Question about Whirlpool Dryers
Electric dyer no heat
Model # Wed5100VQ1 service # Mo4030788 was drying but took longer. Now it doesn't get hot at all. drum does work. vents are clean.
  • Whirlpool Master
  • 2,992 Answers
Online appliance parts sites have been helpful to me. They may help you diagnose the problem and recommend a repair part. It's their business.
Posted on Apr 01, 2015
Heat problem
Sound like thermostat is not working. Should turn off heating elements when drying temp. is reached.
Jan 20, 2014 | Bosch Nexxt WTMC 3300 Electric Dryer
Whirlpool WED5100VQ1 does not heat
Those fuses and thermostats can be checked for continuity with a multi meter. There are several other things that can cause a dryer not to heat. Heating element, burnt wires, improper voltage, inadequate venting, timer, and motor
Nov 03, 2017 | Whirlpool WED5100VQ Electric Dryer
The dryer is hot to the touch inside the drum
two issues the heat thermal relay or the fan motor quit working you can go to www.appliancepros.com and look up the parts list for your model.
Apr 14, 2010 | Amana DLE330RAW Electric Dryer
Dryer suddenly does not produce hot air
have the exact same problem, just over 1 year old no heat! first off my duct work under my floor is like a snake and is not a straight shot out of the house. I beleive this caused a ristriction in the venting because dyer seemed to be running hotter them normal. I took the top off the dryer and pulled the vent tube out of the bottom of the dryer. To my surprise found a three inch layer of lint on the bottom of the machine and also on the heating coil. After cleaning out all the lint i took a volt meter to the two wires that come down to the heater. started the dryer and found i had 220volts at the heater indicating the heater is out, found one on ebay for about 50 bucks. will be installing this weekend and will let you know how it works.
Mar 08, 2010 | Samsung DV218AEW Electric Dryer
Electric Whirpool Dryer doesn't stay hot
Check the vent for obstructions if all is clear do an ohm reading on your heating element. For video instructions go to www.appliancehelponline.com/servicemanual.html
Feb 26, 2010 | Whirlpool Dryers
It takes longer to dry your clothes you have to restart the drye
first clean the pip from the unit to the outsde vent.
then inside your unit there are 2 felts that need to be cahnge, over time they go bad and the heat run out the drum and you can feel the hood is hot but it still not to good . it will save you electric bill when you fix it. :)
Dec 31, 2009 | Whirlpool LER4634J Electric Dryer
My dyer heats and tumbles, but doesn't dry
I'd check first for clogged vent hose or clogged lint filter or clogged vent flap on wall (outside).
If that's not a problem, it may be a faulty thermostat. Heating element is probably okay if it heats some of the time.
More info, let me know.
Charlie
Oct 01, 2009 | Kenmore Dryers
LGE59777S Not drying
There is a little sensor that tells the dryer when to heat and when not to heat. that sensor is bad. If you take the back of the dryer off you will see it. It is about the size of a half dollar and has 2 wires that plug into it. While you have it apart make sure that the dryer vent on the back of the dryer is not plugged with lint. Major cause for fires in dryers.
Jan 04, 2009 | LG DLE5977 Electric Dryer
Whirlpool Electric Dyer Problem
most of the time the dryer vent hose,wall vent and dryer vent hole must be clear to allow the dryer to vent,also you can pull dryer hot put you hand on the dryer vent hole turn on and see if it is venting this will let you know if the blower wheel is turning, let me know what you find-mike
Sep 25, 2008 | Whirlpool Dryers
Bad heat in two year old GE DBXR463ED2WW electric dyer. Not as hot as used to be, takes longer to dry!
If you're experiencing a dryer that requires a longer time to dry, you may want to view this link:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Pay particular attention to the first major paragraph. I know the link is for a no heat problem, however, if you have a dryer that is starved for air, the heating circuits will eventually fail. In most cases, a no heat, or longer dry time problem is directly associated to clogged ventilation, kinked dryer vent hoses, improperly installed vent ducting, a clogged blower fan assembly, or rodents. Yes...the last one isn't always fun, but I have found bird nests, mice nests and even snakes inside dryer vents, clogging the air flow. The symptims were all the same - a dryer that would not dry properly. Before you assume you have a component going bad, take a good look at the way your dyrer is installed and inspect it thoroughly for what might be a good cleaning. The outsiode dryer vent should be at least 12 inches off the ground and a louver is recommended to cover the end to prevent critters from getting inside. In addtion, the SHORTER nd STRAIGHTER the dryer exhaust vent is, the better. If you have an exhaust vent with excessive bends, or excessive run length, this can contribute to poor heating of the dryer. Especially exhaust vents that run thorugh an attic or under a crawl space. They typcially develop sags, which create choke points where lint can accumulate to the point where it clogs. I do not know what your situation may be, but provide this as some helpful guidance just in case. I hope you find this information helpful. If you inspect your dyer and still have problems, please post back and let me know.
Sep 03, 2008 | GE Dryers
Dryers Logo
61 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
