Question about Depo Auto Parts Saturn L100 L200 LW200 L300-1 2001 2002 2003 2004 A/C Condenser Cooling Fan Assy w/ blades, motor, & shroud OEM: TYC 610640, Interchange : GM3113115, Other : 15867597
When the battery is good dash lights come on but no start no cranking of starter
Put starter on worked fine for a few months now when I try to start it I get nothing
This seems like you have problems with your south or north bridge, try to disconnect the HDD. If it's no changes, you will need to take it to the service center to resold or change the chip.
Posted on Apr 21, 2015
  • 3 Answers
Check battery connections, make sure they clean and tight. Often there is enough connection for a light but not good enough to pull high amp starter.
Posted on Apr 01, 2015
Why is there No crank no start and what could cause the problem?
Maybe the battery is not giving enough amperage to crank the engine
May 17, 2014 | 2009 Mitsubishi Lancer ES
1999 yukon denali has power but will not crank the engine
check battery for enough cranking power, if battery is below 8 volts, your dash lights will work, but you wont have enough power to start the engine
Apr 12, 2014 | 1999 GMC Yukon Denali
2003 yukon will not turn over.When I turn the key all the dash lights come on. It started doing this about 6 months ago. It would usually start after 2 or 3 tries or if i put in nuetral and let roll a few...
It could be the starter has a dead spot,the battery voltage is weak,the ignition switch itself,the antitheft passkey or the neutral safety switch..it could also be a bad brake switch.The shift /start interlock is connected to the brake switch...
troubleshooting..... 1) put a test light on the small wire on the starter and see if it lights when attempting to start.if it has 12v or the test light is bright,,but will not crank,tap the starter gently with a plastic hammer,if it cranks the starter is bad.2) make sure the security light is going out.If not it is not reading the passkey and the ignition is faulty.3)when it does not start,jumper with a good battery and see if it starts if it does the battery voltage is low.4) make sure the brake lights go on with every application of the brake pedal.5)try to start in neutral instead of park when the failure occurs,if it does...the neutral safety switch is no good.
best of luck
Jan 29, 2014 | 2003 GMC Yukon XL
1997 chrysler sebring jxi no start
Do head lights stay on (bright) while trying to crank starter? If not, starter motor isn't getting enough current, OR engine is locked. Is there current getting through the solenoid to starter motor? Check the ground connection between the engine and chassis as well as battery and chassis.
Jul 02, 2012 | Chrysler Cars & Trucks
Car not starting, not turning over, have air and interior lights
Perhaps a bad starter solenoid or starter. If equipped with factory immobilizer, is there a light on your dash constantly on or flashing security?
Jun 21, 2012 | 2005 Hyundai Elantra
Jeep starter
first try and go back to unhooking battery and cleaning teminals real good with wire brush and put them back on tight you might have good enough contact to light up dash but not enough to start
Jun 06, 2012 | 1995 Jeep Cherokee
My bike will not turn over. When i push the electric start the starter solenoid just clicks.I tried jumping across the solenoid and still nothing, when i got the bike a few months ago I put a new battery...
pull the starter and check it by putting it on a testor or just hooking it to a good(known)battery. If it tests good then check/replace the starter switch and check wires to the switch.
Sep 08, 2011 | 1984 Honda CB 700 SC Nighthawk
Depo Auto Parts Saturn L100 L200 LW200 L300-1 2001 2002 2003 2004 A/C Condenser Cooling Fan Assy w/ blades, motor, & shroud OEM: TYC 610640, Interchange : GM3113115, Other : 15867597 Logo
758 people viewed this question
Top Depo Auto Parts Computers & Internet Experts
Todd Arndt
Todd Arndt
Matthew Spark
Matthew Spark
Andrew Taylor
Andrew Taylor
Are you a Depo Auto Parts Computer and Internet Expert? Answer questions, earn points and help others
