Question about Polaroid Televison & Video
My tv will only stay on for 10 minutes
I have switch on and at wall to get it on again but wont stay on longer than 10 mins
    Top Expert:
  • Polaroid Master
  • 74,136 Answers
Fault in the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Posted on Apr 01, 2015
Sound goes off after 15 Min
Assuming it is not hardware but soft settings...
1) Check and make sure that your TV does not have the timer set.
The Timer feature allows you to set a day and time for the TV to turn on automatically and the device and channel to display when it switches on. If the TV is already on at the requested time, the TV automatically tunes to the channel you designated in the Timer menu.
When the Timer turns on the TV, the following message is displayed: "Press a button for the TV to stay on." Press any button on the remote control within five minutes if you wish the TV to remain on.
Note: The TV clock must be set before you can use the
Timer feature (see preceding page to set the clock).
On/Off
Press down arrow / up arrow to enable or disable the Timer.
2) If not working, try SYSTEM RESET. Press SYSTEM RESET button on the front panel with pointed object (e.g. straight paperclip). TV turns off, green LED flashes for about 1 minute. When it stops flashing turn the TV on again. All settings other than Parental Lock need to be set again using the manual.
3) TV RESET. If all else fails for soft error. Your manual describes this last resort for soft type error. It could be hardware problem needing more expertise.
Manual can be viewed on a computer at
http://www.audiolabga.com/pdf/V32-V32L_Service_Manual.pdf
Aug 05, 2014 | Mitsubishi WD-62531 Projection Television
The notebook will not turn on. it charges but wont start. it used to start up and stay on for about 5-10 mins before going on standby, but now it wont even start up. What can i do to fix this?
Without the AC power supply connected (e.g. no external power supply), remove the battery pack to force a hard reset on the software controlled on/off switch and wait a few minutes before reconnecting the battery (and external power supply if your battery is flat): try to switch the unit on again.
Good luck and let me know how you go!
Dec 12, 2010 | Acer Aspire One PC Notebook
Rca projection tv wont stay on but about 1 min then powers off and wont turn back on for about ten minutes then shuts off again after a min or so
Possibility Fan Cooler Issue Check at the back if your hear the fan going if not your fan cooler is burn out .... The Thermistor will shut off the TV automaticly to the unit for Over Heat
Sep 22, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Samsungh LA40B530 No picture but sound
try connecting tv to cable direct also try unplugging both converter and tv for wile like 5 mins plug both back in see if tv and converter sync, but if otherwise then
The ysus board is the most common reason.
you can try websites on ebay.com to buy parts for replacement...
Aug 03, 2010 | Samsung LA40B530 40 in. HD-Ready TV
Sony tv-
hello this happened to mine what i did was switch it off at the switch then unpug it from the wall and leave for 10 to 15 minutes then switch it back on tv was ok i hope this help's
regards
shaun
Feb 21, 2010 | Sony Grand WEGA KF-42SX300 42" LCD TV
My converter box will not turn on. The light stays red. i plug it in and it lights red but it wont turn on it stays off and i use remote and i manually push the power button but it wont turn on!!
TRY
Unplug receiver.
Leave for 10mins.
Plug in again.
Wait another 10 mins.
Press the hand control stand by button.
In a few minutes the light should turn green and start options should appear.
Good luck. This works when my HD box freezes.
Feb 02, 2010 | Televison & Video
My Nokia 3110 wont come on when I switch it on
Your battery might have drained. Try plugging it to a wall socket with a charger and turn it on after 5 minutes whilst the charger is still plugged in. If it still wont work, try replacing the battery pack.
Nov 03, 2009 | Cell Phones
Wall furnace shuts off after about 10-20 mins
sounds like its not venting properly...it likely is shutting off on a "Spill switch" or "Vent safety switch"....check the vent/chimney first off.....also the pilot could be dirty..,..a lazy pilot tends to blow out easily....pilot should be blue and sharp,,,big enough to fully envelope the thermocouple
Oct 30, 2009 | Heating & Cooling
LG TV Turns itself off
Sounds like it could be a poor connection in the power plug or a ' dry joint ' on the power board, if it's the latter, it will respond to light thumping at the side of the tv. If that's the case it needs resoldering by a technician..
good luck !
Mar 30, 2017 | LG 32LG30 32 in. LCD HDTV
Televison & Video Logo
44 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
