Question about Panasonic PT-47WX53 47" Rear Projection HDTV
How to reset defaults Panasonic HD PT-47WX53G TV/picture
I have a Panasonic HD PT-47WX53G TV and i did the unthinkable. i went in to the service menu to try and fix a slight convergence problem, and now my picture is all screwed up! is there a reset or a way to recall factory defaults?
  • Anonymous Dec 09, 2007
    We have the same model- PT-47WX53G- Panasonic high def. projection tv and experienced the same problem after trying to manually adjust/align the images. The next time we turned on the tv we noticed the closed captioning was doubled and red/green colors separated out, especially on the bottom left part of the tv screen.
  • Panasonic Master
  • 5,138 Answers
First of all are you sure you were in the factory menu this step requires alot of known how!!!!!! By using your hand unit only customer controls can be reached unless you know factory menu setup. Which starts like this ,make sure antenna to cable then go to menu set sleep timer to 30 mins exit out now enter ch 124 then press v- down on tv you should now see on top CHK ,also these sets have double convergence patterens.if you were in factory set up for more information look in techassist/09-2005 .let me know if you still need help.
Posted on Dec 21, 2007
  • giocas Nov 25, 2010
    I have checked for info in but did not find information pertaining the issue for this model. I have followed your instructions for reseting to factory settings and did accomplish up to where i did see the CHK on top. I just dont know what is supposed to happen after that or if I have to do additional settings......would you please let me know if the factory reset was complete after your last instruction of seeing CHK on top of the screen?
Pt-47wx53g tv won't click over n than the power button will blink 5 times
IC4511 has failed on the DG board replaing the DG board as a unit i the only way to fix the issue. The DG board isnt serviceable
Jun 01, 2012 | Panasonic PT-47WX53 47" Rear Projection...
My Panosonic TV Model# PT-47WX53g has sound but no picture
Part is C509 located on D board:
It is a .47 @ 200 volts and the location is marked top and bottom on the board.
Examine the attached photos (cap has been removed but you will see exactly where it is located).
Let me know if you have questions
Jan 17, 2012 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic pt-47wx53g tv power light blinkcs 5 times and goes out.
Convergence problem...causing the TV to shut down. Goto and get one of their fixes.
Jun 04, 2010 | Panasonic PT-47WX42 47" Rear Projection...
PT-47WX53G. TV got moved. Unable to move blue
The convergence ICs have failed which is very common when the set has been moved as a wek IC wont allow the color to be moved. You can get the PT52WX53G convergence repair kit from which is the correct one for your model. The kit contains the parts and the CD with repair instructions.
Apr 10, 2010 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic CinemaVision PT-47WX53G : half the screen is distorted
did you try to try to adjust the vertical and the horizontal of your tv?
Oct 05, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Hi, We need solution for B-Ray connection to PT-47WX53G
We solved the problem with Sony experts from Vio. Thank you
Jan 03, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Picture quality on PT-50LC14
clean out the housing (where the lamp is) the go through your menu and check the tv settings ie...color temp, picture, contrast, ect...try resetting it back to the default and go from there
Nov 09, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Just bought a PANASONIC PT-47WX53G On ebay for what I thought was a steal. It was explained that somehow someone got into the service menu and messed something up with the convergence on the green gun....
You can try restoring to factory defaults, and you can try the manual convergence option. If the manual convergence fails to reset (as in, the crosshairs physically will not move), then the convergence board is bad, and will need to be replaced or repaired (if you are a good circuit solderer).
Mar 07, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Same tv but smaller
Sorry there is no reset for this alinement,you probly need your ics replace and complete convergence alinement ICs are STK-392-110s or 150s , I myself replace them with 180s.
Oct 10, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
2,344 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
