Question about Soleus Heating & Cooling
I have the soleus kftzhp-12. I have condinsation dripping from the lower front. Just below the vent. Not sure what my options are, any suggestions? Thanks
2 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: Frigidare thru-wall AC drips water when unit is on.
Do not try to drill any holes but search for the built in drain and open it. Again do not use a drill. Get a shop vac.
Posted on Jun 09, 2009
It is freezing over the vents at the top and dripping in icicles down inside over the lower drawer fronts
It could be a defrost problem or there could be air seeping into the unit through the seals. Check the seals for any faults. Would need model # to suggest further.
Sep 27, 2015 | Refrigerators
Soleus GPS software - "No USB Device" warning
Dear Mike,
I have the same problem. I tried the solution (link below) suggested by Soleus but of no avail. Maybe it will work for you. I'm using Windows 8. Good Luck :0)
http://cdn.shopify.com/s/files/1/0196/4616/files/Soleus-Software-Troubleshooting.pdf?2012
Dec 16, 2013 | Soleus GPS 3.0 Running Watch and Heart...
Need driver?
Dear Mike,
I'm not sure my first post made it online.
Sportive greetings from Belgium,
Pascal
Samsung fradg
When you thaw or let the ice melt, make sure all the vents between the freezer(upper compartment) and refrigerator(lower compartment) are clear of ice or obstructions. This is very important! Make sure all vent ducts and tubes are clear of ice!!! Next Level the unit front to back and side to side. Make sure the refrigerator is level. When level the doors should close without assistance. It is normal for water build up and dripping sound in the fridge do to condensation, the air vents and an evaporation pan located behind the cover in the rear of the freezer will eliminate the water if unit is properly leveled. I had the same problem, then i read the user manual. this will also eliminate all the water in the lower compartment.
Jun 28, 2013 | Refrigerators
My dishwasher is leaking out the front. It drips from the lower left hand corner. Any suggestions to what is causing the leak?
Either the tub gasket needs replacement (item 3) in this diagram. or the door base gasket needs replacement. Alternatively, the door vent seal could be leaking. Item 4 in this diagram.
Hope this helps.
Jan 10, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
I have put freon in it seems to cool untill it all leaks out i have noticed my floorboard is full over water i dont think its the heater coil cause it doesnt get hot. My question really is where can i find...
The evaporator is located inside the boxed housing on the firewall incorporating the heater core as well
The lower section of the box has the drain which can be clogged as well I do think. Go under the truck with a coat hanger and try to break loose the clogged tube that pertrudes out from that box
Jun 26, 2010 | 2002 Dodge Durango
Jun 09, 2009 | Frigidaire FAC124 wall/Window Air...
Condinsate Water Leaks Inside Trailer
Where is it dripping from inside the trailer? is a tray under the unit filling up? why does the line drip? where from? is it split? have you put a color dye in condensate to check flow what temp have you got inside your trailer when A/C off?
Jun 08, 2009 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
83 people viewed this question
Top Soleus Heating & Cooling Experts
Coss
Dennis Boxerman
Harjeet Singh
Are you a Soleus Heating and Cooling Expert? Answer questions, earn points and help others
