Question about Techno Source Kurio Kids Tablet With Android 4.0 - 7 Inch 4 Gb
The Screen flashes on my Tablet: red, green, blue, white. I had tried a hard reset but nothing happens, what else can I try?
Screen flashes red, green, blue, white. I had tried a hard reset but nothing happens
  • Kalani Kamanu
    Kalani Kamanu Apr 02, 2015
    Thanks Bill I had bought it in December so I am dealing with Kurio warranty department.
    mahalo,
    kalani
Tablet worked for a while, but now we have a blank white screen
This has happened to me as well. Try holding the power and home screen button at the same time for 20 secs or until it restarts. If this does not work try turning off the tablet and hooking it up to a charger. Hope this helped. Keep me posted.
Oct 01, 2017 | Tablets & eReaders
Digiland DL718M
Review: Digiland DL718M Android Tablet Gives the ...
the-digital-reader.com/2015/12/06/94715/
Dec 6, 2015 - Take the Digiland DL718M, for example. ... I also found that the screenon the Fire has a yellow tint when viewing an ebook in the ... fire tablet digiland dl718m... I am happy with it, and that says more than you might think.
DigiLand 7-inch DL701Q Tablet Review: Quad-Core 8GB ...
vbsweb.net/digiland-7-inch-dl701q-tablet-review-quad-core-8gb.htm
Dec 21, 2014 - With a 7" 5-point capacitive touch screen, this DigiLand DL701Q tablet makes .... Hi, my daughter was playing on her tablet and then the screen .... let me donothing just more error messages, when it says to report the error ...
Digiland DL700D Hard Reset - YouTube
? 1:55
https://www.youtube.com/watch?v=Yr7PTiaShQk
Oct 4, 2015 - Uploaded by Android Pro
Digiland DL700D Hard Reset .... I get the Digiland logo, then the green android, then nothing but black screen. ... DIGILAND 7" (DL718M) NEW ANDROID 5.1 LOLLIPOP TABLET HD DISPLAY UNBOXING - Duration: 4:12. by
Jan 01, 2016 | Tablets & eReaders
USED WRONG CHARGER ON RCA TABLET AND NOW SCREEN MALFUNCTIONING.HOW DO I FIX?
Try a factory reset of your tablet first. Here is a link to the procedure:
http://www.rcatablets.com/how-completely-reset-your-rca-android-42-tablet
Apr 29, 2015 | RCA RCT6077W2 7" 4 GB Black Wi-Fi Tablet...
How to factory reset a contixo tablet ?
Look around the tablet to see if there is a pinhole along the edge or back. If there is, then you can carefully insert a straightened paper clip to reset the tablet. Normally from off condition, insert paper clip and press power button.
If no pin hole, from an off condition press and hold the volume + and the power buttons until it boots. Follow any directions presented.
I am sure you have checked your manual, but you may want to look again for any specific reset procedures.
Mar 31, 2015 | Contixo Q102 10.1" Quad Core Google...
I have a Tablet that was giving to me from a friend but she has forgotting her password and its lock at the main screen. I tried by pressing the reset button as well pressing the volume button but nothing...
Take it back to the generous person who gave it to you and ask her to try hard to remember the password or to unlock it for you so that you can change the pattern. Or contact the manufacturer's service center.
Dec 06, 2013 | Zeki Berk Ulu 8GB 7in WiFi Android Tablet...
My tablet is stuck on a green screen with the green words android along with a flying green android
switch off tablet and keep pressing the power button a bit longer. Remove battery and replace it after 2 minutes. Switch on the tablet. Good luck
Dec 03, 2013 | Tablets & eReaders
I have an Evorea Tablet, I power up get a white screen but no home buttons show up, in fact nothing but a white screen
Hello Jachin, if you still have this problem. Try doing a "hard reset"
- Turn off tablet
- Hold down the power and volume "down" key together
- when red text appears select "yes" by holding down power key for 10 secs.
Reformatting shall commence
Please note that this process works on most android tablets.
Hope this helps
Nov 24, 2012 | Android Tablets & eReaders
I HAVE A PANDIGITALSTAR ANDROID TABLET WHEN I TURN IT ON IT STAYS ON THE WHITE SCREEN AND SAYS PANDIGITAL WITH THE BLUE DESIGN BUT I HAVE NO ICONS AND WHEN I PRESS THE BUTTONS AT THE BOTTOM NOTHING HAPPENS...
had same problem. I figured it out. While pressing the home key on the bottom of the tablet, press the on/off button until a black screen appears with green words on the side, which says upgrading...please wait...wait. It should take you to the Pandigital screen with a small bar underneath it with green going across. It should work.
Dec 15, 2011 | PANDIGITAL Digital Book 843967071153...
I just bought new lcd display for my Toshiba Satellite R10 Tablet. The inverter is fine, checked the cables and reconnected. But the screen alternately flashes solid white, red, green and blue on the...
you need to download the proper drivers for the Graphics Card Right click your desktop go to settings go advanced Go to the intel(R) tab and hit Graphics Properties thin pick' either Dual Display Clone or Extended Desktop and Click Apply.
Wierdly the Monitor 2 will Still he greyed out in the settings Tab but the monitor will display Good luck
I'm currently trying to figure out it I Can Rotate the tablet Monitor and keep the other monitor Un-rotated Any ideas?
Oct 19, 2010 | Toshiba Satellite R10-S802TD Tablet PC
Techno Source Kurio Kids Tablet With Android 4.0 - 7 Inch 4 Gb Logo
234 people viewed this question
Top Techno Source Tablets & eReaders Experts
David Payne
David Payne
ray gallant
independebts
independebts
Level 1 Expert
Are you a Techno Source Tablet and eReader Expert? Answer questions, earn points and help others
