Question about Toshiba Computers & Internet
Changed a hard drive on a Toshiba laptop got an error message F3-FF00-0026 wont let me put windows 7 back on it?
    Top Expert:
  • Toshiba Master
  • 10,875 Answers
How To Fix Toshiba Error F3-ff00-0026 Errors
Your operating system is: Windows 8.1
This repair method is compatible with your OS.
Summary
Toshiba Error F3-ff00-0026 and other critical errors can occur when your Windows operating system becomes corrupted. Opening programs will be slower and response times will lag. When you have multiple applications running, you may experience crashes and freezes. There can be numerous causes of this error including excessive startup entries, registry errors, hardware/RAM decline, fragmented files, unnecessary or redundant program installations and so on.
Resolution
You can dramatically improve the speed of your machine when you address all the problems just mentioned. In order to fix your errors and improve the speed of your PC, it is recommended that youdownload the 'Toshiba Error F3-ff00-0026 Repair Tool'. This is an advanced optimization tool that can repair all the problems that are slowing your computer down.
Download the Toshiba Error F3-ff00-0026 repair tool
Recommended: In order to repair Toshiba Error F3-ff00-0026, use this version of Reimage . This repair tool will locate, identify, and fix Toshiba Error F3-ff00-0026 errors. Your computer should also run faster and smoother after using this software.
File Size6 MB
CompatibleWindows XP, Vista, 7 (32/64 bit), 8 (32/64 bit)
LicenseFree evaluation version. To unlock all features and tools, a purchase is required.
Downloads361,927You need to understand just what causes these errors and slowdowns in performance. There are a lot of reasons why Windows errors happen, including having malware, spyware, or programs not installing properly. You can have all kinds of system conflicts, registry errors, and Active X errors. The registry on your computer will accumulate errors over time. It's just a fact of life in the computer world. This happens as programs are installed and modified, or even removed.
Over time the errors and conflicts begin to accumulate and add up, slowing down the effectiveness of your PC. When you remove programs from your PC, they don't always take out every single file, and some can be left there to interfere with your PCs functions. Most of the time people don't even realize this is going on. But over time, the evidence will appear. Computers need to be regularly maintained, just as you would a car.
We highly recommend downloading Reimage and using it to optimize the stability and performance of your PC. This software program has already proven its ability to locate and repair Windows errors. It can delete junk files, decrease your startup time, restore lost memory, defragment your hard drive, remove spyware and malware, and lots more. Reimage will get your PC running smoothly again, and make it a lot more fun to be using your PC by maximizing its total potential.
Posted on Apr 01, 2015
    New Friend:
    Problem Solver:
  • 5 Answers
Did you install the a new OS on the new Hard Drive?
My Toshiba v63700-c 1TB external hard drive worked great in Window 7. My v63700-c does not like Surface 3 Pro. Do I need a new cable?
Somewhat depends on what "does not like" actually means. So far, I've not found any USB item that works differently on my Surface than on my laptop or desktop, Windows 7 or 8.
Is there an error message? What does it say?
Apr 14, 2015 | Toshiba Computers & Internet
Error code on toshiba laptop F3-f100-003
No doubt that the hard drive has serious problem, You need to replace the hard drive ... Then reinstall the operating system on the new drive using the disc you have.
Jul 31, 2014 | Toshiba Satellite Computers & Internet
How to upgrade a toshiba L305 to a 500gb hard without hardware failure error
I'm a bit confused? You are trying to install a HDD with Windows 7 on it from another computer in a Toshiba L305 laptop? If that's correct, it will not work, first, you must format the 500GB SATA HDD, then load the Windows 7 OS to get a clean install. Clarify the question if I am incorrect.
Jul 03, 2013 | Toshiba Satellite L305-S5875 Notebook
Getting error code F3 F100 0003 on a Toshiba Satellite L650 running on a Windows 7 Ultimate 32 bit operating system. This code appeared before hard disk drive was replaced and continues to appear after a...
Hi Lea,
If you're getting the F3 F100 0003 error on boot-up, the problem might lie on three things. It's either the a bad HDD, Memory, or the video adapter (which is soldered on the motherboard). Since you already replaced the HDD, the problem might lie on the other two. If you can burn a disc to run diagnostics on your computer, you can use UltimateBootCD or Hiren's Boot CD (more info on the tools here).
I've also seen some errors when you are trying to re-image the HDD using the Recovery Discs and it may have some connection to the error message that you're getting. Here's a list below:
-An error has occurred: ERROR : 10-FC10-1710" -- may be caused by a faulty hard drive.--An error has occurred. ERROR : 10-FC12-0241" -- may be caused by a faulty hard drive or defective memory.
