Question about Life Fitness 9500HR Next Generation Remanufactured Treadmill
MOTOR CONTROLLER COMM ERROR BAD ERROR9 ON LED3
AFTER REPLACING THE WHITE CHIP ON THE BOARD AND PUT THE BOARD BACK IN PLACE I GOT AN ERROR 9 MESSAGE ON THE LED 3 ON THE BOARD. WHAT SHOULD I DO NEXT?
bwinton
  • 83 Answers
SOURCE: error message notify maintennce motor
Every time I have gotten this message, I have had to replace the motor controller.
Posted on Mar 24, 2010
SOURCE: notify maintenance motor controller comm
I own a gym and have 5 9500's...unfortunately it sounds like it the motor controller board which is around $800. National gym supply or sprotsmith has the part.
Posted on Mar 01, 2011
  • 3 Answers
SOURCE: On display stands: MOTOR COMM BAD
Try Carolina Technical Services in South Carolina for all you East Coast guys. They charge flat rate of $175.00 and have a 90-day warranty. Also great turnaround time. Carolinatechnicalservice.com. 864-504-7303. Sure beats sending to California and having to wait for 3 weeks.
Posted on Jul 04, 2011
  • 3 Answers
SOURCE: indicates motor controler comm bad
Check out www.carolinatechnicalservices.com. They can help if your boards look like either of the 2 on the website.
Posted on Jul 12, 2011
ercupa190
  • 12223 Answers
SOURCE: The screen says "motor control comm bad", what
Dear Sir: Hello, i will help you, but unfortunately the factory use this software:
System usage statistics on main motor:
By that reason the problem is the Main Motor is faulty!, some technician from the factory must be set up your machine. You must call them for to replace the main motor, and adjusting in the main controller(Boar for control the main motor).
When you had been repair the motor , I will STRONG recommend you to install some stabilizer voltage in the power cord in the receptable is Not expensive, will be costo about us$15.00 aprox.
Thank you in advance, if you need some additional assistance, you can contact me, blessing, sincerely.
E. CUADRA MANAGUA, NICARAGUA. C.A.
Posted on Sep 26, 2011
Bad Controller Comm Error. I swapped out Controller but still get same error, any suggestions?
i recommend to replace the control board. This is very critical matter for the electronic machine. see the diagram attached, How the controller motor hast the 80 of control of machine.
go to www.fitnessrepairparts.com and get it
Sep 23, 2013 | Life Fitness LifeFitness 9500HR Treadmill...
When attempting to load a tape into the AG-DV2000, the cassette door does not open and the display reads F07.
i had the same issue with my ag-dv2000, a fun problem to solve without a service manual. first verify we are dealing with the same issue.first open hopper fully and apply power. you should get an f06 error(failure to close in required time), now close hopper and apply power, you should get a f07 error (failure to open in required time). if this is the case the bad part is the motor drive ic. ic 1 on the motor drive board mounted to bottom of dv mech. it is a 10 pin ic labeled xra6887. i have not located a source yet but you can confirm the chip is bad by replacing it with ic6502 on the same board. if you put the bad chip in place of ic 6502 you will ground power supply and will not have power, leave it out. it controls threading motor, not needed to verify problem. the door should work now. dont put in a tape untill you replace bad chip. if you find the panasonic part number for this part please post it. happy desoldering!
Sep 16, 2011 | Panasonic AG-DV2000 Mini DV VCR
My power went out and i have a message saying security alarm, bad rtc chip , please reboot...how do i reboot..i have the verifone onmi 5100 vx 510
your power comm board is fry that's why it will not work the only way is to replace the board you have what we call power surge to the board
Jul 14, 2011 | VeriFone VX570 Credit Card Terminal (Dual...
Hello im getting a startup error when i press the quickstart button on my 95ti treadmill.
when I start up my treadmilll across the screens reads Motor-comm error. what coulld be the problem.I keep it clean and dirt free.
May 03, 2011 | Life Fitness 95Ti Treadmill 95 Ti
The washer is stopping midway through the load and an error codeLE what seems to be the problem
This is usually a communication error, unplug the machine for 20 minutes and then see if it returns when power is restored.
but if this does not helps then the actual reason of LE error code is as follows:--
LE LOCKED MOTOR ERROR
• The connector (3-pin, male, white) in the MOTOR HARNESS is not connected to the connector (3-pin, female, white) of STATOR ASSEMBLY.
