Question about Pool & Spa
Why is my Wolf 1800w, 230v machine's motor running in reverse?
  • 2,992 Answers
Wired wrong. It should have a wiring diagram on the label. Or possibly on the back of the plate covering the wiring connections.
Otherwise Owner's manual, no manual, try manualslib.com
Posted on Apr 01, 2015
Everything works. But the fan runs all the time on or off. 25/7
Condenser Fan Motor Operation ' FAQ ' Sub-Zero and Wolf
www.subzero-wolf.com/.../condenser-fan-motor-operation
Sub?ZeroShould the condenser fan motor on a Sub-Zero run continuously? Why does the fanmotor run all the time? ... Refrigerator or Freezer Fan Switch Information.
Refrigerator Condenser Fan Is Always Running ' Home ...
homeguides.sfgate.com > Insurance & Inspections > Insurance Basics
Refrigerator motors sometimes need troubleshooting over time. ... If the fan isn't shutting off there could be several reasons. ... reason a condenser fan is continuallyrunning within a refrigerator is the thermostat. ... All Fields are required. Name.
Oct 30, 2015 | Refrigerators
Wolf 5000kva generator
Locate where the choke lever is for your generator (under the petrol tank), you ought to notice a star headed shaped screw connected to the governor shaft (if you bend and look closely further beyond the choke lever; still under the petrol tank) which is linked to the carburettor housing/assembly. You need to increase/turn clockwise (using a star screwdriver) on this screw.
Your generator engine sound will change/high a bit because the engine speed will increase.
Reconnect your 1800w chop saw (load) and see if your generator can "effortlessly" accommodate it without shutting down otherwise, increae the turns on this adjustment screw attached to the governor shaft till your generator operates/stabilizes with the load (1800w) connected
Oct 05, 2017 | Wolf Manufacturing Electrical Supplies
WIRING A COMPATIBLE POOL PUMP[MARATHON 1 H.P.230V
check for 230v not 110 (on line to ground). SO checking L1 and L2 should show 230 v if not you have a fault in the timer or the breaker is toast. depending on the timer you can clean the points
Jun 30, 2017 | Pool & Spa
I have applied 230V instead of 110V for the Bread Maker. The Transformer and Motor burnt. Where do I get Serviced. I am located in Bangalore, India
You can get them wound in any windiing shop that specialising in imported machines.
Both the transformer and the motor must be REDONE for 230V instead of the 110 in which case you will require another step down transformer.-- additional cost.
Get an estimate and warranty on the job before you can get the winding done, or else I recomment not to proceed because unless the person who winds do not do it technically well for 230V, the motor or transforemer will not last.
Check this out and decide.
Aug 27, 2010 | Sunbeam 5891 Bread Maker
I have a Area Lighting Research 24hr Time Clock Model # TC-104R on my pool My timer is advancing,(between the on & off time) but when it hits the "off" tripper it stops & does not advance, I can...
First this model is a 230V model I believe. That means the motor runs on 230V. IF it's working when it's "ON" then you probably have a line and load set of wires reversed. Look at your wiring diagram. I believe 1 and 3 are line and 2 and 4 are load. Since the timer motor is connected to term 1 and 3 it should receive power at all times. When the switches trip then 1 is connected to 2 and 3 is connected to 4. If I don't have the numbers right on your model, you can see the two small wires from the motor. These should both be Line on a 230V model.
Jul 02, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Need to reverse polarity
the two poles on this type of motor are for high and low voltage (series and parallel connection) there is no polarity on a.c.(alternating current) motors. if the motor is reversable (an option on some motors) then ther will be a terminal strip in the electrical connection box with jumpers usualy interchanging wires #5 AND #9
Sep 20, 2009 | Grinders
Have to change power input from 120V/60Hz to 230V/50Hz
ok " check the net for plug and power converters that plug in to
Singapore receptacle
Had a set for Europe worked great
Jan 22, 2008 | Miele CVA2660 Stainless Steel Coffee Maker
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