-An error has occurred. ERROR :10-FC12-045D" -- may be caused by a faulty hard drive.
-An error has occurred. ERROR :10-FC06-0002" -- may be caused by damaged recovery media or faulty hard drive.
-An error has occurred. ERROR :10-FC12-0970" -- may be caused by defective memory.
Hope this helps. Good luck.
Sep 06, 2011 | Toshiba Satellite L455D-S5976 Notebook
How do you go about to format a toshiba l650 and reinstall windows 7
Hi! If you have the Windows 7 disc just insert it restart the computer. It will boot directly from the disc. Then follow the step by step instructions here.
If you don't have the Windows 7 disc, you have two ways to reformat your Toshiba computer.
Using Toshiba HDD Recovery Utility from the recovery partition
In case of a hard disk drive failure, you may be able to restore the drive to the factory default state using the on-disk Toshiba HDD Recovery Utility (in a special partition on the hard disk drive).
You can select restoring the entire hard disk drive to the factory default state, or restoring only the C: drive -- without affecting other partitions (for example, a D: drive) -- or changing the size allocated to your C: drive, and then restore it.
To recover your hard disk drive from a system failure using the utilities stored on your computers HDD, follow these steps:
  1. If the computer is running, shut it down -- by clicking Start, Shut Down, and again Shut Down.
  2. Press and hold the 0 (zero) key on your keyboard and then press the computers power switch. When the computer turns on, the Toshiba HDD Recovery Utility screen will appear, presenting three options:
Sample TOSHIBA HDD Recovery Utility screen
Restore Original Factory Image (Recommended)
CAUTION:
Restoring a hard disk drive to its factory default state deletes all partitions on the hard disk drive and all data stored on those partitions. All of your files and information will be lost! Be sure to back up all important files first.
  1. Press 1 to restore your hard disk drive to its original factory default state. A confirmation message will appear, indicating that all data will be overwritten and lost during the restore process. Be sure to back up all important files before proceeding.
  2. Click Yes to begin the recovery. A message will appear once the operation is finished, indicating the HDD has been restored.
  3. Press any key to restart the computer.
* The options 2 & 3 are for advanced users.
Hard Disk Drive Recovery using Recovery CDs or DVDs
You may also wish to to run the Toshiba HDD Recovery Utility from Recovery CDs or DVDs that you have created.
Insert the first Recovery CD or DVD into your CD/DVD drive, and turn on the computer. Once the computer is running, the TOSHIBA HDD Recovery Utility screen will appear, presenting the same three options above. Again Press 1 to
restore your hard disk drive to its original factory default state. Click Yes to begin the recovery. Press any key to restart the computer.
Installing Drivers and Applications
The TOSHIBA Application Installer allows you to reinstall the drivers and applications that were originally bundled with your computer.
To reinstall drivers and applications:
  1. Double-click the "Toshiba Application Installer" icon on the Windows desktop. This utility may also be launched by clicking Start -->All Programs --> Hard Disk Recovery Utilities.
  2. Click "Next".
  3. Click the item(s) you wish to install. To select multiple items, hold down the Ctrl key as you click your selections.
  4. Click "Install".
  5. Follow the on-screen prompts to complete the installation process.
Hope this helps.
Jun 19, 2011 | Toshiba Computers & Internet
Toshiba laptop wont start up
change the ram (Random Access Memory) on your laptop your ram is not working
Regards
manish
Mar 24, 2010 | Toshiba Satellite A200-0ET00X Notebook
Hard disk error message.The computer says that windows has detected a hard disk error and that I should back up all of my system files to avoid losing all of my information.
Sounds like you have an bad sector in with the windows system files. Yes backup now! I would buy another hard drive, you can try to re format and put you stuff back on, but for the price of hard drive buy an new one.
Feb 26, 2010 | Toshiba Satellite L305D-S5895 Notebook
Toshiba Satellite A105 s4254 Wont Boot Recovery Disk
You most likely have a bad hard drive. I would replace the hard drive and run a recover disk to put your laptop back to it factory condition. if you don't have a recovery disk you can get one at one of the sites below.
http://www.myrecoverycds.com/toshibaSets.html
http://www.recovery-cds.com/laptop/search.asp?keywords=toshiba
Feb 17, 2009 | Toshiba Satellite A105 Notebook
Problem with recovery of the system (Windows XP)
check the status of harddisk on bios, whether detecting it or not if detecting then also check the hdd status, change its native status
Oct 24, 2008 | Toshiba Satellite A135-S4527 Notebook
Computers & Internet Logo
594 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
