Question about Panasonic Sa-pt760/sc-pt760/sa-pt960/sa-pt-660 6.1ch 1250w 5 Disk Dvd Receiver
I can't turn on the product - Panasonic Sa-pt760/sc-pt760/sa-pt960/sa-pt-660 6.1ch 1250w 5 Disk Dvd Receiver
  • Anonymous Apr 06, 2015
    it's very simple i can't turn on the system
    Champion:
  • 208 Answers
Always splash plenty of details in your question if you want good answers... I do not have a single clue what it is you want or need or even what item you are struggling with! Details are your friend. Good luck.
Posted on Apr 06, 2015
Error code 54.1103
Code Display 54.XX Error Turn off then on Description The product has experienced an error with one of the internal sensors. Remedy Turn the product power off, wait at least 30 seconds, and then turn the product power on and wait for it to initialize. If you are using a surge protector, remove it. Plug the product directly into the wall socket. Turn the product power on.
May 11, 2015 | HP Color Laserjet M451dw Printer
My printer hp laser pro 400 show message 50.3 fuser error
hello ,,
50.x Fuser Error
Description
The product has experienced an error with the fuser.
Recommended action
Turn off the product, wait at least 25 minutes, and then turn on the product.
If the message persists, contact HP support.
Oct 21, 2013 | HP LaserJet Pro 400 M401DN Laser Printer
HP DeskJet 3745 Printer , My Printer Cant Turn ON , Tested PW Adapter OK , How To FIx It .....Help Me!!!
Some products require time to turn on. These products might or might not give feedback in the form of blinking light(s). Wait a minute for the power light to turn on before proceeding to the solution.If your product does not respond when you try to print, press any button on the product to wake it from power save mode. Wait for the product to initialize, and then try to print again.
Try the following solutions in the order presented to resolve the issue. When one of the solutions resolves the issue, there is no need to continue troubleshooting.Solution one: Press and quickly release the Power button Press and quickly release the Power button (c01602202.gif ) to start a Power On/Off cycle. Do not hold down the button Figure 1: Press and quickly release the Power button If you press and hold the Power button too long, the product might turn on and then off without restarting. If this happens, press and quickly release the Power button (c01602202.gif ) again.If these steps resolved the issue , you do not need to continue troubleshooting.If the issue persists , continue to the next solution Solution two: Check the electrical connections and outlet Unplug the power cord from the electrical outlet, or the power strip or surge suppressor Carefully inspect the power cord for visible damage.If the power cord or power module shows any damage, contact HP to replace the power supply. Disconnect the power supply from the rear of the product.Wait at least 30 seconds, and then plug the disconnected power supply into an electrical outlet. Do not use a power strip or surge suppressor.If the green light (LED) on the power supply does not light up, contact HP to replace the power supply.Reconnect the power module to the product. Press and quickly release the Power button (c01602202.gif ) to turn the product on.If the product still does not turn on, connect the product to an electrical outlet in another room, and then quickly press and release the Power button (c01602202.gif ) to turn the product on.If the product turns on , the electrical outlet in the original room caused the issue.If the product still does not turn on , continue with the next solution.Solution three: Check the USB cable Disconnect the USB cable from the rear of the product.Figure 2: Disconnect the USB cable from the HP product Press the Power button (c01602202.gif ) to turn on the product.If the product turns on with the USB cable disconnected , replace the USB cable If the product still does not turn on , continue to the next solution.Solution four: Check the battery If your HP product has a battery, follow these steps:Check the battery light. If the light is red,recharge the battery.If the battery light is still red after recharge, replace the battery.Figure 3: Removing a battery (example only) 1 - Slide the battery release slider in the direction of the arrow 2 - Remove the battery Instructions for recharging and replacing a battery are available on the HP Web site.Solution five: Replace the power supply If you have completed all of the troubleshooting steps and are still experiencing a problem, contact HP to replace the power supply for your product Solution six: Service the product If you have completed all the preceding steps and are still experiencing a problem, service the product
Oct 03, 2011 | HP DeskJet 3745 Printer
The reset power flasher is continually on! How do I remove? Dean
Issue All lights on the product control panel flash and a 'Reset Power ' message displays on the product control panel. Solution one: Turn the product off and then on Follow these steps in the order presented to turn the product off, and then on again. Step one: Turn the product off and then on
  1. Press the Power button (c01602202.gif ) to turn off the product.
  2. Wait 15 seconds.
  3. Press the Power button (c01602202.gif ) to turn on the product.
Step two: Print a self-test report
  1. Load clean, unused, plain white paper into the input tray.
  2. Press the Setup button.
  3. Press the Right Arrow button (c01185072.jpg ) to select Print Report , and then press OK .
  4. Press the Right Arrow button (c01185072.jpg ) to select Self-test Report , and then press OK . The self-test report prints.
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , continue to the next solution.
Solution two: Reset the product Follow these steps in the order presented to reset the product. Step one: Reset the product
  1. Press the Power button (c01602202.gif ) to turn on the product.
  2. With the product turned on , disconnect the power cord from the rear of the product.
  3. Unplug the power cord from the wall outlet.
  4. Wait at least 15 seconds.
  5. Plug the power cord back into the wall outlet.
  6. Reconnect the power cord to the rear of the product.
  7. If the product does not turn on by itself, press the Power button (c01602202.gif ) to turn it on.
  2. Press the Setup button (? ).
  3. Press the Right Arrow button (c01185072.jpg ) to select Print Report , and then press OK . The Print Report menu displays.
Solution three: Service the product If you have completed all the preceding steps and are still experiencing a problem, service the product. Determine if your product is in warranty or out of warranty. If you need help determining your product's warranty status, go to HP's Warranty Check Tool .
