Question about Garden
INSIDE OF FRONT PANEL THERES 3-WAY PORT WITH 3 CLEAR HOSES COMING FROM IT
PLEASE WHERE DOES EACH CLEAR HOSE GO TO.LEFT GOES TO.?? RIGHT GOES TO.?? CENTRE GOES TO??.MANY THANKS.MARK/SWANSEA
mikedurland
  • 481 Answers
SOURCE: Installing water hose's
  • it is kind of hard to explain without being there, so please bear with me.
  • if the refrigerator has a water filter then 2 lines will will go to it, probably diagonally up the back of the refrigerator. the water goes through the filter first then back to the valve.
  •  then another line will go strait up the back of the refrigerator to the icemaker.
  •  the line that goes under the refrigerator is for the water dispenser in the door.
  •  the water valve should have come with instructions on which line goes where on the valve, there is now way for me to convey this to you. the valve assembly you described is proprietary for your machine.
  • if you need more help let me know, i will try to help you figure it out.
Posted on Jul 04, 2008
  • 97 Answers
SOURCE: Gas driven portable pressure washer no longer draws chemicals up
Picks up under low pressure conditions by adjusting wand or changing tip.
Posted on Mar 19, 2009
USfalcon
  • 175 Answers
SOURCE: Toyota corolla heater tap neck hose
u should remove the top hose which come from the engine to the raidator
Posted on Apr 03, 2009
  • 375 Answers
SOURCE: My 1987 K100 LT Fuel hoses.
It isn't the most straightforward without diagams. The system is under pressure as it is EFI, so firstly you need to depressurise it. This involves removing the battery before doing anything else. In order to replace the pipe, you need to remove the whole tank, this procedure takes up 2 and a half pages of the Clymer manual - I would recomend you either purchase the manual or get it into a BMW service centre.
Posted on Jul 03, 2009
  • 574 Answers
SOURCE: Maytag A482 washer from 1985. Leaking water from
probably has a pin hole leak where it has been rubbing the tub. Does the tub have a seal at the top of it where it meets the top. Could be the seal is going bad.
Posted on Sep 07, 2009
Dishwasher wont drain
If you will open the door on the front of the dishwasher, you should see two small screws going through tabs holding the dishwasher to the countertop. They are in the front, and above the door.
If you will remove those screws, you should be able to pull the dishwasher out about halfway into the room.
Do not pull it farther, because there are 3 important components you want to leave hooked up. The electric wires, the drain hose, and the fill hose.
Remove the front lower panel that hides the bottom of the dishwasher, and you should see a water pump made of plastic maybe the size of your fist, maybe on the right side.
The drain hose should be attached to that pump, as should electric wires. The drain hose goes to the sink drain in most cases
Find a way to catch the water and or sludge that may come out of that hose, and remove the hose from the pump that goes to the sink drain. You may need a pan that holds a quart or more liquid.
See if that hose is clear of being plugged up.
Sometimes too much food left on the dishes can plug up the pump or the hose. Examine the pump to see if it is plugged.
If the hose goes to the garbage disposal, perhaps that is where the plug-up is.
Jan 07, 2013 | Hotpoint Dishwashers
I have a model 417 Kenmore front load washer which stopped running and shows a E 20 error message in the window. What does that mean and how can I get it operating again?
Check to see if you have an obstruction inside the pump. If the hoses and the pump is clear, then it would be the motor control module, located in the back left hand corner of the washer.
First take the fat hose coming off the the bottom of the tub, that goes into the pump, you can access it by taking off the rear panel. Inside that hose is a filter, that normally gets clogged.
Hope helps.
Aug 16, 2011 | Kenmore Washing Machines
Replaced brakelines know pedal goes to floor
You either have a leak in the the system or your master cylinder is bad and allowing the pedal to push through the cylinder without bulding pressure. Check all the wheels for signs of a leak, if none and the brake fluid resivoir is full then the master cylinder on the back of the firewall is bad. These can be rebuilt very cheaply and you can do this yourself with parts from the parts store.
Apr 08, 2011 | 1998 Pontiac Sunfire
Rinnai direct vent heater RHFE 556WTA goes off showing code 99 which means flue block we have checked flue terminal and still have same problem. I understand their is a recall on some please let us know...
