Question about Ovens
Why does the bottom oven worj but the top oven does not
    Top Expert:
  • Ovens Master
  • 45,332 Answers
Possibly burnt out element
Posted on Apr 01, 2015
How do I fix an oven door
sounds to me like bottom hinges are set to close to oven/ need spacers so oven door closes flat top and bottom at moment it seems that bottom is to tight before oven door is closed ,try fitting spacers behind hinge fixings at bottom, good luck
Sep 22, 2016 | Ovens
Beko OFT12300X double oven top oven getting exceptionally hot inside when only the bottom oven is on
I know of nothing unusual about this, the oven vents some through the top burner.
May 19, 2017 | Ovens
Bottom oven won't turn on;
85% of these are usually the ignitor getting week and not allowing the gas valve to open prideapplianceser@sti.net
Dec 31, 2008 | Amana AOGD2750 Gas Double Oven
Meaning of symbols on oven setting.
i would know them if i were looking at it but hope this helps
line at top - top element only
line at bottom - bottom element only
line at top and bottom - conventional oven ie top and bottom elements on
wavy line - grill element
pic of fan - fan only with no heat
pic of fan with a line as well - fan oven
youi may not have all of these depending on oven.
best to use i find is fan oven - i do a lot of cooking!
Nov 05, 2008 | Smeg SE250XUK Stainless Steel Electric...
Hotpoint double oven
Top oven works bottom oven fan works but bottom oven does not work and cannot get rid of auto signal
Jul 22, 2008 | Hotpoint UY46 Style Line Stainless Steel...
Fridgiaire Gallery series Model GLEB30T8CBA lower elements dont work
I replaced the relay board for the top oven (the one with the transformer) and it works properly now. My issue was only for the top oven so you probably have to replace both relay boards since both ovens have only the top element working.
318022002 is the part number for the relay board with transformer
318022001 is the part number for the relay board without transformer
Yes the one without the transformer is more expensive for some reason.
The boards are on the top of the oven, I was able to pull out the oven about 75% of the way out of the cabinet and easily get to the boards. Just unplugged the connections and plugged them into the new board.
To get the oven out there are two small screws that go into brackets inside the top oven door. Highly recommend taking the doors off the oven to pull it out, much easier to work with.
NOTE: On my old board I noticed one solder joint that was burned out and I since I already had the new board I just replaced but you might want to check that first and see if just a solder fix gets you working again before you spend $$ on a new board.
Jun 30, 2008 | Frigidaire 30 in. Electric Gallery Series...
Top oven will not heat up
Had a similar problem. The overheat sensor had failed to the open position and the oven control would light up and you could set the temp, but it would drop to 100 degrees and then go blank.
Nov 14, 2007 | GE JKP45 Electric Double Oven
Kenmore 47779 double oven; lower oven doesn't work after self clean
Sounds like a thermal overload has opened up during clean. It may be mounted on the back.
Nov 02, 2007 | Kenmore 47772/47774/47779 Electric Double...
Ovens Logo
53 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
