Question about Dryers
My westinghouse dryer turns on but only beeps at me and doesn't do anything
When i turn on the dryer it only beeps at me as if the filter is blocked but its not and the dryer won't do anything
  • 173 Answers
Is it electronic unit or older unit
Check door switch and the motor,belt
Posted on Apr 01, 2015
What does beeping mean during dry cycle?
My dryer did the same thing, it was so distrubing noise in the middle of drying cycles, so I turned off the sound switch it went away, now it doesn’t peep any more.
Oct 28, 2017 | Whirlpool Cabrio WTW6600SBT Top Load...
Westinghouse Electric Dryer, Drum doesn't turn on start up, if your spin drum and close door it will start,
Either something is binding the blower wheel up or the motor is bad. The best thing is to take the front of the machine off to access the blower wheel to verify ifanything is indeed binding it.IF not read the next section.
If you can turn the drum and then the dryer starts you have a bad motor. The way the dryer works is when you initially push the start button, electricity is sent to the start winding, or stator, of the motor. This will in turn start the motor turning. From there the stator will drop out of the electrical process and at the same time the run winding, or rotor, will take over and the motor will continie to run. Your stator is damaged, has a burn spot, etc so by you turning the drum, the belt around the drum is moved which is attached to the motor pulley. You basically take the place of the stator. Long story short, you have a bad motor.
Jun 22, 2012 | Westinghouse Laundry Dryer Motor...
I have a Westinghouse 505E dryer and it won't
if its making a buzzing sound the motor is stuck its proberly full of lint it need taken apart and vac out around the motor / or it could be motor bearings worn or the belt brocken you will need to take apart to hav a look
Dec 09, 2011 | Dryers
I have Miele t9800 gas dryer . After 5 or ten minutes the check vent filter light blinks and beeps. Then unit turns off. No heat. The drum turns and air flows. Vent and filter have been thoroughly...
it is not sensing enough air flow. Remove the hose at the rear and check the whole pipe for fluff. Also check that the outside vent is not blocked and any opening flaps are okay.
Feb 25, 2018 | Miele T9800 Electric Dryer
Westinghouse dpf 1411 wont turn on power block
I would recommend contacting Westinghouse customer service team at 1800-701-0680 for further assistance in getting this frame replaced.
Dec 31, 2009 | Westinghouse DPF-1411 Digital Picture...
Westinghouse mastermind 700 flashing HE
I just had to lighten the load. I think that HE means heavy. It works fine now.
Aug 24, 2009 | Westinghouse Washing Machines
Keep getting 3 beeps and the lights come on while its beeping.
Mine has been beeping incessantly as well. Turned out that even though I was cleaning the filter after each load, there was still a ball of lint the size of a tennis ball that was blocking the lint sensor. To fix, I removed the screws from the plastic piece that holds the lint trap and slid it out (it won't come out entirely.) Then I used the mini attachments for my vacuum to remove the lint from the bottom of that space. Once I did that, the dryer has been working flawlessly.
Mar 24, 2008 | Frigidaire FEQ1442ES Electric Dryer
Dryer doesnt do anything besides a loud noise
What kind of loud noise??  A loud electrical noise??  A loud squealing noise??
It's possible that there is a foreign matter inside the filter chamber jamming up the blower fan.  Pull the filter screen out and look down the filter chamber area and see if there is a sock jamming the fan from turning.  If you can pull it out, that should resolve your problem.  If not, you may need to call a qualified LG technician to resolve this issue.
Mar 16, 2008 | LG DLE2532W Electric Dryer
Bosch WTL5400 Condensation Dryer
We continuously had a similar problem with signals forever coming on after just a few dryer loads. The problem was corrected when we took the back off of the dryer and cleaned the recirculating fan and removed a rubber glove that somehow came through the system and blocked the air flow at the heating element. Low air flow is the same as plugged filter and apparently the computer in our German-made Bosch dryer simply says that. We cleaned the area well, removed all traces of the glove and restored the dryer to operation. We have not had the filter problem since. We routinely clean the heater area at the back of the dryer to maintain our sanity. And we now dry our clothes. Bosch never responded to my query.
Dec 28, 2007 | Bosch Axxis WTL 5410 Electric Dryer
Dryers Logo
66 people viewed this question
Top Dryers Experts
