Question about Speed Drills
Works on 1&2 speed just spins & clicks in 3 speed
    Master:
  • 487 Answers
Clutch may need replacing.
Posted on Apr 01, 2015
I have a front loader washer Kenmore Elite Model #796.40311900 that spins SLOW, not FAST as it should on spin. The digital readout works normally.
sounds like maybe drain filter is plugged and unit is not draining fast enough. if you have drain access in front pull it out and clean it.
May 08, 2017 | Kenmore Washing Machines
LG WM2101H won't dry until many cycles
Won't dry? I guess you mean spin enough water out? Depending on age, warranty, It sounds like a worn or bad drive belt or possibly a problem with the discharge pump not working properly.
May 04, 2015 | LG Washing Machines
Washer wont spin code e57
High current issue - 1. Remove the belt from the motor and spin the motor pulley. Does the motor spin free? No, replace the motor. Yes, go to step (3). 2. Spin the tub pulley. Does the tub spin free? No, check the tub bearings. Yes, go to step (3). 3. Disconnect the plug from the motor and measure the resistance of the windings (pin 1 to 2, pin 1 to 3, pin 2 to 3). All readings should be between 4 and 6 ohms. If readings are correct, replace the Speed Control Board. If readings are incorrect, replace the motor.
Aug 19, 2012 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire affinity washer error 58
High motor current is recognized in the unit:
Aug 10, 2012 | Frigidaire Affinity ATF7000E Front Load...
Blower start up problem
The motor is bad. It is overheating and shutting down on thermal overload. You need a new motor
Jun 24, 2017 | LG LWHD1200FR Wall/Window Air Conditioner
I have a Hoover Zodiac12 2-speed reversible motor i want to use for a home project. Its a Nuova Ibmei with 5 terminals. The wires are L to R and top to bottom; 1. black stripe, 2. blue, 3. yellow, 4. red...
You will destroy the motor by running it with multiple speeds tied together. So be careful. Just try and get it to work with 2 wires and tape the others off away from each other and the frame so they won't short anything out. themobilian_795.jpg
Jan 04, 2011 | Washing Machines
Wont play
If its not a power problem, notice that the servo motor is spinning or trying to spin with a disc in the tray.
-listen carefully for a high pitch or whinning sound of the motor.
-do you have a reading on the screen? No disc or reading disc?
One of the above can be:
1- a defective laser (it wont illuminate)
2- a broken flat cable to the laser (you wont hear clicking sound when reading)
3- a bad servo motor that can not reach its speed to read the disc (has to spin at a very high speed)
Hope you can solve the problem, succes
Aug 27, 2010 | Apex Digital Televison & Video
Brushes the motor on spin does 1 of 3 things 1- does not start you here it trys to turn but stalls 2-does a very quick spin (3secs)then stops 3- goes gradually up to spin speed, when it approches full...
sounds like part of one of the bushes is trapped in the motor,take motor off and by turning around a bit may just drop out,as i had to repair a washer with the same problem,rgds,paul.
Jul 07, 2009 | Hotpoint WMA32 Front Load Washer
No high speed spin cycle
I just had a similar problem. The washer would just shut down prior to the high spin cycle. I had a service guy in and he had a diagnostics sheet. Did you get an error code? If you have the electronic. Turn the knob to the Drain/Spin mode and press both the "Options" and "Cancel" buttons simultaneously until all control panel lights are lit and flashing. Then turn the knob clockwise in click and the washer will then go into its diagnostics mode. With every click it should do something (i.e. fill, pump, drain, spin, etc..) continue turning 1-8 clicks. On the 9th click you should then get an error code. My code was E47, which I have already posted another possible solution. I could be either the door switch or the control panel. Remove the door switch by removing the wire around the rubber seal, then remove the 2 screws for the door switch and unplug the 3 plugs. Check the readings on the PTC (white plug on doorswitch). If the switch reads around 1500 ohms, then the problem is most likely the control panel.
To exit the diagnostics mode, the easiest way is to unplug the washer, wait 10 seconds, and then plug it back in.
The reading on my switch was 1398 ohms, which is close to 1500, so I ordered a new control panel. Hopefully, this will work.
Jan 03, 2009 | Frigidaire GLTF2940ES Front Load Washer
Need a user manual for lg washer dryer wd 12331 ad
Click on washing machines, (below FIXYA) on this site, find your model, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site.
Dec 30, 2007 | Washing Machines
Drills Logo
103 people viewed this question
Top Speed Drills Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
noel
noel
Andrew Taylor
Andrew Taylor
Are you a Speed Drill Expert? Answer questions, earn points and help others
