Question about Coffee Makers & Espresso Machines
Grinds but won't heat or pump water - Coffee Makers & Espresso Machines
  • Coffee Maker... Master
  • 1,317 Answers
Brand and model number would be a help.
Posted on Apr 01, 2015
I have a Whirlpool Gold washer (MOD# GSQ9669LW0). The washer makes a grinding noise below when in operation. Spins when agitating, but not in rinse mode. Water still pumps out in final spin.
This machine can get items stuck in the drum, the bearings can go bad etc. https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Washing-Machine/38-5-620929-/Whirlpool-Washer-won-t-spin-GSQ9669LW0.
Oct 16, 2017 | Whirlpool Washing Machines
HEATING ISSUES
One way to tell a bad thermostat in a car is if the car overheats frequently even if there is water in the radiator.Stuck open - no heat from heater, temp gauge hardly moves off of cold.
Stuck closed - overheats engine, temp gauge quickly climbs to hot.listen for any rubbing, grinding, or whining noises from the pump. look under water pump while running, if pump is going bad. water will come out of weep hole on the bottom of the pump. good-day!
Apr 07, 2014 | 2005 Kia Sorento
2003 buick regal fan belt wobbling grinding noise over heating
Possible water pump. Remove the belt and grab the pulley , wiggle and spin. Check the other pulleys as well.
Dec 22, 2013 | 2000 Buick Regal
Why won't it heat?
take it bak to bed-bath and beyond, and git another 1.
Nov 22, 2012 | Breville YouBrew 12 Cup Thermal Grind and...
98 Buick is heating up, and when it does it blows cold air. Is that the thermostat going bad or is that the water pump?
1. if your thermostat is going out...you will generally over heat if its stuck in the closed position....initially you might not even notice.but watch your temp gage.
2. If sticking in the open position..rare... your car will require a longer warm up period...operating temp.....heater takes longer to heat up...tough to check in the summer time...if you think its going out then just replace it and be sure to install the new gasket that should come with it....they are cheap and one of the easiest things to fix on a motor...failure to fix it can result in an overheated engine, oil breakdown and seized engine parts
3. Water Pump.
Listen for a faint ( initially ) metal on metal sound from the front of your motor.... easiest thing is to take a cut off broom handle...solid wood....place it on a section of the pump where you won't get hit by the belt or fan blade...then place the stick against your ear and listen...you will hear a faint smooth grinding sound...thats the bearings...if its chattering or very loud, then you have a pump going bad...also just before they go out you should see water dripping from the bottom of the pump or engine, near the pumps location.
You can buy stethoscopes and use water hose etc to check it but the wooden handle is the cheapest.
May 23, 2011 | 1998 Buick Century
Krups grind & brew. It grinds but water
Check to see if your heating plate gets hot when it is on, if it doesn't your water heater/heating pklate has failed.
Nov 20, 2009 | Krups Coffee Makers & Espresso Machines
Grinding noise from passenger side engine
The water pump bearings could be going out and they will make a grinding noise.The water pump doesn't always leak when the bearings are going out.
Sep 01, 2009 | 2002 Dodge Neon
Van overheating
  • it could be a bad water pump if you hear grinding the serpentine belt wraps around the pump and pump has bearing's that are possible went out this means bad water-pump if have changed convert coolant, instead of dex-cool use regular green coolant the dex-cool is a lemon on any gm motors that use it. you may even see if genarl motors will fix problem with vehicle. I hope this was helpful please rate this and thank you!!!
Mar 27, 2009 | 2000 Oldsmobile Silhouette
Water pump
if there are no leaks, then will be a grinding sound
Dec 31, 2008 | 1992 Honda Accord
Coffee Makers & Espresso Machines Logo
50 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
