Question about Toro Garden
Crank case not venting blowing dip stick out - Toro Garden
  • Toro Master
  • 2,478 Answers
Check your crankcase vent. May be dirty. Some have filters on the oil fill cap.
Posted on Apr 01, 2015
  • Toro Master
  • 1,169 Answers
Maybe a blown head gasket or bad rings causing excess blow by pressure.
My intec 22hp. Briggs moter blowing compressed air out dip stick
they all do that to some degree . some vent back to the carburetor and some use that pressure to power the fuel pump .
May 14, 2016 | Garden
What's your question?my Isuzu 4ja1 engine .my problem is the oil comes from deep stick
i think you mean
when running the engine
the DIP STICK seal as it fits the dip stick tube end. leaks oil
this a bad PCV valve.
excess crank case pressures.... cause by not doing service on car.
or worse a very worn out engine with huge blow by gassed.
is engine miles high? over 300k? miles?
or the dips stick seal there is bad.... looking at it tells you that.
Sep 20, 2015 | Isuzu Cars & Trucks
My new crf 150 is blowing oil out of vent tube rode 2 hours and oil is barely on stick any ideas?
Sounds like it has NO OIL!!!!
The 'vapour' is just that, oil vapour from crank-case.
If the 'Stick' is the 'Dip-Stick', put some oil in it (till it reads the correct level).
Good Luck with it.
For more Bike stuff, go to YouTbe/CrashTestDummyTV
Cheers
Aug 22, 2015 | 2014 Honda CRF 150R
Exaust blowing out oil dip stick
Too much crank case pressure, Cause:- blocked crank case breather, worn piston rings gases passing into engine causing excessive pressure. Remedies:- engine rebuild/ replace unit
Dec 27, 2013 | 1998 Mercury Mountaineer
Why is crank case pressurizing
check for a blown head gasket one side of the gasket goes to the crankcase if blows out
Jul 15, 2012 | Garden
Why is my diesel blowing oil from the dip stick?
Sounds like blow-by...due to worn piston rings. (Compression that gets pushed past the rings, into the engine crankcase, and out the dip stick tube.) Make sure that a vent may not be plugged.
Sep 08, 2011 | Isuzu Trooper Cars & Trucks
Where is the pcv valve located on a 1998 c70
There isnt' one. Volvos are equipped with vent-box located underneath the intake manifold. Remove the oil dip stick tube and then the intake manifold and remove the box. Install a new breather box and make sure to clean the lines going to and from the box. If the breather box gets clogged, oil will push from the oil filler cap, dip stick tube and worst case, blow through the engine seals.
Feb 28, 2011 | 1998 Volvo V70
The oil dip-stick is blown out of its seat when the compressor runs
Without knowing what make or model you have, check the following:
1. Some, not all, compressor dip sticks have venting holes for the crankcase. If the vent holes are plugged or the check ball is stuck the dip stick will get forced out when the piston comes down.
2. Make sure the oil level is where it's supposed to be. Too much oil in the crankcase will cause the motor to work harder and the excess oil being splashed around the crank case can overwhelm the vents in the case or dip stick and again blow the dip stick out.
3. Worst case, you have worn or broken rings on the piston(s), a hole in a piston or a badly scored cylinder(s) and air is leaking past the piston and creating pressure in the crank case and blowing the dip stick out.
Jan 26, 2011 | Campbell Hausfeld Air Tools & Compressors
1979 chevy 350 modded to 383 stroker i have been
Sounds like the engine can't breath,
make sure pcv valve is good,or oil cap is vented.
your engine is building up pressure and has no where to vent,so it blows the easiest thing,the dip stick
Nov 18, 2009 | 1983 Chevrolet K1500
Garden Logo
62 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
