My bizhub 210 has new image unit but its printing too light copies. please what can i do?
    Master:
  • 487 Answers
Read the instruction manual and make adjustments through the on board menu screen.
Posted on Apr 01, 2015
  • 10 Answers
SOURCE: service manual for KONICA MINOLTA Bizhub 210/162
Swithc off the machine Press stop button and hold switch on the machine. problem will go.
Good Luck
Posted on Jan 07, 2009
Junoon007
  • 1011 Answers
SOURCE: Bizhub C351 Magenta Image Unit Problem
Sir,
The print head assembly has failed. Replace the print head assembly
Posted on Jan 15, 2009
  • 12 Answers
SOURCE: Imaging Unit Problem with bizhub C450
On the end of the image unit you will find a white bit of plastic with a small screw in the middle, make sure this screw is tight and then reinstall the units(give the units a bit of a shake too)
Posted on Apr 06, 2009
smt24
  • 54 Answers
SOURCE: put in newer fuser unit but machine still says to replace
If you want to clear the fuser message you have to be sure you replaced the fuser web. Then go to 25 => counter clear(items 13)=> Clear fuser counter or 36=>counter clear(items 8)=>Clear fuser counter.
Posted on Jun 03, 2009
xeerie
  • 347 Answers
SOURCE: i connect the konica minolta bizhub 210 to my win
SOLUTION:- Follow these steps. 1-First of all take a usb cable. 2-Connect its one end to Bizhub 210 and the other end to your computer. 3-you will see your computer will show a notification " Found new hardware". 4-Now insert the printer Driver disc of Bizhub 210 in CD-ROM. 5-autoplay will show at the desktop 6-Now click on "Install Printer" 7-Follow the instructions and install the drivers. 8-when the drivers are correctly installed you will see printer icon of bizhub 210 in "Printer and Faxes" at control panel of your computer. 9-Now right click on this icon and click on "Properties" 10-now click on "PRINTING PREFERENCES" tab. 11-select Paper size, i.e if you are using A4 size in bizhub 210 then select paper size=A4 from the list. 12-now give a print command.ctrl+p. of any document. 13-printer will start printing.
if still having problem, then please do check the usb cable, it may be broken. if there is any other printers are installed on your computer which are not in use then remove them/ delete them. use konica minolta bizhub 210 as a default printer.
Posted on Jun 30, 2010
Konica minolta bizup c550 printing black copy what will i do?
The corona housing for the back drum need to be replaced. Get a new black image unit drum and developer units
Aug 15, 2014 | Konica Minolta Bizhub C 353, Bizhub...
My problem is with a bizhub 181, because the copies are opaques. I already check and replace the imaging kit. but is damaged.
Sir/Mam,
Is the machine set up as a printer also do print come out ok? Copies from the big glass ok? Mite be the electrical connection to the sponge roller on the right side door the sponge looking roller is what helps the transfer of the image off the drum to the paper. The paper is guided between both the drum and that sponge looking roller to place the image on the paper. There is a high voltage applied to that roller during the copy cycle. the connection for the roller is on the copier at the rear where the right side door closes
Oct 05, 2013 | Konica Minolta 950-281 Genuine Konica...
I have an Konica Minolta Bizhub c250. for the last week now the prints and copies are so light I can't read them. I have replaced the toner. I would liek to know if this would be caused by the drum or...
This can be the problem of imaging unit, you have replaced the toner still print is light this means you need to replace its opc drum.Most probably its K.Replace it with the new on.Print will be fine.
Mar 21, 2011 | Konica Minolta bizhub C250 All-In-One...
I connect the konica minolta bizhub 210 to my win xp system then i try to print but i can't the system show the message "failed to print" what is this .please help me
Jun 28, 2010 | Konica Minolta bizhub 180 All-In-One...
Cannot print in duplex
Go to Option, in driver and be sure that the Duplex Option is installed.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Jun 01, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
46 people viewed this question
k24674
jasbo
jasbo
