Question about Whirlpool Whirpool 26 cu. ft. French Door Refrigerator w/ MicroEdge Shelves -
Ice maker not working on a whirlpool french door fridge
  • Whirlpool Master
  • 2,963 Answers
Is the cold water dispenser working? If not, does the filter need to be changed? Do you actually have water supply to the fridge?
Is the Ice bin empty? Is this your fridge, or are you renting and this was in place? If yours, do you have an Owner's manual with the troubleshooting tips? No manual, try manualslib.com Make model possibly year and serial number. If not yours, there should be a switch that turns the Icemaker on or off. A green light on the front of the drive mechanism near this switch should mean it does have power. No light, no power. There should be a mechanical switch that stops the Ice maker. If the bin is empty, the ice detection arm should be down If it is not down, It is stuck in the "bin is full" position. If these are not the problem, It may be the electrical valve for the Icemaker water supply is not operating, or has been disconnected, or is bad. I have found that one of the online "appliance parts store or sites" have been quite helpful in diagnosing problems and recommending parts and how to fix.
Posted on Apr 01, 2015
Trouble shooting LG french door ice dispenser
LG French Door Refrigerator - In Door Ice Maker Troubleshoot
? 4:41
https://www.youtube.com/watch?v=rA1DhfTwuwM
Feb 4, 2013 - Uploaded by ExperienceLG
Ice makers are great, but not if it means you can't fit all of your food in the fridge. The Slim SpacePlus Ice ...
LG fridge ice maker troubleshoot/ repair. How to fix ice ...
? 8:06
https://www.youtube.com/watch?v=arJpFgMnvPY
May 19, 2013 - Uploaded by spartacus1234567890
The ice maker quit working in my LG refrigerator so I decided to take it apart ... LG French Door Refrigerator - In Door Ice Maker Troubleshoot ...
LG Refrigerator Ice Maker Not Working - Model LFX25960ST
www.repairclinic.com/RepairHelp/...Fix...-/LG-Refrigerator-ice-maker-n...
LG Refrigerator Ice Maker Not Working. LFX25960ST. The part(s) or condition(s) listed below for the symptom Refrigerator ice maker not working are ordered ...
Jan 05, 2016 | LG LMX28988ST Refrigeration : Refrigerator...
I have a whirlpool WRF736SDAM11 french door fridge. I've changed the icemaker per a repairman, but I still have no ice.
if water is dispening and you replaced the ice maker, the most probable cause is a bad water valve. The valve has two outlets, one for the water and one for the ice maker; it appears that you ice side is not working as it is not likely to be from the Ice Maker
good luck
Oct 02, 2015 | Whirlpool Refrigerators
Ice Maker bar won't come down
I have not worked on this model before but on the whirlpool they have a bar as well. you can turn off ice maker by pushing it up and it locks in place to stop ice production. if u want it to make ice u push it up slightly and it should move down. also check the ice maker tray to be sure u are getting water to the tray. if u get the bar to go down and no water comes in then check that u have water at the back of fridge.. if u have water there but not in the tray then you may have a bad water inlet valve on back of fridge.
Apr 15, 2014 | Maytag MFX2570AEM French Door Freestanding...
Ice maker not working just changed the filter water works but ice maker not working
Check the plastic lever on the door. It usually moves closed when the door is shut to turn ice maker on. The lever can freeze and stop the ice maker.
Sep 23, 2013 | Whirlpool Gold GI6FARXXF 25.5 cu. ft....
I don know how to turn on the ice maker of a french four door refrigerator
water line hooked up,open door to ice maker check to see ice maker metal arm where cubes fall down from is in the down position,,when its in the up position it stops making ice,no water coming inalso u can change water filter in fridge this way too,it will not let water in until arm is back down
Aug 07, 2013 | Whirlpool Whirpool 26 cu. ft. French Door...
Ice maker quit working
Its either your icemaker or your inlet valve behind access panel behind fridge. Change the inlet valve first. Rate me if I am correct. Good luck!
Aug 26, 2010 | Whirlpool GX5FHTXVA Bottom Freezer French...
Ice maker not working. Fridge keeps beeping when opened
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
hlk;;lhk
Jan 31, 2010 | Fisher and Paykel RF201ADUX Bottom Freezer...
go back to your sales people this is under warranty and it's propably a system problem . don't void warranty . // hold on i thought the sysem had failed . ice maker must be 15 deg or lower . to work ... close the drawer and give it 24 and see what it will do . but it is still under mfg warranty . **** ..
Jan 05, 2010 | Samsung RF265AA Bottom Freezer French Door...
Ice Cube Maker
Here is a link for the srevice manual ( section 7 discusses how to troubleshoot an ice maker ) that should get you going..
http://136.166.4.200/contents/Fridge/LFX25960/LFX25960_Service_Manual.pdf
Hope this helps you...
Sep 14, 2008 | LG LFX25960ST Stainless Steel French Door...
Whirlpool Whirpool 26 cu. ft. French Door Refrigerator w/ MicroEdge Shelves - Logo
151 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
