Question about Sewing Machines
How do I fix my sewing machine
The machine's light turns on but when I push the pedal, the machine isn't working.
    New Friend:
  • 5 Answers
Have you tried unplugging and then plugging back in your cord to the foot pedal?? Sometimes they wobble loose a little.
Posted on Apr 01, 2015
I have a Viking 6690, it will sew when pedal is pushed but the machine does not turn on.
Not understanding your question. Not sure how the machine sews if it doesn't turn on...
Are you saying the light doesn't come one? If so, the light bulb is probably burned out and needs to be replaced.
Dec 04, 2017 | Sewing Machines
What would cause my Kenmore sewing machine's light to turn on but the motor seem to have no power?
The wiring for the older Kenmore is simple. The light switch completes the connection to the light. If the foot pedal has failed or connection loose where the wire attaches from the foot-pedal the motor will not run.
Also if the brushes in the motor are worn or failing to contact the motor internally the motor will not run.
With light on and pedal partially depressed attempt to activate motor to determine if brush connection are faulty. If the motor reacts at all the brushes will likely need to be replaced.
No success borrow a foot pedal from a friend or sewing center to determine if the pedal control is faulty.
Hope this helps?
Oct 15, 2016 | Kenmore Sewing Machines
Foot pedal doesn't work
well if the foot pedal isn't working, you can either replace it with a new one or take the machine to a sewing machine repair shop & let them check the foot pedal & see if it's fixable
Mar 14, 2012 | Husqvarna Sewing Machines
My juki serger mo-634de suddenly stopped working. Lights on, wheels and parts move freely, even stitching seems to work if I turn it manually, but nothing happens when I push the pedal. No sound. ...
Hi, I have the exact same machine. it sounds like the wire from the foot pedal to the machine is broken. You would still get power from the wall to the machine to light the light, but no 'gas pedal'. You could maybe get an electrian to test the connection under the foot pedal and if the wire is damaged? or maybe the part that plugs in the machine is cracked or damaged?
Good luck! Annette
Jan 08, 2012 | Sewing Machines
I have a Kenmore sewing machine Model 158, 1792280. The foot pedal is not working well; I was sewing normally and when I finished, I removed my foot from the foot pedal but the machine continue sewing. I...
Buy a new foot pedal for it, probably one of the electrical components inside the foot has failed.
There are Kenmore footcontrols for sale on www.sewingpartsonline.com. You could email them to check its right for your model if it isn't listed.
Obviously I'm assuming that you are in USA with 110 Voltage and that is what your machine is. If not and your country is 220V, you would need to source it from a reseller in your own country or another with the same voltage.
Jun 12, 2011 | Sewing Machines
I just purchased the sew pro portable zig zag sewing machine model zz 401 and it won?t work, the pedal makes this funny sound and the machine isn?t working. What do i do? I tried everything and tried...
Maybe the drive wheel is disengaged. Some machines have you pull out the wheel on the right to wind a bobbin and yours might be pulled out. Try pushing the wheel back in to engage the machine.
Nov 09, 2009 | Steam Fast ZZ-401 Mechanical Sewing...
Beeping Sewing Machine
Your problem is most certainly with the buttonhole switch. Firstly: Look if the buttonhole lever, left back of machine, is push up in position. The beeping sound is a warning message. Secondly Remove the light cover, left of the machine, loosen back screw and remove left hand screw completely. Check for a small black electric switch, follow the brown and green elecrtic wire, just back of the light. If you push the BH lever up and down the switch finger should also move up and down. If it stays down, the machine will not work and give a beeping sound. If the switch finger is stuck, push it up with the BH in top position. Hope this will help you
Oct 31, 2008 | Singer 7422
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
