Question about ViewSonic VX2835wm Monitor
I just received the vx2835wm as a gift, got it hooked up thru a HDMI cord and all that is happening is the power button is lit up blue. the screen does not turn on. Any advice?
    Top Expert:
  • ViewSonic Master
  • 10,875 Answers
Change the input to hdmi 1 or 2,if that doesnt work,hook it up to something else with different cord
Posted on Apr 01, 2015
I'm back.my mitsubishi ws-48413 tv only has a blue screen when i turn it on. Ive tried several things. I tried turning on the receiver first and waiting 10 seconds and the opposite. I rebooted the tv...
There is a communication error between the source & the TV. When powering up the units, try turning on the receiver first, then turn the TV on, that way there is a signal for the TV to detect at initial start-up.
Dec 12, 2014 | Mitsubishi Televison & Video
The "new device found" screen keeps popping up
Inspect for damaged pin on INPUT 1 socket. (left most of the three HDMI connectors)
A quick pull on the cable can damage the pins.
=== If you see mis-aligned pins then please power off the set before making corrective action. ===
============== Here's a textbook instruction from Mitsubishi
If the New Device Found Screen Displays No HDMI Control Option If the New Device Found screen shows no option for HDMI Control, one of these conditions applies: • HDMI Control is turned off in the menus of the new device Action: a. Highlight EXIT and press ENTER to close the New Device Found screen. b. Display the device's setup menus and enable the device's CEC capabilities. c. Wait for the TV's New Device Found screen to appear again. d. If the New Device Found screen does not appear, power off the device. Power on the device and wait for the New Device Found screen to display with the HDMI Control option.
Next time you see the NEW DEVICE FOUND screen pop up.
Toggle the CEC field (on the right side of the pop up) to OFF.
Jan 05, 2011 | Mitsubishi WD65737 65" DLP TV
When I plug in the power cord nothing happens. I press the power button and nothing seems to happen. I tried 3 different cords.
The power supply on lcd and other flat screen type monitors utilize a group of capacitors as a static pulse for the screen to energize..my bet is that one or more of those have failed...it's actually a common problem with flat screens. Most of them, those that won't power up anyways, have this exact same problem. If it's not that, then your power supply is burnt out, and if that's the case it may be cheaper to get a new monitor instead of trying to fix the old one.
Dec 13, 2010 | ViewSonic VX2835wm Monitor
Hi Have Vizio Flat Screen and a Denon 3803 receiver. The Tv a Vizio 65 Inch flat screen was here. Out of the wall is a power cord and red,blue,green monster cable. Red and Blue is audio and green video I...
Red, Green and Blue cables together typically denotes a component video signal - an Analog, High Definition transportation for video. This cable does not carry audio, you need another cable to hook up audio between the DVR and receiver. You can use either an RCA stereo cable (red and white), optical-audio, HDMI, or a whole plethora of other audio cables. I would recommend optical or HDMI to get the most out of your system.
Jul 16, 2010 | Denon AVR-3803 Receiver
HTMI errors on the following devices DVD Blue-ray HDMI connected; CD Not HDMI connected; VCR Not HDMI connected; satellite works OK HDMI to Yamaha - HDMI to TV NO HDMI error displayed; GUI does not display...
You have to use Component Video on this unit. HDMI will not "Handshake" and pass thru. This was HDMI's first version "1.1a" and there is no fix. Use your receiver to switch audio via Coaxial or optical then use HDMI directly from BLURAY etc to your TV. The downside to this is how many HDMI inputs your TV has. It's an awesome receiver! Don't blame Yamaha!!! This issue is directly attributable to "HDMI" and their race to shelves before truly field testing the product. The current version of HDMI is 1.3b and soon to be 1.4 which includes ethernet capabilities.
I hate to be the bearer of bad news! If you would like an "in depth" look into the world of HDMI issues, Google HDMI problems or HDMI forums, and you can read for hours. Hope this helps
May 29, 2010 | Yamaha RX-V2600 Receiver
I have an HDMI cord hooked to my Bravia it is set on video 6 the cable box is powered on and funtiona and the HDMI cord is good. I am getting no sound and no picture is there any way to test the HDMI port...
if you have video im assuming you do if you can see its on video 6 look at hdmi port and make shure its video 6 if your not shure leave it hooked up the way you have it turn on cable box and go thru all inputs example put it on video 1 wait for 60 seconds if nothing happens go to video 2 and so on and so on be shure to wait at least 60 seconds before you change to another input good luck
Feb 03, 2010 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Hdmi cord my tv
may be a problem with the input on the tv or the receiver itself. if you have another receiver, try hooking it up to see if you get a video or component cables (red, green, and blue) work just as well these are video only so also have to have composit cables hooked up with it
Apr 04, 2009 | Protron PLTV-32 Television
Blue screen with dtv input and HD channels
the left large button controls a dozen different ways your set is hooked up,easest is get the monolink cord at any store will need a dvi hdmi.if not keep rolling the left large button,if you have a blue screen on all your inputs ,There has to a man around to plug in the right cord.
Jan 28, 2009 | Mitsubishi WS-55807 TV
Open Questions:
ViewSonic VX2835wm Monitor Logo
175 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