• The electric contact between the connectors (3-pin, male, white) in the MOTOR HARNESS and 4-pin, female, white connector in the MAIN PWB ASSEMBLY is bad or unstable.
• The MOTOR HARNESS between the STATOR ASSEMBLY and MAIN PWB ASSEMBLY is cut (open circuited).
• The hall sensor is out of order/defective.
The hall sensor seems to be part of the motor.
The 'LE' error message indicates the control board has detected that the motor is either not turning, or has locked up for some reason. Monitoring the motor is the job of the hall effect sensor board which constantly determines the direction and speed of the motor and feeds that information back to the control board. If there is a problem between what the motor should be doing and what the hall effect sensor says the motor is doing, the 'LE' will be displayed and the cycle will be stopped.
Motor lock can be caused by several things from a loose connector, to a bad motor, or even the hall effect sensor failing or dislodging from it's mount. Any one or more of these components could have caused this error.
Dec 20, 2010 | Samsung WF337AA Front Load Washer
Error message notify maintennce motor controller comm bad
Mar 16, 2010 | Life Fitness 9500HR Next Generation...
E20 error message
replace the control panel or have it repaired,there is no e20 listed as a trouble code,so it needs to be replaced.
To clear latest stored error code:
Place the control into Diagnostic test Mode.
  • Turn the program knob clockwise 9 clicks from the Start Position. The control will signal the last error code.
  • Press and hold the Options and Pause Cancel buttons for 3 seconds. The code will be cleared.
  • Exit Diagnostic Mode to return the washer to normal operation.
Error code - Fault condition
E11 Fill time too long.
E13 Water leak in tub or air leak in air bell.
E14 Reed switch.
E21 Water not pumping out fast enough.
E23 Drain pump relay on control board failed.
E24 Drain pump relay on control board failed.
E31 Better models. Pressure sensor not communicating with control board.
E35 Better models. Pressure sensor indicates water overfill.
E41 Control board thinks the door switch is open.
E42 Door remains locked after cycle is completed.
E43 Control board problem.
E44 Control board problem.
E45 Control board problem.
E46 Control board problem.
E47 Board thinks the door PTC circuit is open in spin.
E48 Board thinks the door PTC circuit is closed.
E52 Bad signal from tacho generator.
E55 Motor overheating.
E56 High motor current.
E57 High current on inverter.
E58 High current on motor phase.
E59 No tacho signal for 3 seconds.
E5A High temperature on heat sink.
E5B High temperature on heat sink.
E5C High temperature on heat sink.
E5D Communication problem.
E5E Communication problem.
E5F Communication problem.
E67 Input voltage on microprocessor incorrect.
E75 Better models only. Water temperature sensor circuit.
E76 Better model only. NTC temperature for the cold water valve over the limits.
E95 Communication error.
EB1 Incoming power frequency out of limits.
EB2 Incoming line voltage above 130 VAC.
EB3 Incoming line voltage below 90 VAC.
EF1 Clogged drain pump.
EF2 Too much soap.
Apr 22, 2017 | Frigidaire ATF6000ES Front Load Washer
LE error message when washing. Drum will not spin
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
May 25, 2009 | LG WM-2077C Front Load Washer
Hplaserjet 4100 shows the error 55.0 printer error
Welcome to Fixya !
That is an iternal communications error. The first thing is to shut the printer and turn back on. If the error is still present the first item would be the firmware chip. I would remove the firmware and memory chips and reseat. Make sure you put the firmware chip back in the same slot. If that does not work, contact hp as they have a service not for firmware chip issues (not necessarily yours) and will replace it free. If not the chip it is either the formatter or the engine control board.
The Chips can be found by sliding the rear plastic panel on the right side of the printer towards the back of the printer You are looking at the formatter cage. Open the metal panel and chips are here
Feb 07, 2009 | HP 4100N: HP 4100 laserjet printer , 32MB...
Service Error
58.04 error is a processor error. check to make sure the transfer kit is installed correctly. Take it out and put it back in even if it looks like its in good.
If that doesn't work, take it to a service technician. It will probably have something to do with the connector from the Low Voltage Power Supply to the DC Controller, bad power supply or bad DC Controller.
Nov 05, 2007 | HP LaserJet 5200tn Printer
Life Fitness 9500HR Next Generation Remanufactured Treadmill Logo
87 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Howard
Howard
Electro Med Services...
Matt Olenzek
Matt Olenzek
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
