Question about Neff Microwave Ovens
Hi I have a neff C57M70N3GB and it suddenly cut out and now no lights or anything. Its stopped working. What can be done to fix it
Hi i have a neff microwave h5642nogb/02 when i switch it on to heat up food it cuts out after about 10 seconds can you please help
The magnetron is probably not working and the main board senses that.
Call an authorised repairer to fix it for you. There are no user serviceable parts in that section of the machine.
Feb 18, 2011 | Neff H5642 Convection / Microwave Oven
Not heating or defrosting although light works, timer etc works
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fjfh
May 11, 2010 | Neff H5470 Microwave Oven
Replace light bulb on the Neff H7871 combined oven and microwave.
The bulb is positioned at the top of the oven, accessible only from the outside. You'll need to pull off the top and bottom trim strips, remove the bottom trim strip locators, remove 2 fixing screws from the left edge of the oven (with door open), and the 2 fixing screws from behind the top trim strip. The oven should then just slide out. You only need to pull it out 6 inches or so to gain access to the bulb cover. You'll need a T20 driver to remove the cover, then the bulb unscrews as it has an SES fitting. Bob
Mar 17, 2010 | Neff H7871 Convection/Microwave Oven
Neff microwave oven not heating
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Sep 22, 2009 | Microwave Ovens
Neff 5470 used for 20 min then just cut out
Take it back to where you bought it from and get a new one!
May 19, 2009 | Neff H5470NOGB 900 Watts Microwave Oven
NEFF H5470NOGB Microwave door latch fault
theres a small plastic hook inside the door which holds a tension spring this will have snapped off stopping the latch from entering the lock its actually quite easy to fix the inner plastic frame can be unclipped with a small flat blade screwdriver exposing the hook mechanism and the spring will be lying in the bottom of the door frame you can reconnect it to the metal inner frame it stretches the spring a little more but it will never snap again ive done this loads of times with no probs otherwise you will have to replace the outer door to reinstate the broken hook.
Oct 27, 2008 | Neff H5470 Microwave Oven
Neff H5642 1000 Watt Microwave
Sounds like the Magnetron may have collapsed. Probably not worth repairing. Check for burnt/browned components on circuit board/s. Burnt wires, insect or ant damage or soiling. Magnetron is the large-ish square metal object with lots of heat-sink fins on it. Check for discolouration. If nothing obvious, it's probably stuffed, If something is obvious, it's still stuffed, but it may be repairable.:::Spiceweasel.au
Apr 04, 2008 | Neff H5642 Convection / Microwave Oven
Microwave Ovens Logo
76 people viewed this question
Top Neff Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Neff Microwave Oven Expert? Answer questions, earn points and help others
