Question about Sanyo SRR49FD
Sanyo SRR49FD refrigerator- We are looking for a handle and hinges for this model, bout so far no luck. Any suggestions?
    Top Expert:
  • Sanyo Master
  • 43,127 Answers
Try this link http://erepairparts.com/
Posted on May 05, 2015
Code 5H2
sh means sensor short and 2 means sensor number 2
Dec 17, 2013 | Sanyo SRR49FD
What does the OP2 code mean
OP means sensor is open OP2 would mean sensor number 2 is open
Sep 10, 2013 | Sanyo SRR49FD
Error code sh2 on a Sanyo srr-49fd
SH2 means sensor number 2 is shorted
Aug 03, 2013 | Sanyo SRR49FD
Sanyo SRR49FD reading SH2 what does it mean?
Nov 16, 2011 | Sanyo SRR49FD
GE "frige model GTS18XCSFRBB; has
Loosen the screws on the top bracket on top of the refrigerator.
Not the hinge between the doors.
Pull up on the door handle and tighten the top bracket screws.
Mar 19, 2011 | Refrigerators
I want to switch the side that the door opens on my refrigerator. Everything looks simple enough except where the handle meets the door. My assumption is that once I unscrew the top portion of the...
This is generic because you did not include the make and model number. Had you provided that info we most likely could have provided you with the installation instructions that would show you exactly what to do.
Having said that... To release the plastic on the top of the TOP hinge use a butter knife on top of a putty knife so you don't dent or scratch the top. Gently lift in and outward and upward direction and it will come right off. Of this us a 2 horizontal swing door model the center hinge is inverted on the opposite side. Sometimes the lower hinge is also inverted. Other times you have to remove the hinge pin and place it on the other side of the hinge bracket. It is not a difficult task but it sure is helpful to have 2 people when installing the larger door. What ever you do leave the pliers off the job / at least away from the refrigerator. You might need them to switch the lower hinge pin installed position. The door handle usually on the lower portion (Screw part) may have a plastic insert covering the screw that you can gently remove with a small knife blade prying around the edges if the insert piece. Other handles it is exactly the opposite of what you stated... you slide the handle DOWN to expose the mounting screw.
If you need more help please include your make and model number and I will do my best to find exact model installation instructions for you.
Thanks for choosing FixYa.
Kelly
Sep 03, 2010 | Refrigerators
How do i change the hinge on thhe refrigerator door? Thanks for your help!
Unplug the refrigerator and remove all food and utility bins from the doors. With the door open, remove the grille from the bottom of the refrigerator. Close the door.
Step 2
Remove the cover from the top hinge with the putty knife. Remove the three screws underneath, then remove the hinge. Take off the freezer door.
Step 3
Remove the three screws from the center hinge, then remove the hinge. Take off the refrigerator door.
Step 4
Remove the two screws from the bottom hinge, then remove the hinge. Replace with the new hinge and insert the two screws.
Step 5
Seat the refrigerator door on the bottom hinge and close the door. Fasten the new center hinge with the three old screws.
Step 6
Seat the freezer door on the center hinge and close the door. Fasten the top hinge and replace the top hinge cover.
Step 7
Replace the base grille, and plug the refrigerator back in.
Good luck in solving the problem with the solutions provided....
Aug 03, 2010 | Sanyo SR-4910M Compact Refrigerator
I to have loose door handles on the ge zfsb27daass and one of the parts that fits inside 1007 broke to fix I have to order1006 which is whole door handle only need one of the inserts to the 1007 any...
Check your local dump facility and you may very well find what you're looking for. Also call local appliance repair shops and ask if they keep any used parts around. When you live as far from the "real world" as I do here in Provincetown Mass. you learn to shop at the most unusual places...Good Luck with the search. Dana
Aug 09, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Not getting power on front panel
what kind of refrigerator. if your talking bout the dispenser housing lights then check your plugs at the hinge above the freezer door. if this is not a side by side then tell me model
Jun 21, 2009 | Electrolux Refrigerators
Sanyo SRR49FD Logo
99 people viewed this question
Top Sanyo Refrigerators Experts
John Tripp
John Tripp
Steve
Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