Remove the top panel closest to the wall after you remove filter. Check all the connections for exhaust and air intake. You can remove the air intake pipe (looks like a smaller diameter vacuum cleaner hose but Gray in color) and run the unit with it off of the vent. If unit starts and stays on, the inducer blower is getting weak and will need to be replaced. There is also two small hoses (clear and blue) that may have come off the vent or even cracked or chewed by a mouse. Inspect them for cracks or damage. You may have to take off the right side panel closest to the wall to get to the hoses. Next, remove the many screws that hold the front panel on the heater. Take off the front cover and check to make sure all the hoses are connected and that the inducer fan runs. You can even take a shop vacuum and put it over the center hole on the vent to make sure something is not lodged inside where you can't see it.
Yes there is a recall for a gasket that deteriorates over time. It is located at the view port of the flame. Contact Rinnai at (US) 8006219419 for details.
Hope this helps.
Feb 24, 2011 | Rinnai RHFE-556WTA Direct Vent Heater NG...
I have a 1986 ford ltd,6cill. small sedan,theres i guess a vacuum distributer on the driver side firewall. on the lower left port there was something, but i noticed there was no hose attached so i put a...
The one you capped could have been capped from the factory. The hose that goes thru the firewall goes to the heater controls and the one that is tee'd to it should go to a vac can. It will be a plastic ball or a metal soup can.
Jul 25, 2010 | 1986 Ford LTD
Need to know how to bleed the brake system? just changed front and rear brakes pads and shoes ... need to bleed brakes
I will assume you have some mechanical ability to explain this process:
Remove cover on master cylinder and make sure the brake fluid is filled to the proper level.
-For a one man job; get a piece of 3/16" X 2' clear plastic hose.
-Starting at the furthest brake cylinder; typically the right rear wheel.
-With the proper wrench, loosen the bleeder valve and place the hose over the opening.
-Fill an empty container (empty brake fluid bottle works great) about 1/4 of the way with brake fluid...put the other end of the hose into the container, ensuring the end of the hose is secure in the bottom of the container.
-Open the bleeder valve, ho around to the driver side and pump the brake pedal (slowly or you'll make a mess under the hood), about three times.
-Refill the master cylinder and repeat until the liquid in the hose is clear.
-Repeat process for the left rear, right front, and then the left front.
Good Luck! If this helps please indicate so.
Nov 18, 2009 | 1997 Chevrolet Tahoe
A/C Problems When Accelerating
I have a 1994 Town Car EVTM, Electrical and Vacuum Troubleshooting Manual. I no longer need it and will sell for $10 including shipping. Let me know.
As for the hoses:
  • a black hose goes from the intake to a vacuum manifold with eight ports.
  • the next 2 ports go to the PCV through a "T"
  • the next port goes to the check valve for the a/c system. The check valve has two ports coming out. One for the reservoir and one to the heater control panel.
  • the next port goes to the automatic park brake release switch (I think on the steering cloumn base.)
  • the next port on the vacuum manifold has a red plastic hose going to the EVR, EGR Vacuum Regulator. A green hose comes out of the EVR and goes to the EGR Valve.
  • the next port has another red hose that goes to the FPRC (fuel pressure regulator on fuel rail?)
  • the last port goes to a check valve and then on to the brake booster.
May 08, 2009 | 1994 Lincoln Town Car
Clothes come out soaking wet seams like it doesn't spin out the w
There are 3 possible places to look for filters as each machine is made differently –
1 If machine has a square flap fitted on the front filter maybe located behind this.
2 It could be located behind the front lower kick panel (remove panel to see).
3 Located inside the sump hose, this is the hose that is attached to the bottom of the
main tub.
Try this:
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too.
On some models the filter is located ‘inside’ the big hose from the bottom of the tub. This takes more time to clean.
Apr 10, 2009 | Maytag Neptune MAH6500A Front Load Washer
E20 Error - how do I access the inside to check for blocks?
Plug off the mains. First drain out all your water by lowering the exit hose into a bucket or drain. You have to look for screws below the front kick-panel, the panel comes down & out. (You may find the drain hose here, on left) The pump is on the right side. Be prepared for dirty water. Inside the big flexible tube (coming from the tub bottom) is the filter, be prepared to find all sorts of junk here, clean out. Examine your pump also, clean out the impeller. Carefully refit all. Your machine would be fine. Don’t wait for the machine to jam to look into your filter.
Mar 21, 2009 | Frigidaire Affinity ATF7000E Front Load...
Jul 04, 2008 | GE Refrigerators
Garden Logo
44 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
