Question about Canine Carry Outs 25 oz. Bacon-Flavored Soft & Chewy Dog Snacks
Does it contain antifreeze? - Canine Carry Outs 25 oz. Bacon-Flavored Soft & Chewy Dog Snacks
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 114 Answers
Here is a little info on t how at:
Avoid pet food with potentially toxic ingredients www.feedingfidoandfluffy.com/pet-food-is-no-place-for-cancer-causing-to...Jul 18, 2013 - Artificial preservatives, colors and flavorings do not belong in pet food. ... Manypet treats sold in grocery stores, discount stores and major pet stores contain ... Several well-known pet foods contain propylene glycol. ... Milk-Bone Soft & Chewy Chicken Recipe®, and Pup-Peroni Original Beef Recipe®Treats.
Posted on Apr 01, 2015
How to add antifreeze 2002 dodge intrepid
Open the container of antifreeze. Using a separate EMPTY gallon-size container, pour out HALF of the contents into the empty container, making sure not to spill any. Now, FILL the newly filled container with tap water. Fill the rest of the antifreeze with water, also. Now, you are ready to add antifreeze to your vehicle! Simply locate the radiator cap, (Don't touch it if it's hot!!) and unscrew it. Pour the desired amount of your mixed antifreeze into the radiator. Remember not to do this without proper knowledge!
Jun 26, 2016 | Dodge Cars & Trucks
How to check for leaks of antifreeze/in 97 expedition smell of antifreeze
Hi Sharlene,so you smell antifreeze.Raise your hood and check your antifreeze over flow container,you should have a l and a h mark on it,high and low.If low,then it's leaking somewhere,look at the radiator cap and overflow hose for leak,look at over flow container for leak from hose going to it from radiator,look all over engine,look at top and bottom radiator hoses and clamps for leaks,if leaking there,tighten clamp with flat head screw driver,if no leak is found,get under vehicle and see if any antifreeze is visible,maybe water pump,look on ground for leak and follow,check floor board on driver side,heater core could be bad,check hoses going to heater core from engine firewall.
Nov 05, 2012 | 2003 Ford Expedition
Oil in antifreeze container
Antifreeze in the oil is a sign of a blown head gasket but oil in the antifreeze reservoir could simply be an Id10t error. (a user mistake).
Sep 19, 2012 | 2004 Chevrolet Cavalier
What type of antifreeze can I use for my ninja 250 r it's a 94
Use any motorcycle brand, GM Dexcool, or non-silica style antifreeze. 50/50 is usually the desired blend of antifreeze and distilled water. You want to a purchase any antifreeze that does not have rust scrubbing particles in it. The rust scrubbing particles that are contained in automotive antifreeze can damage the ceramic washer used in most motorcycle water pumps causing them to drip. Hope this helps.
Sep 05, 2011 | 2008 kawasaki Ninja 250R
Where do you check the transmission fluid?
PERFORM AN ELIMINATION OF ENGINE FLIUD CONTAINERS TO ACQUIRE THE TRANSMISION CHAMBER
The vehicle should only have an engine oil compartment, radiation compartment for antifreeze/ water, power steering fliuds, a water wiper blade spray dispenser compartment, and finally the transmittion fliud container area all situted within the engine entrapment area. Usually, opening the engine for the first time would require observing the fliud compartments that are identifyable from the remaining engine chambers. Observing closely on the fliud container should have written descriptions of what is expected within compartment. For example, the water fliud containers for wiper blades would usually have written lables as wiper blade fliud container, radiantion container would usually have the antifreeze demarkation logos visibly observable when engine is opened. Rely by elimination methods to ascertain the transmission fliud compartment. For example, once antifreze container, wiper water container, engine oild container, power steering fliud containers have been identified, the most like only remaining in the engine would be the transmition fliud compartment. Alternately, every fliud container within the vehicle engine is situated at separate areas. For example, the only fliud container closest to the transmittion chamber is the engine oil compartment. The vehicles usually require more engine oil than transmission fliud. Between both fliud containers, the smallest chamber for fliud oil is usually for transmission perposes in the absence of hydraulic fliud compartments with newer vehicles.
Jan 22, 2011 | 2000 Oldsmobile Alero
How much antifreeze to add to an emty raterator and over flow tank for a 96 toyota corolla
The best method is to fill the radiator up with a mixture of antifreeze and water. The mixture details should be on the antifreeze container. Once the radiator is full let the car run until the thermostat opens up and you should see the level of fluid go down in the radiator. Fill the radiator again while the thermostat is opened. Then add fluid to the overflow tank to the fill line. That should do it. If you have put in too much it will run into the overflow container when it is not needed in the car.
Jul 24, 2010 | 1996 Toyota Corolla
Where is radiator to put Antifreeze
ask a dealer or a parts store ...
Dec 10, 2009 | 2001 Daewoo Nubira
Antifreeze appears to leak everytime I turn on the
it is most likely not antifreeze, but just condensation dripping from the HVAC drain. it is normal and unless it contains orange dex-cool coolant, is not a problem.
Aug 02, 2009 | 2006 Chevrolet Impala
Mixing engine coolants?
toyota did some good research years ago .. they found that anti freeze that contain silicates caused excessive wear in the water pump seals .. most antifreeze at that time contained silicates .. so toyota developed their own type .. and they charged a lot for it .. it was red in color .. it was designed to last a long time and cut seal wear to a minimum (no silicates) .. so it was a good idea to use their super antifreeze .. now almost all antifreeze can mix with other types but do you reallly want to contaminate the expensive stuff already in your car with something that might contain silicates .. in this case toyota has a good reason for recommending certain types of antifreeze .. of course they used to recommend only their own brand but i hope that has changed .. i would use only long life antifreeze that is recommended by toyota or that states "contains no silicates" .. even buying their expensive stuff isnt so bad since it lasts so long and the echo uses so little. .. i am not sure what the new long life antifreeze contains ... did they ever address that problem ?..
May 29, 2009 | 2005 Toyota ECHO
1993 Mazda Protege Checking the Antifreeze
Right side next to battery you'll find the antifreeze cap on a clear plastic container. The container has fluid level markings, so you'll know how much to put in. Paul
Dec 12, 2008 | 1993 Mazda Protege
Canine Carry Outs 25 oz. Bacon-Flavored Soft & Chewy Dog Snacks Logo
585 people viewed this question
Top Canine Carry Outs Dogs Experts
Ruth summersides
Thomas Perkins
Thomas Perkins
mpr9798
Level 1 Expert
Are you a Canine Carry Outs Dog Expert? Answer questions, earn points and help others
