Question about Panasonic Televison & Video
Trouble turning on via remote control - Panasonic Televison & Video
    Top Expert:
  • Panasonic Master
  • 74,196 Answers
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Posted on Apr 01, 2015
Try to turn on via remote or button on set. Only a green flash on front. Nothing else. Can I fix it?
About 435,000 results (0.80 seconds) Search Results
    3 Ways to Program an RCA Universal Remote - wikiHow
    www.wikihow.com > ... > TV and Home Audio > Television
    wikiHow... Universal Remote. Are you tired of juggling three or four different remotes just to control your home theater setup? ... Log in via ... Turn on the device you want to control. ... Press and hold the button on the remote that corresponds with the device.... You will need to try another method in this article to program the remote.
    How to Program an RCA RCR312W Remote: 15 Steps ...
    wikiHowHow to Program an RCA RCR312W Remote. ... Log in via ... Press the PLAY buttonevery five seconds until the component turns off. ... If component does not respond or has limited functionality, codes in a different block list can be tried until you find the code that allows the remote to .... Set Up a Home Theater System.
    Your remote reprogramming woes solved - Rogers RedBoard
    redboard.rogers.com/.../your-remote-reprogram...
    Rogers CommunicationsJun 18, 2014 - Once the TV turns off, press the SETUP button once to lock the code.... You can always contact us via our Facebook page or tweet us ... Hi my TV is anRCA model # RLDED3258A-B I have tried 73 codes from Universal .... I have tried toset up my tv and home theatre with the Rogers remote but no luck...
    RCA TV: input channel/s-video - ecoustics.com
Jan 19, 2016 | RCA Audio Players & Recorders
Remote controller
The remote control you uses need cleaning. Check this site to get more details about how to check and clean a remote control. Pull up older posts there. One among has details.
Mar 31, 2013 | Yamaha Remote Control RAV252 p/n:WE458500
My fuel cover does not lock with central locking
According to WIS, the remote boot release is directly connected to the PSE via CAN
The pneumatic system equipment makes vacuum or pressure available for the following systems:Central locking (CL), (pressure, vacuum)Remote trunk release (RTR), (pressure)- actuation via remote trunk release switch or via radio
AD80.20-P-2002-02B Remote trunk release, general notes on Models 202.01/02/12/12 as of 1.6.97,diagnosis, advanced information, RTR 208, 210 as of 1.3.97, 210.081Actuation of PSE control module:The remote trunk release switch (N72s15) is connected to the PSE control module (combined) (A37) via CAN data buses. The remote trunk release radio signal from the key is conveyed to the overhead control panel control module (N70) via theantenna. This transmits the signal to the electronic ignition switch control module (N73) via CAN data buses. If a valid signal is recognized there the PSE control module (combined) (A37) is actuated via CAN data buses. The remote trunk release IR signal from the key is conveyed to the respective door control module (N69/1, N69/2) via the IR receivers (A26/1, A26/2). This transmits the signal to the electronic ignition switch control module (N73) via CAN data buses. If a valid signal is recognized there the PSE control module (combined) (A37) is actuated via CAN data buses.
If the trunk lid is unlocked the LED in the remote trunk releaseswitch (N72s15) is actuated by the PSE control module (combined)(A37) via CAN data buses.
Special features on model 208.4 (Cabriolet)The trunk lid cannot be released remotely with the transmitter key.The rollover bar (RB)/soft top operation control module (N52)signals via the CAN interior data bus whether the soft top is lockedor unlocked or the power soft top switch (S84) is operated. As long as the CAN message reads:"Power soft top switch (S84) operated" or"soft top unlocked"the trunk lid cannot be released remotely.
Pneumatics testingPermissible leakage in complete system at:vacuum of 300 mbar within 1 minute: 30 mbarPermissible leakage of actuators with lines at:vacuum of 300 mbar within 1 minute: 25 mbar
Thanks
Apr 02, 2012 | 2000 Mercedes-Benz CLK
Code for Universal Remote Control - 24116 GE
How I turn on closed captioning through this universal remote via with old model sanyo tv model: DS25500
Jan 11, 2012 | General Electric Universal Remote Control
Gant get past language selection
This screen requires you to use motion controls, meaning you have to actually have the sensor bar set up properly, and then physically point the wii-mote at the buttons you want to select. You cannot use the arrows.
If you are having trouble getting the wii-mote to point, be sure that your sensor bar is in the correct position, that you are at least three feet away from the sensor, and the remote is one. If all three of those things apply, turn your system off, let it sit for a minute or two, then turn it on and try again.
If the problem persists, try syncing the remote via the remote's instructions.
Mar 08, 2011 | Nintendo Wii Console
Cant connect asus computer to tv via hdmi
Try turning both pc and tv off and connect, then turn both on. Also, make sure your Display setting are correctly configured. Goto Control Panel, Display and click on Settings Tab. If your still having trouble. Try changing your resolution and make sure that you have your TV to the right input. My TV has 4 HDMI 3 RCA 2Component 1 Digital Optical many USBs...can get kinda confusing. The connection should be numbered. Switch inputs with your remote til you get the right port. Then work on getting your pc to display correctly. Set your aspect ration to 16:9 first. Most tv and laptops are set this way. GOOD LUCK let me know how it goes.
Sep 12, 2009 | ASUS A2400H Notebook
Connected home theatre system but no sound sub woofer
If the system uses a remote control, you may need to adjust the subwoofer out signal setting or turn on the sub in a menu, and on many systems, you can only access those settings via a remote control (you should check the onkyo user manual on how to do it).
Now, this is just one suggestion, it may work, but then again, it may not.
These could also be connection problems or some internal trouble in the onkyo sub signal output section or in the subwoofer input section, but hopefuly, it's just a "turn on" or "signal level" setting in a menu.
Good luck
3rq8 (triarcuate)
Jul 23, 2009 | Onkyo HT-S780 System
Living solutions giant remote control 3-in-1, A17G0510 (Item606426)
I had trouble programing the living solutions giant remote - c17g0801.
But after many times serching I ran across a genius' resolution (maybe it was 2 genius') -
Jumbo Remote:
Make sure you have device turned on.
Hold the device button you want to program for 3 seconds & release.
Push & release the power button & the red light will remain lit.
Push the CHANNEL UP button over & over slowly until the device turns off.
When device turns off press OK button.
Oct 27, 2008 | Philips Magnavox Learning Universal Remote
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
