I have split ac But The problem is as i on Ac The compressor to Starts with it Sudden.
  • 2,963 Answers
Usually, there is a delay timer in the thermostat system to prevent overloading compressor by multiple on-off by changing thermostat settings or power failure and back on. If that delay timer is bypassed, it will shorten the life of the compressor. If the delay timer is not functioning properly usually it will stop any start of the compressor and you will need a ACND technician to replace it.
Posted on Apr 01, 2015
I need to buy the compressor card for sankey air conditioner split model 12inv31
Most local home improvement stores do not carry AC components. I would try 1-800-269-2609 or google places in your area that sell AC parts. It could also be that it needs a cleaning. Can you provide any other details? I hope I can help.
Jul 28, 2016 | Heating & Cooling
I have samsung split ac 1.5 ton 2.5 years old when am switch on the ac the indoor unit is working when it tires to on the out door unit after 3 minute delay suddenly the ac is restarting but the out d
Make sure all of the pressure switches are closed on the low voltage control circuit on the outdoor unit. If any are stuck open, the compressor will not kick on. Or just push the compressor contactor in with an insulated screwdriver to ensure the compressor does actually work.
Dec 28, 2014 | Samsung Heating & Cooling
Why is there a rattling sound under my hood after i re charged my ac?
The possible problem here is that you put in too much gas and the compressor pistons are pumping liquid and not gas . This is hammering the rod ends on the swivel plate and if allowed to continue will result in compressor failure requiring a new compressor Have an accredited ac specialist shop check the pressures in the system and adjust to correct levels.
Jul 28, 2014 | 2006 Scion xA
Dawlance split ac
My guess is compressor motor overtemp cutout. So why is the motor overheating? Possibles: Needs bearing oil, bad bearings, compressor too much pressure, overfull with freon, mechanical friction, cooling fan not turning.
Suggest set thermostat to demand less cooling, see if compressor stays on longer.
--Gil
May 25, 2014 | Haier 18000 Btu Air Conditioner Heat Pump...
Samsung 2.0TR split ac compressor getting heated up and tripped after running for 10 mins
High limit switch set to high, obstruction in the system, or your compressor may be wearing out.
Apr 12, 2013 | Heating & Cooling
Split AC whole unit turnig off at each compressor start up!
Dirty coil wash outside unit with water and change indoor unit filter
Jun 08, 2017 | Heating & Cooling
Compressor starts then stops after maybe 3 mins
Any error codes? If not there may be a mechanical fault with the compressor/inverter. The unit is possibly short on refrigerant, so the compressor is not getting enough suction cooling from return gas, so may be clicking off on its internal over temp klixon.
all the best
Jul 05, 2010 | Mitsubishi MS-A09WA Split System Air...
Ford Ranger 1994 - AC stopped working - AC system pressure way hi
There is a low side pressure switch on the dryer,remove the plug in connector and use a wire to connect the two circuits together on the plug,if the ac compressor runs,and the ac cools fine,replace this switch,it just unscrews,and you will not loose any freon.
Jun 09, 2010 | 2004 Ford Ranger
Heating & Cooling Logo
64 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
