Question about dealeurstore.com JXD661 2G 2.8 inch Mp4 player with Camera TV-IN and TV-OUT
My JXD is not opening on pressing the power button. However, it opens when connected to my computer but displays the USB symbol. Plz Helpp ????
My ipod is disabled
Plug the iPod USB cable into the bottom of your iPod. Plug the other end of the iPod USB cable into a free USB port on your Mac or PC. Open the iTunes application by using the dock icon on a Mac or the start menu on a PC. Click on the name of your iPod under the "Devices" list in the main iTunes window. Click on the "Sync" button to create a connection between the computer and the iPod. Click on the eject symbol after the syncing process is complete, and then unplug your iPod from the computer. The lock code has been reset; when you go to disable the iPod again, you will be prompted to choose a new four-digit code. hope this helps
Attach a USB connector to the iPod and plug it into a USB connection on a computer for power, or into a stand alone USB charger plugged into a power strip for electrical power. Pick up the iPod. Move the "Hold" switch at the top of the iPod to the "Locked" position so that an orange color appears by the switch. Return the switch to the "Unlocked" position. Repeat this process. Press and hold the "Home" button and the button at the top right corner together if using a fifth generation iPod, iPod Nano, iPod Mini or iPod with a click wheel. Press and hold the "Menu" button and the "Play/Pause" button together if using an iPod Touch. Press and hold the "Menu" button and the "OK" button together if using an older iPod. Continue holding the buttons together until the screen flashes and then displays the iPod name and the Apple logo. Release the buttons. Wait as the iPod resets itself and turns itself back on. Leave the iPod connected to the USB connector so that it can fully charge the battery. Remove the iPod from the USB connector. Navigate to a song using the menu selection and play some music
Mar 01, 2013 | Apple Audio Players & Recorders
Ipod is disabled
or
hope this helps
Sep 15, 2012 | Computers & Internet
I had jxd in it songs are not playing i copied songs in jxd in audio file songs r appearing in jxd but not playing i pressed play button "file type error" coming why
MP3 players can only play music files in mp3 file format. You can download mp3 music files from the Internet to your computer and then copy them to your MP3 player using the USB cable. For your CD collection, you need to convert your CDs to mp3 music files onto your computer or download them from the Internet and then copy them to your MP3 player after you have connected the USB cable to the MP3 player and the computer.
You can do this using Windows Media player and Rip the CDs - Media Player will create a MP3 music file for each music track. Click on this link for instruction on converting music files to mp3 file format :- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Aug 23, 2012 | Acer Audio Players & Recorders
Hi I"m Sunny.., I"ve a
maybe it was corrupted? try to connect it to your pc.. try to open those files.. if the file was opened , your mp4 hardware was broken.
Feb 07, 2011 | Computers & Internet
Sir, I Have JXD 656 recently I connected it to my
WARNING : This procedure can render your device dead, so do not try if your player is working fine.
  1. The most important step of the whole process is to correctly identify your device CONTROL CHIP and CPU, using wrong firmware or flashing tool may cause damage to your device, unscrew and open your device and write down all chip id's and motherboard numbers you see, you can also try the EasyChips - firmware identification utility but it did not worked for me.
  • You will now need to download the correct firmware and flashing utility for your device, visit sites below and search for your control chip and cpu to download the firmware and flashing utility, you can also post on user-forums to get help identifying the firmware :
  • In my case the chipset was Sunplus AJ262-V7 and the utility needed to flash it was FRM Pro.
  • Once identified you need to connect your device to computer via USB in camera mode (Press A + OK button and plugin USB cord on player), for Windows to identify this mode you will need camera drivers you need to point Windows Found New Hardware Wizard to Driver folder downloaded with the FRM Pro utility above, this will install the first camera driver, for correct identification by flashing utility you need to install a second camera driver - open Windows Hardware Manager and install unidentified camera device drivers by pointing the driver wizard to Driver folder used earlier.
  • Now install and launch FSM Pro flashing utility the new firmware.
  • Jan 13, 2011 | Audio Players & Recorders
    How do i put the heart symbol on my display name? not the one thats already there, but the black one. PLEASEEEE HELPP!!
    Open start menu>run. type in "charmap" then press enter. this is the system font mapper. provides all symbols. pretty cool, huh?
    alternatively copy this- ♥
    Jun 04, 2009 | Cingular Wireless AT&T RIM BLACKBERRY BES...
    Helpp! exceeded the power limits on its hub port?
    try to change a new USB cord, and if it does not work the problem is a device then
    Jun 21, 2008 | Vivitar MAGNACAM Binocular
    The 3 yellow lights are blinking and cannot be shut off.error:oxd0840001 isdisplayed.
    Solution Use the instructions below to resolve the issue by restarting the product.
    1. Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
    2. Open the cover of the product and remove the print cartridges.
    3. Close the cover and wait for the Insert Ink Cartridges message to display.
    4. Disconnect the power cord from the back of the product and wait for one minute.
    5. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
    6. Open the cover and reinsert the print cartridges.
    7. Close the cover. If prompted, print a calibration page.
    8. Reconnect the USB cable, and try to print a print job from the computer.
    If these steps did not resolve the issue, contact HP technical support for assistance.
    Apr 19, 2008 | Office Equipment & Supplies
    Jxd i pod not working
    "If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
    Q. How to reset Zen v +
    http://www.youtube.com/watch?v=22T_gkkZjmM&feature=related
    Jan 30, 2008 | Creative Labs Zen Micro MP3 Player
    dealeurstore.com JXD661 2G 2.8 inch Mp4 player with Camera TV-IN and TV-OUT Logo
    112 people viewed this question
    Top dealeurstore.com Cameras Experts
    Are you a dealeurstore.com Camera Expert? Answer questions, earn points and help others
