Question about Sony Televison & Video
My sony DVP-NS57P dvd is working perfectly but cant display the blue screen on my tv;i cant see the options on tv so i need a blind tour into the dvd's manual to put it back to normal;help!
  • Sony Master
  • 2,963 Answers
It may be as simple as disconnecting the DVD player from the TV
and unplugging TV for an hour to reset. If you can reach the menu after connecting, review the manual and DVD options.
Posted on Apr 01, 2015
SOURCE: How do I make my SONY DVP NS57P region free?
You need a palm pilot and then got to this website:
http://www.regionfreedvd.net/player/sony.html
Posted on Jan 23, 2008
SOURCE: Sony DVP-NS57P all region
try thomson
Posted on Feb 04, 2008
  • 3 Answers
SOURCE: unlock region code on Sony CD/DVD Player DVP-NS57P
I don't have a solution, but I know that the one about "press Display, Top Menu, Clear, Power" doesn't work.
Posted on Oct 12, 2008
Try this,
1) Plug the DVD Power Cord to the wall jack, but DO NOT Turn On the player;
2) With the Remote Control, press: Display, Top Menu, Clear and Power;
3) It will enter in the Service Mode;
4) Choose option 2 and then 4;
5) It will ask for an Input Code and Current Code (its 5 spaces), press 1245 and then Zero;
6) Leave all Zero erasing 1245, and on the bottom field all Zero too, then press Enter;
7) So the DVD Display will show a Zero (all Region-Free),     then press Power to Turn Off.
Posted on Dec 21, 2008
  • 5 Answers
SOURCE: Need to turn OFF progressive scan on Sony DVD DVP-NS57P
With the remote: While in STOP mode, press the DISPLAY button. Use up/down buttons to select SETUP. Press Enter. Use up/down buttons to select CUSTOM.Press Enter. Use up/down buttons to select SCREEN SETUP. Press Enter. Use up/down buttons to select PROGRESSIVE. Press Enter. The manual is a bit indistinct after this, but I think the prompts will direct you. Just turn Progressive OFF.
Owner's Manual page 61, link http://www.sonystyle.com/wcsstore/SonyStyleStorefrontAssetStore/pdf/DVPNS57P.pdf
Posted on May 19, 2010
How to Reset a sony dvd player parental Password? Model of DVD - DVP-NS57P
http://www.retrevo.com/support/Sony-DVP-NS57P-DVD-Players-manual/id/1075ci153/t/2/
copy and paste that link to be able to download the manual for the player.
May 03, 2011 | Sony DVP-NS57P
Why original DVDs appear in Black and white only when palyed on the Sony DVP-NS57P player?
Usually, when you get a black and white version of the film, either the cable connection is messed up or the dvd signal and the tuner are mismatched (say NTSC TV getting a PAL signal from the dvd).
The cable mismatch would be connecting composite video output (using the AV cable that came with the unit) to one of the three video jacks of the component video input on the TV. The obvious first thing to check is that the cables are good and in the correct configuration (yellow to yellow for composite or red, green and blue to red, green and blue). Try a new cable in case there is a damaged cable, particularly with a component video cable.
The tuner mismatch is more common with the handheld dvd players.
I hope this helps.
Jan 08, 2011 | Sony DVP-NS57P
I have a Sony DVP-NS57P and a Sony RMT-D175A remote. They have suddenly stopped communicating. I can put in a DVD and its program selections will display. However, I can't get the player to respond to...
there is a switch at the top to use controls from dvd , then tv, wtc. switch it over or call Sony and get a new one. Make sure the sensor on the unit is not blocked.
Jul 30, 2010 | Sony DVP-NS57P
Manuals for sony dvp-ns57p
please check the link below:
http://www.generalmanual.com/DVD-VCRs/Sony-DVP-NS57P-B-S-DVD-CD-Single-Disc-Player.htm
on the bottom of the page after the description, you will find the Owner Manual.
please check it, it should give you all the solutions you need.
thank you.
May 18, 2010 | Sony DVP-NS575P DVD Player
How to convert my dvd sony DVP-NS57P in multizone.
go into set up menu undet audio. you have to turn on the dolby digital and the dts. use a fiber optic or coaxial cable to enable
Jul 11, 2009 | Sony DVP-NS57P
SONY DVP-NS57P does not display video
If your TV has no input selector but has a video input, the TV probably "hides" the video input between the lowest channel on the tuner and the highest channel. That means if your tuner goes from channel 2 to channel 119, the video input will be between 119 and 2. The best way to see if this is the case is to slect channel 2 and then use the up/down channel selector to go down and see if you find the video input. Let me know if this works!
Nov 02, 2008 | Sony DVP-NS57P
Unlock region code on Sony CD/DVD Player DVP-NS57P
Sep 05, 2008 | Sony DVP-NS55P DVD Player
Buzz in Samsung Digital when DVP-NS57P Sony is played back?
Greetings,
Check the audio connection, the port on the TV might be grounded.
While playing, try moving the connection in the port.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jul 08, 2008 | Sony DVP-NS575P DVD Player
Try this,
Nov 18, 2007 | Sony DVP-NS57P
Televison & Video Logo
46 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
