Question about HP Computers & Internet
When trying to boot up my hp Compaq computer dx2450 I get a code that reads mount error mounting/dev/Root on/sysroot how do I fix this
    Brigadier General:
  • HP Master
  • 3,400 Answers
ginko
  • 19396 Answers
SOURCE: Bios could not be loaded error code
Sure , you need to change the battery in your motherboard. Often it looks like a silver coin. What happens is that your bios setting are reset to default each time you restart PC, before updating bios (that is the solution from hp that you are trying), change the battery.
regards
Posted on Mar 04, 2008
  • 41 Answers
SOURCE: bootsafe error on hp compaq notebook notebook pc while booting
Boot from the XP disc and press R at the first screen. This takes you into Recovery Console. Run these commands:
fixboot c:
fixmbr
exit
The computer will restart and hopefully it will load Windows.
If not, is your computer making clicking sounds?
Posted on Jan 25, 2009
sodeep
  • 3267 Answers
SOURCE: hp dx2450 no sound device installed
You will have to install a new sound card if your guide/handbook does not mention in-built sound capabilities....sodeep
Posted on Mar 20, 2009
PaulRepair
  • 66 Answers
SOURCE: hp compaq dc 7600
When you boot your computer, you need to hit the key to get you into the bios setup. F10, F2 or Del keys are the usual ones.
Once into the bios, change the boot order to make the CD drive first, and then you will boot right to the CD.
Note, you will also have to hit a key when it starts to boot, it will say, hit a key to boot from CD.
If you miss the key to get into the bios, you have to start over again. Sometimes you have to hit the enter bios key over and over to get in there.
Posted on Mar 26, 2009
  • 42 Answers
SOURCE: supervisor password hp dx2450
If you bought it used you should reformat the hard drive and install a fresh OS
Posted on Oct 30, 2009
How do i get to recovery mode for ubuntu?
  1. Switch on your computer.
  2. Wait until the BIOS has finished loading, or has almost finished. (During this time you will probably see a logo of your computer manufacturer.)
  3. Quickly press and hold the Shift key, which will bring up the GNU GRUB menu. (If you see the Ubuntu logo, you've missed the point where you can enter the GRUB menu.)
  4. Select the line which starts with "Advanced options".
  5. Select the line ending with "(recovery mode)", probably the second line, something like: Ubuntu GNU/Linux, with Linux 3.8.0-26-generic (recovery mode)
  6. Press Return and your machine will begin the boot process.
  7. After a few moments, your workstation should display a menu with a number of options. One of the options (you may need to scroll down to the bottom of the list) will be "Drop to root shell prompt". Press Return with this option highlighted.
  8. The root partition is mounted read-only. To mount it read/write, enter the command
    mount -o remount,rw /
  9. If you have /home, /boot, /tmp, or any other mount point on a separate partition, you can mount them with the command
    mount --all (This must be done following step 8 so that /etc/mtab is writable.) Alternatively, you could try selecting "Enable networking" in step 7, though this has been found to cause the system to hang (see https://bugs.launchpad.net/ubuntu/+source/friendly-recovery/+bug/981792).
NOTE 1: If you have Ubuntu Quantal (12.10) or earlier, omit step 4 (the recovery mode menu items are displayed on the top-level menu).
NOTE 2: If you reboot, there is no need to hold the Shift key in step 3. The GNU GRUB menu will continue to be displayed automatically on each boot until a normal startup of Ubuntu completes. To configure GRUB so the menu is always displayed, even after a normal startup, see https://help.ubuntu.com/community/Grub2/Setup.
Oct 16, 2013 | Compaq Computers & Internet
Tip
How to Mount storage devices automatically on linux
Hi..
This will be nice that all your local Hard drives are mounted automatically during the boot. This can be achieved by modifying "fstab" (File System TABle) file. This file is located on /etc/ which would need superuser permissions(root user password) to modify.
How we can alter fstab and set system to mount partitions by itself is explained below..
  1. First Open a terminal and type blkid and press <Enter>
    this will show your local Hard disks with their UUIDs( Universal Unique IDentification). This may look like this
    here 1st column with /dev entries are the links of partitions(in the format /device/<Partition No.>
    2nd column : LABEL describes the Name or Label of partitions. Not all partitions necessarily needs a Label.
    3rd column starting with UUID is the entry shows the UUIDs of the Partition
    4th column shows the File system used in the partitions
  2. So Now we know some important informations about our partitions like their File system type and UUIDs. In linux to use a filesystem, we need to mount it in somewhere in the root directory. This is because of the Hierarchy nature of Linux .
    Usual location of mounted file systems are on /mount/ or /mnt/. I take /mount/ as my default Mount location. Create a new folder with a name(Without any space between words, ex: New_Partition) simillar to Partiton Label or No
    To create folders in /mount/ , we need root permissions.
    Open a terminal and type su and press <Enter>. It will ask for root password. type in root password and press enter.
