I need a nordyne gb3bm-036k-a10a heat pump diagram
heatman101
  • 43501 Answers
SOURCE: Nordyne GB5BM T49K C what heat strips do i need or
You need to know how much heat you need (heat loss) and then figure the KW of heat that you need to make that. (3415 BTU's per KW)
Posted on Nov 12, 2009
KLR Monkey
  • 22 Answers
SOURCE: have a new nordyne heat pump installed and em heat
The EM heat is your electric heat element, it probably need to be wired in at the thermostat or air handler, you need a volt/ ohm meter to be sure and a basic knowledge of eletricity, if you don't do not touch it, let a service tech. do it for you, better safe than sorry.
Posted on Feb 01, 2010
  • 3074 Answers
SOURCE: Blower on outside heat pump quit working. Any
may be contact not engaging,fan motor or the capacitor.
Posted on Sep 24, 2010
  • 1033 Answers
SOURCE: WHAT SIZE IS HEAT PUMP Q3RA-036K
Hello, this is a 3 ton unit. There are 12,000 btu per ton. The number 36 in the model number represents rhe tonnage of the heat pump, so 12,000 x 3 = 36,000 which is 3 tons.
Posted on May 10, 2012
  • 1033 Answers
SOURCE: nordyne T3BA-036K trips breaker on outdoor unit immediately will not stay set
Hello, sounds like a short to ground. Check all the wiring to make sure it is not touching any metal. If the wiring appears ok then the compressor windings are shorted to ground and the compressor will need to be replaced.
Posted on Jun 05, 2012
Download for NORDYNE EIEHO15HA WIRING DIAGRAM
For a wiring diagram you will most likely have to request it from Nordyne.
Aug 25, 2017 | Heating & Cooling
Nordyne P3RD-036k starts but the cooling cycles on/off and hums. It gets better after a while. Inspection of electrical board appears theres been arcing on what I think is the contactor
Not quite understanding. So the short cycling goes away after it runs for awhile??? If that's the case I'm assuming you have some loose wiring. Turn power off and check ALL electrical connections. The contactor would not be right on the board so I'm a bit confused. Good Luck!!
Apr 30, 2017 | Heating & Cooling
I need the wiring diagram for the blower on a nordyne furnace
For a wiring diagram, contact Nordyne directly.
Apr 23, 2017 | Heating & Cooling
I need to know the wiring diagram for the thermostat, which is a 24 vac heat pump thermostat TA2000? HELP!!
What is the thermostat brand name? You can do a search in the Internet for the wiring diagram
Jan 20, 2016 | Gibson Nordyne/2 Ton Heat Pump Package...
What year was this model made?
Your unit (B3BV-036K-BB) is a Westinghouse / Nordyne Unit.
Vertical Flow only, 36,000 BTU, 208/230 volts.
You cannot tell the manufacture date from a model number, only from the serial number. Try contacting manufacture with the serial number...
(nordyne.com)
Sep 13, 2014 | Frigidaire Heating & Cooling
I have a heating furnace problem. I need a wiring diagram for the model FEHB-015HA. We had to replace the heating elements and when we tried to hook the wires back up, the white connector(full of wires)...
Hello, Namalee -
I find that the Nordyne brand is what is called a "legacy brand" owned by Nortek Global HVAC.
https://www.nortekhvac.com/
That means Nortek owns the brand name and nothing is currently manufactured with the Nordyne name.
I have looked through the Nortek Global HVAC web pages and have not found any source for a wiring diagram for your model Nordyne furnace.
I suggest you telephone the company (headquaters in O'Fallon, Missouri - Central Time zone) and ask if the company can provide you with a wiring diagram or direct you to a reliable source for it. This is the toll free phone number I found on the Nortek website:
800-422-4328
Jan 12, 2018 | Heating & Cooling
Need a product manual for intertherm model p5rd-036k
http://www.nordyne.com/Literature/455a.pdf
and here ya go. check this web site for your manual.
Hope this is what you want.
Dec 26, 2009 | Intertherm P3RA-036K Air Conditioner
No heat fan running
This is a 10 Seer electric heat package unit. There are few possibilities. Does the blower come on when you put the t-stat on Fan on? If it does, then it is probably the blower time delay relay which is nordyne part# 622181. If the blower doesn't come on at all, check that the blower is getting power and if it is, then the blower motor is bad but could possibly be the capacitor as well. Both should be checked.
Mar 31, 2009 | Intertherm P3RA-036K Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
