Question about Philips Televison & Video
HOW CAN I REPAIR A PHILIPS 42INCH TV WITH NO BACKLIGHT
    Top Expert:
  • Philips Master
  • 75,304 Answers
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should be troubles hooted. Contact any service technician. The circuit will differ with models and versions.
It will be best to contact the authorized service center for Philips in this case.
Posted on Apr 01, 2015
  • Philips Master
  • 722 Answers
Hi Harold,
No back lights means the inverter is not working. Well if you can do, please check the supply voltages and the necessary commands ie " inverter on and backlight control" on the inverter card. The needed voltages will be printed near the connector on the inverter board. If these voltages are ok then the inverter board is bad and if any of these are missing you have to look into the board from which the missing voltage is coming. If you can not do all this, try putting a new inverter card. Good luck
  • 720 Answers
Providing it is backlit and not oled or other The inverters hold the backlight in each and can be obtained via eBay for most make and models.best to put the screen on a folded blanket on the floor before attempting to remove back.make sure the power is off and that you don't touch internals.then inspect each invertor count the number for the screen best to replace all together or you will get uneven illumination.
Backlight inverter board for LG TV What is correct part to restore illumination to TV
LED TV Repair Tutorial - Common Symptoms & Solutions ...
? 6:43
https://www.youtube.com/watch?v=8HG7efTMj78
Jan 3, 2014 - Uploaded by ShopJimmy.com
LED TV Repair Review & Overview-Common Problems - Symptoms, Solutions Click Here to BUY TV REPAIR PARTS: ...TVs inputs and outputs, this main board is connected to thebacklight inverter/LED driver via this ribbon cable. ... ofillumination for the screen and the board that drives thatillumination.
LCD TV Repair Tutorial - How to Replace the Backlight ...
? 2:30
https://www.youtube.com/watch?v=s3r1GZCA0K4
Dec 31, 2012 - Uploaded by ShopJimmy.com
Philips TV Repair Flickering Image On TV Screen Tutorial Guide How to ... Inverter on LCD TV Easy Fix Help Click Here to BUYTV REPAIR PARTS: h... ... How to Replace the Backlight Inverter Board in LG & Philips LCD TVs.Missing: restore ‎illumination
Sanyo 42 led lcd tv - Engine cork
Jan 27, 2016 | LG Televison & Video
What is remote control code for 42 inch vizio tv with phillips universal remote
Your Philips remote is universal so you can use its "code search" feature to find a suitable code. The codes are stored in the remote. If a thorough search does not produce a code, you may have to try another universal remote because not ll codes are stored in all remotes.
Oct 07, 2014 | Philips Phillips SRP1103/27 3-Device...
I have had my Philips Flat screen Plasma 42inch TV for about 4 years now and all of a sudden the TV screen will not come on all the tv is showing is the green light flickering and the sound comes through...
Yes, this is caused by a capacitor problem, take the tv apart and on the main PSU board the faulty capacitors will be evident by their bulged appearance. Andrew Eve
Sep 22, 2010 | Philips 42PF7220A 42 in. Plasma Television
How do i fix a Blackout problem with 42inch plasma tevion tv? Or is there a firmware available to fix this problem.
Not firmware prob,95% of the time it ur main video backlight board it dead need it replaced.10% of the time it the power prob.must replaced the power supply board.
Oct 22, 2009 | Televison & Video
Can't find the remote code for Philips 42pfl3603d 42inch LCD TV
Philips codes are: 011, 056, 043, 017. Try them in this order.
Jul 27, 2009 | Philips 42PFL3603D 42 in. LCD TV
Philips 42inch LCD flat screen tv
It could be a Power supply problem or a Main Board problem. Best to have a Pro look at it for you.
Jul 13, 2009 | Philips 42PFL5603D 42 in. LCD HDTV
Long delay before comes on
Honestly, this does not have any real affect on the future performance or operation of the TV so it may not be worth investing in unless you are very bothered by it.
The backlight is something that is not easily repaired by a novice and extremely expensive to repair in general(more or equal to the cost of a new TV).
Good news is that these manuals are written by people who don't have an exact concept of how the words are interpretted. For example, the manual says "the backlight is failing" which means the backlight should be replaced. I am sure it was meant to say "the backlight components are failing" which may mean only a board or small compenent that affects the backlight needs replacing. This may be much cheaper.
May 22, 2009 | Philips 50PFP5332D 50 in. Plasma...
Philips ambilight 42inch plasma
You can fix this yourself with a software upgrade - get the upgrade from Philips website - go to www.usasupport.philips.com, enter your model number, click on the verison of your model ending in /37, and click on "Software & Drivers"; click on the link that says "Firmware Upgrade - Software". Instructions are on the same page - make sure you only transfer the .upg file, not the entire zip file to a portable memory stick.
Jun 08, 2008 | Philips 42PF9630A 42 in. Plasma Television
Plasma T.V
you need to contact phillips,magnavox consumer service which should be 1-800 number or look under www.phillips.com then type in km42010p.
Dec 23, 2007 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
66 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
