Question about 2002 Ford F350 Truck Super Duty Crew Cab Power Window Regulator wit
I have an F 350 2002. The door ajar light stays on most of the time, and when she on my door locks don't work. Also My trailer turn lights wont flash. Is some how related. Also the radio wont go off
    Genius:
  • 1A Auto Parts Master
  • 2,494 Answers
Check the wires in the cable plugs have not come detached to the trailer wireing ,if the ok check the light globes have,nt fallen out,check power at the lights with a test light,with the door light check the switches on the door frame,s.
Posted on Jan 04, 2017
Alarm activates falsely
there should be a pin button that pushes in and out by your door hinges. if these stay stuck in the dome lights wont work. if its out you will experience some problems like you are experiencing. try checking these and go from there.
Jul 12, 2013 | Autopage Vehicle Parts & Accessories
Auto door lock don't work, they click when activated. Also the door ajar light stays on and auto light does not work. F350 super duty 2002 ford
You might need to oil the locks. Our truck does that some times. We just spray some WD40 on the catches and keep clicking them back and forth till it sinks it. As for the ajar light, the sensor inside of the door jam might be damaged. or the switch on the lights is turned on. I did that once.
Feb 27, 2013 | Cars & Trucks
Ford fiesta ajar light stays on and central lock not working
The central locking will not work when a door is open. find the door which is ajar and fix the door switch. Could be a stuck switch (either open or shut) May just need a whack with a soft faced hammer on the door frame. Don't hit it too hard you could dent the panels.
Nov 18, 2012 | Cars & Trucks
Doorajar liht and beeper sounds
It can be issue with faulty sensor or a wiring issue.Troubleshooting is required.
Click the help link shown below:---
Door Ajar Light and Dome Light Remains ON? http://whoisbyme.blogspot.in/2012/06/2003-mercury-sable-door-ajar-light-and.html
Door ajar light stays on? http://technoanswers.blogspot.com/2012/01/door-ajar-light-stays-on.html
Thanks.
Jun 26, 2012 | 2002 Ford Explorer
2002 Ford F350, Door Ajar Light on constantly, Auto Locks don't operate, Auto Headlights don't operate(only manually), Dome Light does not operate when opening doors, Remote does not work. All
Your keyless entry system is going bad and you need a battery for your keyless entry system once you replace your battery with the new one thing should work properly
Feb 06, 2018 | Ford Cars & Trucks
I got a mercury.. and the problem is the driver door some time it locks good all the way while start driving will lock, just like any other car. and some times it wont lock u can still drive but it will...
Your door ajar switches are located inside the rear faces of each door along with the latches. Just liberally spray a petroleum based lubricant into the door latch areas of each door (one at a time) and open / close the door several times. Once lubricated, your door ajar light, interior lights, and autolocks should function properly.
Good luck.
Apr 24, 2011 | 2002 Mercury Mountaineer
Door ajar alarm comes on while driving.
there is a switch in each door that senses the door is open, it is called the door ajar/courtesy light switch (imagine that), they stick and have this problem, replace it.
Mar 25, 2009 | 2001 Volkswagen Jetta TDI
2003 Explorer door ajar light stay on when all doors are closed
I had this problem on my 2003 explorer and took WD40 and gave the lock mechanism a good dose where it meets the clasp on the door jam. Then open and close the doors a couple of times to get them working. They get gummed up and sometimes have a tendency to stick.
Dec 29, 2008 | 2003 Ford Explorer
2002 Ford F350 Truck Super Duty Crew Cab Power Window Regulator wit Logo
26 people viewed this question
Top 1A Auto Parts Vehicle Parts & Accessories Experts
Tom
Mike Stager
Mike Stager
Are you a 1A Auto Parts Vehicle Part and Accessory Expert? Answer questions, earn points and help others