    Then type mkdir -v /media/<Dir Name>
    ex.: If you want to create New_Drive in /media/ then type mkdir -v /media/New_Drive
    You can also create multiple folders in one step
    ex. You want to create Drive1, Drive2 , Drive3 then you need to type as
    mkdir -v /media/Drive1 /media/Drive2 /media/Drive3
    You may get as this
    Now we created mount points needed to mount the filesystems
  3. Now we need to modify fstab file .
    Default location of fstab is /etc/fstab
    On terminal ( where we typed commands to create folders in /media)
    Before we start editing fstab file, lets make a backup copy of it
    Type on terminal cp -v /etc/fstab /etc/fstab.backup and press <Enter>. You should see as below.
    type sudo gedit & and press <Enter>
    This will open text editor. Click on Open and point it to /etc/fstab
    It will Open fstab file. This may look like this
    Any entry starting with #, will not taken into account. So you can use # for commenting
    Basic structure of fstab file is
    <File System Address> <Mount Point> <Filesystem Type> <Options> <Dump> <Pass>
    File System Address --> Its is the Identifier for the file system. You can use either Links (ex.: /dev/sda2) or Labels (ex.: LABEL="DRIVE1") or UUIDs (ex.: UUID="74c9c3d9-a374-406d-ba41-e030c7d35f5d")
    Mount Point --> This is folder on which the file system mounts. (Refer Step 2) (ex.: /media/Drive2)
    File System Type --> specify the file system (ex ext3, ntfs, fat)
    Options --> Contains more complicated options
    For normal user, its good to set Defaults as Options
    Dump --> set whether to Backup or not. (ex. 0, 1)
    Pass --> set whether to check filesystem before mounting
    example of a edited fstab file is
    After finishing with fstab save it. You may get errors if you don't have permissions to alter fstab. In that case, Open a terminal and type su and press <Enter> and provide Password for root account. and <Enter>
    Then type gedit &.
  4. After saving the file , restart the system, if everything go just good as expected the computer boots up with local partitions mounted on specified locations
If you got any doubts , please contact me
on Mar 18, 2011 | Computers & Internet
Hard drive is not acessible
On another computer download and then burn the Knoppix disk.
Boot the Knoppix disk. Key ctl>alt>f1 to get to console session. Use cfdisk as follows:
cfdisk /dev/sda
or
cfdisk /dev/hda
One of these should you a listing of the partitions on your hard disk. Mount the main partition thus:
mount /dev/sda1 /mnt
or
mount /dev/hda1 /mnt
cd /mnt
Now you can search the partition and save files as needed.
Jan 19, 2013 | HP Computers & Internet
What is grub error 17? how to fix it?
Its GRand Unified Bootloader used in Linux OS.
Normally you get this error when GRUB is not able recognise the partition from which you are trying to boot the system. Make sure the boot partition on your system is recognisable by GRUB (such as EXT3).
You can try to restore the GRUB using the LIVE CD
  1. Boot From Live CD
  2. Open Terminal Window
  3. type >sudo grub
  4. then type : find /boot/grub/stage1
  5. you'll get something like: (hd0, 1)
  6. then type : >root (hd0, 1)
  7. type: > setup (hd0)
  8. >quit
  9. >exit
Remove the Live CD and reboot the system.
Please let me know if you need any further assistance.
Thank you for choosing Fixya
Oct 30, 2009 | Compaq Presario M2000 Notebook
How repair redhat operating system the ask ctrl -d
whoops! You'll have to boot off of an installation disc, maybe Knoppix or Ubuntu if the RedHat install disc doesn't work. Once you do that you should find the old version of your fstab (often with a tilde ~ after it), restore the old version, and go from there!
Oct 15, 2009 | Computers & Internet
Fsck error HELP! HELP ! HELP!
fsck is a file system error check command. Try the root password of nothing, (just the enter key), when ask for the password. Then use the fsck command to repair the file system before rebooting.
fsck - check and repair a Linux file system Try fsck with no options.
SYNOPSIS fsck [ -sACVRTNP ] [ -t fstype ] [filesys ... ] [--] [ fs-specific-options ]
DESCRIPTION fsck is used to check and optionally repair one or more Linux file systems. filesys can be a device name (e.g. /dev/hdc1, /dev/sdb2), a mount point (e.g. /, /usr, /home), or an ext2 label or UUID specifier (e.g. UUID=8868abf6-88c5-4a83-98b8-bfc24057f7bd or LABEL=root). Normally, the fsck program will try to run filesystems on different physical disk drives in parallel to reduce total amount time to check all of the filesystems.
If no filesystems are specified on the command line, and the -A option is not specified, fsck will default to checking filesystems in /etc/fstab serial. This is equivalent to the -As options.
May 27, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Operating system
At a terminal, type:
fdisk -l
as root to see what drives and partitions are on your system. Let's say your partition is /dev/sda1. Next you need a mount point. I like to make and use /sd so type:
mkdir /sd
and to mount it, type:
mount -t ntfs /dev/sda1 /sd
and to view what's on the drive, type:
ls /sd
Jan 09, 2009 | fedora Linux Operating System
Upgrade Ubuntu Error
-While booting your grub bootloader, press "e", enter the edit mode.
-Press "e" on the first line.
-(hd0,0) Change the last 0 to a 2, so it reads: (hd0,2).
-Press ‘b’ to boot.
Good luck.
Jul 29, 2008 | Canonical Ltd. Ubuntu
Acer Aspire 4720 RHEL4 Installation
again install linux in between the installation there will be option select linux boot loader , and one more think linux partition space should more then windows partition
Mar 26, 2008 | Acer Aspire 5100 Notebook
Unable to Install Red Hat Linux Enterprises 4
when the time of installing only you have to take linux boot loader then it will show both operating systems otherwise i think the problem is monitor configuration in linux installing
Mar 24, 2008 | Computers & Internet
Computers & Internet Logo
57 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