Aug 16, 2011 | HP Officejet 6310 All-In-One InkJet...
My printers ink clogs and wont print
Reset the product
Jul 06, 2011 | HP Officejet 6500 Wireless All-in-One...
Tengo una impresora Laser Color CP1215, cuando trato de imprimir me tira un error de Error de Fusor.. Necesito saber porque me da ese error..
Try this:
it to initialize.
product.
Mar 30, 2011 | HP LaserJet CP1215 Color Printer
Hp officejet 6500 all lights are flashing and mechine says turn off and on . Please can someone Help??
: Check the power cord
1.
Turn on the product.
2.
Remove the power cord from the back of the product.
3.
Check the power cord for any physical damage. If the power cord is damaged, replace the power cord.
Turn the product off and then on again
1.
Press the Power button ( ) to turn the product off.
2.
Wait 60 seconds, and then press the Power button ( ) to turn the product back on.
3.
If the product does not turn off when the Power button ( ) is pressed, wait three minutes, and then proceed to the next solution.
Plug the product into a wall outlet
Follow these steps to make sure the product is plugged in correctly.
1.
Unplug the power cord from the back of the product.
2.
Unplug the power cord from any surge protectors or power strips.
3.
Select a wall outlet to plug the product into. Test the wall outlet by plugging another electric appliance, such as a lamp, into the wall outlet and turning it on. Unplug the test appliance.
4.
Plug the power cord into the back of the product.
5.
Plug the power cord into the wall outlet.
6.
Press the Power button ( ) to turn the product on.
Solution six: Reset the product
Follow these steps to reset the printer.
1.
2.
3.
Wait 10 seconds, and then plug the power cord back into the wall outlet.
4.
NOTE: Many power cords have an LED light on the power module or on the end of the cord that plugs into the product. Make sure the LED light is lit and steady.
5.
6. Perform a partial reset of the product
  1. Disconnect the power cord from the product.
  2. Wait for 20 seconds.
  3. Press and hold # and 3 while reconnecting the power cord.
  4. When the product turns on, release both buttons.
  5. Try printing again.
IF still won't resolve it by following steps mentioned above then your printer needs replacement. Malfunctioning hardware.
Mar 28, 2011 | HP Officejet 6500 Wireless All-in-One...
PRINTER SHUTS OFF BY ITSELF HAVE TO UNPLUG IT BEFORE YU CAN PRINT AGAIN
http://search.hp.com/query.html?charset=iso-8859-1&lk=1&la=en&nh=10&st=1&rf=0&qs=&tridion=0&hpvc=sitewide&uf=1&qt=Officejet+8500
Issue The HP product repeatedly turns off. hpweb_1-2_plus.gifhpweb_1-2_minus.gif Cause When low-power problems exist, the product might turn off repeatedly. Low power is a common problem in many home offices because of the number of electronic devices concentrated in one area. Solution one: Press and quickly release the Power button Follow these steps to turn on the product correctly.
  1. Remove any memory cards or USB drives from the HP product.
  2. Press, and then quickly release the Power button (c01602202.gif ) to start a Power On/Off cycle. Do not hold down the button . Figure 1: Press and quickly release the Power buttonc01941590.gif
c01733891.gif If you press and hold the Power button too long, the product might turn on and then turn off without restarting. The product might also appear to be turned off in Powersave mode. In either case, press, and then quickly release the Power button (c01602202.gif ) to turn on the product. Solution two: Check the electrical connections and outlet Follow these steps to make sure that all the power systems work correctly.
  1. Unplug the power cord from the electrical outlet, or the power strip or surge suppressor. Power module Power cord c00745315.gif c00057913.jpg NOTE: The power cord detaches from the power module. The term power supply refers to both the power module and the power cord.
  2. Carefully inspect the power supply for visible damage. c01733891.gif If the power cord or power module shows any damage, contact HP to replace the power supply.
  3. Disconnect the power supply from the back of the product.
  4. Wait at least 30 seconds, and then plug the disconnected power supply into an electrical outlet. Do not use a power strip or surge suppressor. c01733891.gif If the green light (LED) on the power supply does not light up, contact HP to replace the power supply.
  5. Reconnect the power supply to the product.
  6. Press and quickly release the Power button (c01602202.gif ) to turn on the product.
  7. If the product still does not turn on, connect the product to an electrical outlet in another room, and then quickly press and release the Power button (c01602202.gif ) to turn on the product.
    • If the product turns on , the electrical outlet in the original room caused the issue.
    • If the product still does not turn on , continue with the next solution.
Solution three: Make sure that other devices are not causing the issue Follow these steps to make sure that devices plugged into the HP product are not causing the problem
  1. If the parallel and universal serial bus (USB) ports of the HP product have other devices plugged into them, unplug those devices.
  2. Press the Power button (c00636182.gif ) to turn on the HP product.
  3. Monitor the HP product to see if it turns off again.
  • If these steps resolved the issue , there is no need to continue troubleshooting.
  • If the issue persists , see the next step.
Solution four: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
Jan 19, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Photosmart c6180 repeatedly turns off about every 10 seconds
  2. Press, and then quickly release the Power button (c01602202.gif ) to start a Power On/Off cycle. Do not hold down the button . Figure 1: Press and quickly release the Power button c01941590.gif Illustration of pressing and releasing the power button
  1. Unplug the power cord from the electrical outlet, or the power strip or surge suppressor. Power module Power cord c00745315.gif Illustration: Power module c00057913.jpg Illustration: Power cord
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 21, 2010 | HP Photosmart C6180 All-In-One InkJet...
Panasonic Sa-pt760/sc-pt760/sa-pt960/sa-pt-660 6.1ch 1250w 5 Disk Dvd Receiver Logo
296 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
