Question about Refrigerators
All works except no cooling - Refrigerators
    Top Expert:
  • Refrigerators Master
  • 44,252 Answers
Then all does not work call a repair man it needs recharged no doubt
Posted on Apr 01, 2015
Not cooling and led blinking from top to bottom
Your refrigerator is in "Cooling Off" mode, or sometimes called "Store Display Mode", which basically allows everything in the fridge to function except for the Cooling system. Press and hold down the "Lighting" and "Freezer" buttons for 5 seconds until you hear the "Ding Ding". Your 'fridge will be working again.
Feb 26, 2014 | Samsung RS261MDPN Side By Side...
Amana PTAC unit will not cool or heat. Tried reseting, checked supply voltage, ohms checked the heating element, voltage checked off of circuit borad (power everywhere except the two heater terminals)
Compressor working ?
Please follow this tips:
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Please specify, if any error code..........
Thanks. Helpful?
Jan 19, 2011 | Heating & Cooling
On my all buttom qualink 4 on my buttons work except when I turn the spa off the cool down mode doesn't seem to work it says heater will turn off after cool down but the jandy doesn't turn back to filter...
Your heater should shut down rite away and the pump will keep running to pump cool water through the heater. After the cool down period then the valves will go back to normal run positions.
Nov 04, 2010 | Jandy AquaLink RS2/6 All Button Dual...
Lg fridge not cooling... freezer works..
Not knowing the make of fridge it seems like you have a faulty thermostat as in newer fridges most operations are controlled by this.
Mar 28, 2010 | Refrigerators
The refrigerator is not working
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 02, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Programmable T stat
your trane heat pump energizes the reversing valve with O - orange y - is to turn on the unit make sure you have your orange wire hooked up and the tstat programming set to heatpump otherwise your reversing valve might be bad
Jun 30, 2009 | Honeywell Electronic Programmable...
Heater stays at max temp, air conditioner hot except on max cool.
it sound like one of the flap in the duck work is not working. check your heat contrell unit in the dash
Mar 22, 2009 | 1998 Mercury Mountaineer
No cooling
May have burnt wire or bad capacitor to compressor.When running incool can you here the compressor running or is it maybe just the fan outside running?
Jan 08, 2008 | Fujitronic FH-797 Portable Air Conditioner
Refrigerators Logo
42 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
