Question about Cameras
New 164GB SD card when put in to either of my 2 cameras a message reinsert card appears on screen. No further operation can be done until card is removed. Can this problem be fixed?
  • ausyjohn Apr 01, 2015
    4GB @32GB cards both work ok in both cameras.
  • Harrie Apr 04, 2015
    Up to 32 GB is SDHC. Above that, you come in the SDXC range. Although there is almost nothing between 32 and 64. Your camera also is compatible with the SDHC norm.
    Top Expert:
  • Cameras Master
  • 6,702 Answers
The 64 GB cards are not SD cards. They are SDXC cards and need a different interface. The card lloks the same, but the electronics is different. Your camera or any device you are using should be SDXC compatible.
On this page, scroll down half a page and look how the compatibility works for SD, SDHC and SDXC.
What SD Information SD Card Panasonic Global
Posted on Apr 01, 2015
Testimonial: "Thanks Harry this answers my question. I meant 128 GB this card is not compatible with my Sony A55 camera, I need to get an ordinary SD card"
Fix memory error message on camera
Hi there! Make sure the SD card is not locked. There is a tiny slider on the side. If is in the "down" position, the card cannot have new files saved to it. Move the slide to the "up" position, then reinsert the card.
If the slider is very loose, it's possible that inserting it into the camera slides it down, essentially making it useless. I have one like that. You could try a touch of superglue to make the slider harder to move, but I have never tried this and you would need to be very careful not to use too much, and to make sure it's entirely dry before putting it in your camera. Perhaps try a different memory card?
Nov 04, 2014 | DXG 518 5 Megapixel Compact Camera -...
Gateway digital camera DC-T50 5.25 megapixels put new memory card and a card error message appears
The camera uses SD cards. I assume your new card is 8GB, not 8MB as you stated. If this is the case, it's an SDHC card. While it fits into the slot, it is electronically incompatible and will not work in the SD-only camera. You need to use SD cards, 2GB and smaller.
You may download a copy of the manual here.
Apr 04, 2012 | Gateway DC-T50 Digital Camera
Quite regularly when I turn my new Coolpix S8000 on to take photos a message "memory card is write protected" appears on the screen & the camera won't operate. If I turn the camera...
on the side of the card you have a little button and it has 2 position : lock and free. if the button is on lock position that may be the problem! so please check it and put the button on free position and try again!
Jan 03, 2011 | Nikon COOLPIX S8000 Digital Camera
No function is performed, "write protect" message
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Dec 02, 2010 | Olympus FE-230 Digital Camera
Inserted new memory card and getting error message - saying it's locked but it isn't. tried 3 new cards all with same message. Tried to format but the option to do so isn't accessable
Hello
If the card works in another camera or another card doesn't work in your camera , the problem is with your card reader in your camera.
Kind regards
Andrea
Jun 10, 2010 | Canon PowerShot S80 Digital Camera
Get message "card locked" - made sure sd card was unlocked, but still got message - tried another sd card and still received message
Hello
Kind regards
Andrea
Apr 21, 2010 | Canon PowerShot SD550 / IXUS 750 Digital...
Tried to unlock Lexar SD 2GB and Lexar SDHC 4 GB - No luck
First of all, the 4GB card will never be able to work in your camera. Check on its face. It likely says SDHC, and SDHC cards as this format came out after your camera was designed (I know it looks exactly like a normal SD card, but it's not).
Now the 2GB card should work with your camera as it is a standard SD card. Remove the card from your camera. Look on the side of the card for the tiny slide switch, and slide it to the other "unlocked" position. Reinsert it in the camera, and see if that corrects the problem.
Oct 19, 2009 | Canon PowerShot A620 Digital Camera
Camera screen said SD card is locked when I installed an SD card
The SD card has a lever on the side of it. Move it to the other position.That is to prevent accidental erasing.
May 12, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Error 30
The "E30" error code indicates reading/writing data on a SD card has failed. Especially, the error code "E30" may appears when you tried to remove a SD card while the camera was processing data. Solution To clear the "E30" error, try performing the following procedure. 1. Try using another SD card. If you have another SD card, try loading it in the camera. If the error code is not displayed when the other SD card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the SD card for errors. Use ScanDisk to check the SD card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the SD card on the computer before you check the SD card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the SD card. Follow ScanDisk's on-screen instructions to solve the problem. 3. Format the SD card with your camera Try to format the SD card with your camera. Please refer to the "Camera User Guide" for your camera for instructions on formatting SD cards. Also, please note that formatting a SD card will erase all data on the card. Once the SD card is formatted, follow the procedure described in step 2 above and use your computer's ScanDisk on your computer to check the SD card for errors. If a card error or card failure occurs when you are using computer's ScanDisk, there is something wrong with the SD card.
Aug 31, 2005 | Canon PowerShot SD200 / IXUS 30 Digital...
Error 30
Aug 29, 2005 | Canon PowerShot SD10 / IXUS I Digital...
Cameras Logo
60 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
