Question about Singer Sewing Machines
Needle wont go up and down it only goes down and up once, i have to turn the handweel counterclockwise for it to move again than the needle lags at the top. singer 2273 its new just out of the box
  • Singer Master
  • 12,029 Answers
If the bobbin winder is not the problem (as Jimmie suggested), you might want to take it back to where you purchased it. May be defective.
Posted on Apr 02, 2015
  • Singer Master
  • 662 Answers
I believe that your bobbin winder is on. It needs to be pushed to the left.
Posted on Apr 01, 2015
bargainbox
  • 1388 Answers
SOURCE: janome 5700 handwheel stuck/inside pulley stuck
The error message relates to the motor sensing that it is working unusually hard.........the extra strain will have a physical cause, generally in the hook and bobbin region.......something blocking or slowing things down, so.......
Remove needleplate and bobbin case.
You will probably find an accumulation of lint in and around this area, also possibly in the feeddog channels.
Use a small brush and vacuum with crevice tool to remove the lint and wipe the hookrace with a tissue moistened with methylated (denatured) spirit to remove any dirt deposits.
Also check that the bobbin case is not damaged on the top surface by needle strikes or on the underside rim by the hook gouging as it spins.
If damage is present but mild, you can use very fine emery paper to smooth surface, if more severe, replace the bobbin case. Don't forget to change needles regularly too.
Best of ......
 www.bargainbox.com.au
Posted on Nov 21, 2008
SOURCE: singer 2662 only does a straight stitch
got the same problem - wish I could help you -
Posted on Jan 13, 2010
  • 68 Answers
SOURCE: I have a Singer Confidence 7469. It has only been
The bobbin case is not supposed to move. It should only have a little bit of wiggle room so there is enough clearence for the thread.
Posted on Feb 25, 2010
llsilvermerm
SOURCE: Just purchased the Singer Quantum Stylist 9960,
When you pull the needle threader down it seems like it is pulled all the way down but it isn't. Pull it a little harder and it will turn and go down all the way to match up with the needle eye. I was a little scared to apply the extra "force", thinking I could break my new machine. Just be easy with it and it will work just like the manual says.
Good luck....
Posted on Oct 05, 2012
SOURCE: singer 2263 needle hitting something in bobbin area (loud thunk) and needle moves
try taking the bobbin out and putting it back in the bobbin
case if it's a top loading bobbin
if it's a side or front loading bobbin make sure the bobbin case is
inserted correctly
if the bobbin and bobbin case are inserted correctly then
it sounds like the sewing machine could have a timing
problem and needs to be checked at a sewing machine shop
Posted on Nov 13, 2012
My needle wont go all the way down
check to see if the needle is bent or if you have it in back words take the needle out and make sure the arm goes all the way down when you turn it by hand if not take the bobbin out then try again if it goes down there be something wrong with the bobbin good luck
Jun 05, 2016 | Sewing Machines
The screw on the needle bar is broken can't get the needle out the screw broke flush to the needle bar . what do I do.
hi
it's easy don't worry about that , just try to move needle to left and right before start to remove broken scrw, you can catch needle by and spanner. second after removed needle by pull it down ( it's not so easy to remove but try also by spanner. just bring any needle with thick size ( 18 or 23 ) and try slowly move the broken scrw to counterclockwise direction . it will takes long time but at final broken scrw will out of needle bar.
best regards
ASHRAF ABOZID
CAIRO - EGYPT
aabozid@hotmail.com
May 22, 2015 | Juki DDL-8700
Bernina 180 needle bar won't move up and down
This could be the needle bar clutch. Turn off machine. Unplug machine. Remove needle. Turn hand wheel in normal rotation 1/4 turn. Gently move needle bar up and down by hand you should feel a click and the needle bar will not move up and down easily now. Restart machine and test. If it works all is good. This is a result of the machine requiring professional attention. If you use basting stitches it will likely unclutch again.
