Question about Refrigerators
Just bought this bar fridge second hand and the cold does not seem to be circulating throughout the fridge section, however, the freezer is totally freezing up.
Is this just a symptom of these type of bar fridges? Or could there be something blocked or a need to re-gas? What can be done?
  • Ilia Bichin Apr 01, 2015
    This model does not have a fan as it looks manual defrost type.When have you defrost the freezer. In case ice builds up to fast check the door gasket seal. Do not use any sharp objects to defrost
  • 173 Answers
Check if the evaporator fan motor is running
Also check if evaporator pluged with ice
Posted on Apr 01, 2015
  • sarah
    sarah Apr 01, 2015
    Could you direct me to where the evaporator fan might be in the WIM1200wc model. I cannot see it inside the fridge.
Freezers high tempeture light is on and freezer is not getting cold
Door left open usually starts a defrost failure, the evaporator gets blocked with frost and the fan motor can't circulate cold air into the fridge section- while the freezer fan is running, put your hand in front of the slots where the cold air should be blowing in the fridge section- if you don't feel air flow, you have a blockage. Help Me Find My Model Number RepairClinic com
Aug 30, 2016 | Kenmore Refrigerators
I recently scored a bargain Fisher Paykel stand-in fridge/freezer because my original fridge developed a fault. sadly the stand-in Fisher Paykel N405T has an issue of its own, the freezer doesn't really...
Yes ur correct. the fan can be accessed by removing the back panel wall from ur freezer dept. sometimes u will have to remove the bottom panel first a couple screws are all it takes
Mar 31, 2015 | Fisher Refrigerators
Coolzone compact fridge freezer works for a while (a day) then totally defrosts and will not come back on. I turned it off and switched backed on later and it came back on again but keeps doing the same -...
Fan Problems
One of the most common reasons for the freezer to start failing is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food.
You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Other Causes
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster than the fridge can cool it, which will thaw your food.
Hope this would help.
Have a nice day : )
Aug 17, 2011 | Refrigerators
Hi There We have bought a second hand FFA71
If the refrigerator was not demonstrated as functional when purchased, you may have bought a dud.
Aug 03, 2017 | Refrigerators
Freezer seems to be ok. But refrigerator is not cold??? any simple fixes would be greatly appreciated
Somewhere in your fridge should be a fan that circulates air from the freezer section toi the fridge section. Chances are it is not running.
Jun 21, 2010 | Jenn-Air JSD2789GES Side by Side...
Top of freezer not freezing, bottom of fridge is?
Could be the evaporator fan motor is not working. This is what circulates the air from the freezer to the refrigerator section.
Aug 24, 2009 | Refrigerators
Frost in freezer fridge warm
Sounds like the circulating fan behind the rear panel inside the freezer section is starting to go bad, This problem is very hard to diagnose because the fan still spins but at a much lower rate than needed to circulate chilled air thru the freezer and the frig. The minimum cost for parts and labor is around $300.00.
Aug 02, 2009 | Maytag MFD2561HE Bottom Freezer French...
Freezer staying cold but fridge is getting hot
More likely than not there is a blockage of ice bettween the freezer and the refridgerator. most fridges work to get the freezer cold as a priority.Then the cold freezer air is circulated throughout the rest of the unit to keep the fridge cold. Thats why you may hear a fan running in the fridge unit while the compressor is not on. Unplug and open the doors to warm the inside. Look at the plastic piece bettween the two units and remove. See if there is ice build up and use a hair dryer to melt, dry area out and restart the unit by plugging back in or turning temp dial. Hope this helps.
Aug 06, 2008 | Refrigerators
Freezer/fridge won't get cold enough
Madezmom, you have a defrost issue. If your model starts with 106 you more than likley have a bad defrost bi-metal, I will attach a picture of bad one. This sits on the evaporator in the freezer section behind the panel. You will have to remove the shelves and remove the back panel. Defrost the evaporator completely. The part number for the bi-metal is 2196155. See if yours is bulged like the one in the attached photo. If so, that's your problem..Catriver..post back.
Aug 28, 2006 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
74 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
