Question about John Deere Garden
Why does my LA105 john deere lawn tractor only click when i turn key?
I replaced the solonoid and brake/clutch switch, also charged the battery. Nothin but one click when i turn key. Last summer you had to press in the brake pedal to just the right spot to get it to crank. That is why i changed the brake/clutch switch. Anyone know what I'm mssing other than the switch under the seat? Any other safety switches or problems i should be looking for?
  • 4,128 Answers
The click you hear is the starter solenoid. If the starter doesn't engage, it is suspect.
Posted on Apr 01, 2015
Testimonial: "Thanks. I was thinking same thing but was also thinking maybe ther was another switch somewhere that i was not checking."
  • John Deere Master
  • 2,478 Answers
With a wire with coated, go from big nut on solenoid to other big nut. It will you if solenoid problem.
Why will engine not start.
first make sure battery is fully charged and in good shape. Be sure pto is off and brake/clutch pedal is depressed. If still nothing then check fuse. After that its likely a safety switch or bad connection.
Aug 03, 2014 | John Deere Garden
I have a John Deere D130 riding mower that will not start. When I turn the key I get nothing. When I jump from the battery + to the solinoid the motor cranks. I have replaced the seat switch, the brake...
check out all the safety switches , they make a circuit on closed , = make sure your safe not in gear etc , put a shunt direct and make sure you have cuircuit
Jul 19, 2014 | John Deere D130 22HP V-Twin Foot Pedal...
I need a wiring schematic for the LA105 John Deere lawn tractor
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt?search=model&model=la105
Jun 14, 2014 | John Deere Garden
John Deere 855 Compact tractor has no power to solenoid
Power from the battery direct to a big terminal on the solonoid. The other big terminal leaves the solonoid for the starter. Then there are either one (1) or two (2) smaller terminals on the solonoid. If there is one then the body of the solonoid is the ground. With two of course the extra is the ground. Make sure the solonoid has a good ground.
Remove the smaller terminal from the solonoid ( usually yellow) and connect the positive end of a multimeter or a DC volts tester to it. ground the other end of the tester and turn the ignition key to start. If you get 12 volts to the wire end then the solonoid is bad and should be replaced. If no voltage is registered then the ignition switch is bad or an inline safety switch such as: nuetral, clutch/brake, PTO, seat ( Operator Presence Switch). Or you have a bad wire, bad ground, bad connection somewhere in the starting system.
Oct 31, 2012 | John Deere Garden
I have a john deere LT 150 that will not start. When you turn the key nothing happens. I've checked the seat switch , the mower engage switch and a new brake/clutch switch. Battery is good. You ca
you have a safty switch problem you have 4 to 6 switchs the easest way to test them ,startin with the seat get a ohms metter they are open or noramly closed
Oct 23, 2012 | John Deere Garden
My John Deere 5210 just stopped running .
check the safety switch on the brake/clutch pedal
Aug 30, 2012 | Garden
Just bought a John Deere d140 had it delivered by home depot. Went to turn key, tractor completely dead. Lights won't even turn on. Looked in manual says to charge battery. What do I use to charge this...
are you pressing down the clutch/brake pedal? is the pto switch turned on?are you sitting on the seat?the lights only come on while its running not with the key turned on
Apr 30, 2012 | John Deere Garden
I have a john deere 240 lawn tractor. It will not turn over. Bat. has 12.45 volts. i think my electronic pto switch has gone bad. Any way to check it?
Engine wont turn over on lawn tractor. There are several kill switches that could cause the problem. The seat switch, electric pto or the clutch switch. There are also fuses in the electric circuit that could be blown. If you hear a clicking sound when you turn the key then it could be a weak battery, weak starter or the engine has locked up. If locked up remove plug and squirt oil in spark plug hole. Sometimes that helps if cylinder has been flooded with gas.
Feb 04, 2012 | John Deere Garden
The electric Starter motor will not stop running
If the starter continues to spin after the engine is started..replace the key switch, it is bad
Apr 10, 2009 | Garden
Garden Logo
169 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