Jun 15, 2014 | Bernina Sewing Machines
Empisal dressmaker 270d
Loosen your needle. Turn your handle towards you. You may have to turn a little hard. Now, throw that needle away.Take your fabric away and check the area where your bobbin goes and clean it out of fabric and thread. Now load your bobbin again and load a new needle. Pull your thread up from the bottom by turning the handle towards you while holding the needle thread with the foot down. Now look and place something under the foot and slide it forward while still holding the needle thread. The bobbin thread should come up. Let me tell you this though. Adjust the bobbin thread before you start. This is done by placing the thread in the carrier (usually unwinding counterclockwise) and place the thread under the tension spring. Hang this from your finger and bob it up and down lightly. It should fall about one inch. If it doesn't then loosen. If it falls too far then tighten.
Apr 27, 2014 | Sewing Machines
My Designer 1 sewing machine runs great, but it sound terrible. It always sounds like rattling from the bobbin area. What can be done? I take it for cleans and mention this, but nothing changes.
When the needle moves down, is it striking the edge of the needle plate? If so, adjustment is needed. Take the various parts of the bobbin assembly out of the machine and use the handwheel to move the needle in the downward direction (turn the handwheel counterclockwise). Is the needle striking the "hook" in its downward most position? If so, this is most likely what's making the noise and it needs adjustment.
Mar 24, 2013 | Husqvarna Designer I
My janome 11000 memorycraft's needle threader has jammed in the down position and cannot be moved
Thanks to floraq803, we have our 11000 working again. The needle threader was stuck in the down position. We turned off the machine, and turned the wheel (which controls where the needle is) until the needle threader bar was straight (approximately 1/2 way between the needle being all the way down and all the way up). Turned on the machine and the threader came back up again. Now back to sewing.
Jan 20, 2013 | Janome Memory Craft 9000 Computerized...
Fixing a new needle on a sewing machine
Turn the hand-wheel counterclockwise until the needle is at the highest point. Lower the guide or presser foot. This will give the maximum room possible for working with the needle.
Turn the needle clamp screw counterclockwise until the needle comes loose. This screw is located on the side of the small
box, known as the needle clamp, that holds the needle in place.
Remove the old needle by pulling it straight down and then angling it outward. Place a new needle into the holding slot or needle clamp.
Tighten the new needle into place by turning the clamp screw clockwise until tight. Do not over-tighten the needle.
Here's a tip
Use a needle that is appropriate for the type of fabric you are sewing. Using the wrong needle may result in breakage and increase the number of needles to be changed
Over-tightening a needle can cause it to be crooked and break. Turn the clamp screw only until the needle feels stiff in place.
Aug 23, 2012 | Euro-Pro Shark 9110 Sewing Machine
The needle on my model 1315 Kenmore sewing machine wont go up and down.
try turning the bobbin in the opposite direction & see if that helps
Jul 30, 2012 | Kenmore Sewing Machines
Janome 5700 handwheel stuck/inside pulley stuck
Best of ......
Nov 04, 2008 | Janome Memory Craft 5700
Needle Keeps Moving While Sewing and Bobbin Wont Thread
Hi Nikki,
The problem seems to be of the needles alignment. If you are using a half bobbin type (D type) needle, makes sure you have used the proper number & size and also fastened it well so that the flat side is firmly fixed/clasping the inner side of the needle hold. That black thing which I feel is the fly-nut that helps you tighten/clamp the needle to its hold. Then after having done that, slowly turn the wheel manually to see whether the needle is going in thru the hole in a straight line and if you can, look underneath to se if the knotter ring (the one that looks like having fangs) comes close as the neele advances inward. All these movements HAVE TO BE syncronised. Only then you will be able to stitch the fines of fabrics speedily. Also make sure oyu are not tugging on the front end of the fabric too hard as this may cause the needle to go in a diagonal manner thus causing it to snap. Take care as to NOT to be too close to the needle while at high speeds. The snapping pieces can fly right into your eyes/nose causing serious injury.
Hope that does it Nikki...
May 06, 2008 | Bernina Virtuosa 150
Sewing Machines Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
