Question about Whirlpool Washing Machines
Is there a way I can change the settings of Whirlpool Washer Model # CAE2743BQ, because this Machine has a very low level of water. Kindly teach us how to make the water plenty in the washer..
My business is Laundry Mat for 9 years already. Last year I purchased 12 pcs. of Washing Machine from Home Depot Guam. But we are disappointed, because the level of water of the Washing Machine is very low, which my customer's don't to comeback, because they want the old model. My question is, If we can, program again the unit, to make the water plenty.. Thank You..
  • Whirlpool Master
  • 2,963 Answers
If you do not have owner's manual, try manualslib.com Double check the method for setting water level (load size). There may be an "energy conservation or water conservation" mode.
I would also take the purchase receipt to Home Depot and ask for help. If it is all machines, there may be a factory defect. Hopefully, you are within the factory warranty time.
Posted on Apr 01, 2015
How do I change the rinse cycle on CAE2743BQ
They... SHOULD be somewhat wet, Donald This isn't a dryer, it's a commercial washer. After washing your clothing, you'll need to dry them.
Aug 03, 2014 | Whirlpool Washing Machines
How do I change the rinse cycle on CAE2743BQ?
They... SHOULD be somewhat wet. This isn't a dryer, it's a commercial washer. After washing your clothing, you'll need to dry them.
Whirlpool LBR5232EQ2 Overflows on Medium Water Level Setting
This is the landlords machine that does this? There is a problem inside the machine with the water level sensor.
Dec 16, 2013 | Whirlpool Washing Machines
Cae2743bq will not turn on all lights on and lid lock is lit up
Try this, worked for me! :)
New WHIRLPOOL Top Load Washer
Model #'s CAE2743BQ, CAE2763BQ
Cycle Selector Knob key dance: [CCW=Counter Clockwise and CW = Clockwise]
Start On "NORMAL"
1 step CCW (Left)
2 steps CW (Right, Right)
1 step CCW (Left)
1 step CW (Right)
Stay on "HEAVY DUTY"
(If unsuccessful LEDs will not flash, and you must return the selector to the Normal Cycle position and
wait 4-5 seconds before retrying. )
If you are successful in the process, all LEDs will be flashing
Toggle between HEAVY DUTY and NORMAL until ONLY the RINSE light is on, then press the
START button for about 30 seconds. Machine will then enter CALIBRATION mode for about 2 - 4
minutes. DO NOT RAISE THE LID
Sep 01, 2013 | Whirlpool Washing Machines
Whirlpool LF Error code
LF = Long Fill
LF flashes when the water level does not change for a period of time after the valves are turned on OR water has disengaged the basket but control does not detect a water level change.
Is water supply connected and turned on?
Are hose screens plugged?
Is water entering the tub? If so check pressure hose connection to machine/motor control.
Oct 19, 2012 | Whirlpool WTW6400SW Cabrio Washer
WHIRLPOOL DUET WASHER THE WASH LIGHT IS NOT LIGHTING UP WHEN WASHER IS STARTED AND THEN I GET "LF" CODE
Oct 12, 2012 | Whirlpool WFW9151YW Duet 3.5 cu. ft. Front...
Whirlpool fron loader washer leaks at the door
The water should be able to come up to the door level without leaking. Chances are you have build up on the bottom side of the glass on your door. If so take a razor blade and scrape the build up off. Your door will quit leaking.
Aug 12, 2017 | Whirlpool Duet GHW9150P Front Load Washer
What does the ''Reset'' position on the ''Load Size'' knob do?
if you have filled machine to say small water level and change your mind you turn to reset and then set your new level hope this helps
Nov 06, 2009 | Coffee Makers & Espresso Machines
Water level is low
This machine only sprays the water, you may never see the clothes completly covered with water it just sprays the water in intervals. You can download a user guide at whirlpool.com select owner center than literature in drop down menu, requires adobe. Hope this helps
Mar 19, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
101 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
