Check the plugs to see if you all cylinders are burning clean. Multiple fouled plugs can cause the same problem. Wet plugs indicate they aren't firing at all, which means the coil pack isn't working. Check the air filter, it could be choking the motor if it's too dirty. Check the fuel filter to see if it's clogged from dirty gas.
Have you checked the wiring that goes to both the Crank and Cam sensors? Most of the time the wires are close to a heat source (ie: exhaust manifold) and the plastic covering starts to melt causing the cooper on wires to make contact and thus making engine stop, you will have to take off the protective covering as well as tape around the wires and inspect each and every one. Had same problem with Dodge caravan, it turns out the Crank Sensor plug wires were melted together. Good Luck.
Two basics; fuel supply and ignition. Neither of these are difficult to check but for in-hand assistance, a service manual is a good investment and we like Haynes:
Dakota service
