Question about Ricoh Aficio MP-C2551 Multifunction Color Copier
Ricoh machine C2551 screen shows me that the bypass tray of the machine is open unable to print. i closed the tray and again the same signal shows. please advise how to troubleshoot this .
  • 1027 Answers
SOURCE: Ricoh CL3100N
Have you setup for double-sided printing?
Posted on Jul 15, 2008
  • 22 Answers
SOURCE: My printer will only print from bypass tray. Why?
It may be something to do with the paper size settings on printer driver, document print settings or page setup. If for example the computer thinks the paper size is Letter, and the paper in Tray 1/2/3 is A4, it won't print.
Posted on Jan 24, 2009
  • 58 Answers
SOURCE: Printing from the wrong tray on the Ricoh C410 DN
these settings need to be done with the RPCS printer driver, go to properties and then custom settings from there you can tell the printer where to print from.
http://www.websitetoolbox.com/mb/copierquestions
Posted on Jan 29, 2009
  • 161 Answers
SOURCE: SC 366 on CL4000DN
cyan problem --check if cyan pcu is set properly or replace cuan pcu(drum)
Posted on May 06, 2009
SOURCE: Ricoh Aficio C410 bypass tray not picking up and reporting jam
This is happening to me also. The rollers sound like they're turning, but the paper doesn't advance. I then go into th emachine and spin the roller cam a bit and it seems to clear the problem. Any idea what's happening?
Posted on May 13, 2010
How can the lock on the number of photocopies for a particular tray be removed?
Yes, it will show as locked because you have special paper settings on it. If you press the 123 user tools button and then Tray Settings button on the touch screen. You'll find 3 pages of tray settings for tray size, type. Select tray 2 and you can unlock the tray.
Jul 16, 2014 | Ricoh Aficio MP C2551 Multifunction Copier
BYPASS MISFEED, FEED FROM TRAY IS OK
the bypass tray does not have paper sensors, so when you print you need to specify the dimensions of the paper ion the print driver and in the machine system features-tray paper settings..
Jan 20, 2013 | Ricoh Corp Aficio SP 6330N Laser Printer...
Bypass tray locked out for printing
Please the copiers models.The paper tray is selected in the computer.To the Ricoh copiers the by pass cassette selected mannually.
Feb 07, 2012 | Ricoh Office Equipment & Supplies
Ricoh Aficio 2035 all-in-one laser won't print from Bypass Tray
there are two places to set the paper tray on the ricoh aficio 2035 print drivers first make sure you are using the PCL 5 drivers not pcl6 or rpcs then go to the printers folder and set the defaults by right clicking the printer and selecting properties printing preferences, then go into word and select print set up and properties then defaults for printer select bypass tray and select labels enter the correct sheet size for the labels from the drop down box click apply and you should be set.
if this resolves your issue please rate my anser accordingly
regards
Aug 11, 2009 | Office Equipment & Supplies
Can't select 'Bypass Tray' as a print option.
That's strange. I just downloaded it to see what might need to be done, and the bypass tray was available, and it's a standard feature, so it doesn't have to be manually added or anything. I, however, used the Ricoh driver which is identical, because Ricoh owns Gestetner (in case you didn't know) so you may try installing that one. maybe it's a glitch in the Gestetner driver package. The comparable model is Ricoh AP 4510, and you can get it here. I hope this helps:
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/p4510/p4510en.htm
Please rate me :)
May 27, 2009 | Toshiba Estudio 200L Copier
How to print 17 inch paper on Ricoh AP 3800 C
You should just be able to place paper on the tray and then select the bypass tray under "properties", "Paper", then under "tray" select "bypass tray" when printing.
Feb 13, 2009 | Ricoh Aficio 1013F Copier
Reset Duplex Unit Correctly on Ricoh 2232C
Hi There,
The vertical box on the left side of the machine is not closed all the way. Open it, and close it again. It is directly on the left side of the main machine.
Scott K.
Jan 28, 2009 | Ricoh Aficio 1085 Laser Printer
Printing labels on Ricoh 1224C copier
Labels should only be printed through the bypass tray. when printing, go to "properties", "Paper" and change tray from "auto select" to "Bypass tray"
Jan 13, 2009 | Ricoh Aficio 450 Copier
Ricoh Aficio MP-C2551 Multifunction Color Copier Logo
35 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
