What's your question?HP laserjet m4345mfp error 49.4c02
4 Suggested Answers
pdouglasss
  • 125 Answers
SOURCE: hp laserjet 4650n
Hi 123sha:
49.XXXX
PRINTER ERROR
To continue
turn off then on
A critical firmware error has
occurred that caused the
processor on the formatter
to abort operation. This type
of error can be caused by
invalid print commands,
corrupt data, or invalid
operations. In some cases,
electrical noise in the cable
can corrupt data during
transmission to the printer.
Other causes include poorquality
parallel cables, poorconnections,
or home-grown
programs. On rare
occasions, the formatter is at
fault, which is usually
indicated by a 79 Service
Error.
1 Press CANCEL JOB to
clear the print job from
the printer memory.
2 Turn the printer off and
then on.
3 Try printing a job from a
different software
program. If the job
prints, go back to the
first program and try
printing a different file. If
the message appears
only with a certain
software program or
print job, contact the
software vendor for
assistance.
4 If the message persists
with different software
programs and print jobs,
disconnect all of the
cables to the printer that
connect it to the network
or computer.
5 Turn the printer off.
6 Remove all memory
DIMMs or third-party
DIMMs from the printer.
7 Remove all EIO devices
from the printer.
8 Turn the printer on.
9 If the error no longer
exists, install each
DIMM and EIO device
one at a time, making
sure to turn the printer
off and on again as you
install each device.
10 Replace a DIMM or EIO
device if you determine
that it causes the error.
Try new network card
pdouglasss
Posted on Jan 10, 2009
SOURCE: I Have Fault Codes on the Display.
Problem solve someone tried to print a PDF file which lodged the fault our It Dept deleted the print spool and Re-set the printer all ok.
Posted on Jan 15, 2010
  • 137 Answers
SOURCE: how do i get this error cleared 49ff95 on hp laserjet m4345mfp
Hi, Well this problem could be due to a lot of things. If this won't with a power cycle then make sure there is nothing in the print queue, a corupt file could cause this. If nothing there then try a cold reset. I believe turn off then on when you see the memory start counting hold the number 6 down until the three lights turn on and stay on. (Something should be seen on the screen like disk intialize or something) push 9 until you see cold reset then hit 6 again.
Regards, polysandy
Posted on Apr 21, 2010
Reseting HP Laserjet M4345Mfp
If you want to do a cold reset, then you must turn machine off. Turn machine on and when the memory count starts, hold down the ok key. When all three leds on control panel stay on solid, use the 9 button to advance through options. When you find cold reset press the 6 button, unit will restart with most settings back to factory. network card may not reset.
Mar 05, 2016 | HP Office Equipment & Supplies
How to reattached output bin cable
How to remove the error reattached output bin HP m4345mfp
Feb 07, 2013 | HP LaserJet M4345 MultiFunction Printer
HP LJ M4345MFP printer message Downld file now SEND RFU UPGRADE ON USB DEV PORT
Better to replace the farmatter assm, chances are too low to recover the formatter.
Sep 28, 2011 | HP LaserJet 4345mfp Printer
How do i get this error cleared 49ff95 on hp laserjet m4345mfp
Regards, polysandy
Apr 21, 2010 | HP LaserJet M4345 MultiFunction Printer
I get an error in HP LaserJet 4345 MFP printer, 49.ff95 error, Tunr off and the turn on
a 49.xxxx error on an HP means that there is an issue with one or more hard disks. you can try to re-initialise the hard disk(s) by rebooting the printer while holding the green button. when the three leds are lit, release the green button, and navigate using the numerical buttons until you see "initialise hard disks" on the display of the printer. confirm by pressing the green button again. if all goes well, your printer will take two minutes longer than usual to boot. if you still get the same error afterwards, you need to replace the disk.
Hp lj m4345mfp printer showing 13.31.00 fuser output paper late jam i am replace the fuser assy but problem is same
If you are using Windows:
  1. Click on Start => Settings => Printers and Faxes
  2. Locate your printer's name and right click on it and click "Printing Preferences"
  3. Under the "Main" (General tab in some other printer models) Tab, and under "Paper Options" group, select the settings for "Paper Type" Paper Size"
  4. Click "Apply" and the click OK.
Your values here will be the default values loaded when you click the print command in any programs in your computer.
Feb 09, 2010 | HP LaserJet 4350 Printer
Jan 14, 2010 | HP Color LaserJet 5550hdn Printer
49,4c02 error to continue turn off then on
I would try clearing your print que as it could be a corrupt print job and disconnecting your network cable and reboot the printer, make sure you have the latest firmware. hope this helps
Nov 24, 2009 | HP LaserJet 4700 Printer
Hi how to set up network scanner in m4345mfp all in one
Download and install everything you need including the instructuion booklet for the HP support website for yuo model . Link below:
http://h20000.www2.hp.com/bizsupport/TechSupport/Home.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=2512319&submit.y=7&submit.x=7&lang=en
Jan 06, 2009 | HP LaserJet M4345 MultiFunction Printer
Hp laserjet 4650n
Hi 123sha:
49.XXXX
PRINTER ERROR
To continue
turn off then on
or home-grown
programs. On rare
Error.
the printer memory.
then on.
different software
program. If the job
the message appears
only with a certain
software program or
software vendor for
assistance.
or computer.
6 Remove all memory
from the printer.
DIMM and EIO device
pdouglasss
Jun 18, 2008 | HP LaserJet 4650 Color Printer Manual...
jasbo
jasbo
