Question about Frigidaire Kitchen Ranges
The main ring of my radiant heat stove top stopped working. The light comes on with the dial but no heat from the ring. All the rest still work. It is model number cpes389dc5
  • 173 Answers
Check out the element,wires and the switch
Posted on Apr 01, 2015
Americana stove not heating but lights come on
get in an electricians to check what looks good but isn't
May 29, 2017 | Ovens
Hello a couple of our stove tops rings intermittently work and now one has stopped working altogether. The light comes on but the ring does not heat up. Any advice? Thanks so much
Hi unplug the stove and remove the two screws that hold the top down, holding the burners, check for burned wires going to and from all burners I think you may have wires that are shorted out , or the element itself is burn out , you can check this with a ome meter, by putting each wire on the ends of the element , I hope you know how to use a meter if not write back and I will walk you though it , Just look around very carful
Feb 21, 2011 | Maytag CWE4800A Electric Single Oven
I have a 4 burner Jenn-Air JED8430ADB electric radiant heat stove that has recently stopped working. It has been installed for many years (came with the house) and worked fine until now. When I turn one...
The cook top is connected to 220 volts. In the house wiring there are two legs each 115 volts. Usually they connect with a red wire, black wire and the third a neutral. It is likely that at the connection to the unit or at the electrical box a connection has failed or the 220 volt circuit breaker has failed on one leg. A qualified electrician needs to do the repair!
project1-nbbnxwvnfadegsi2zsme4jri-2-2.jpg Hope this helps?
May 04, 2017 | Jenn-Air JED8430 Electric Cooktop
Broken glass top inset ''burner ring''
If you are referring to the bakelight material, this is an insulating compound and the burner still may work. I would not use this long term in this manner however. This material insulates as well as helping maintain an even heat transfer of the burner. Long term use, may cause damage to the cooktop. The burners are replaceable, but the prices vary depending on the size of the burner. The part numbers are as follows:
6" radiant heat burner - WB30T10129
8" radiant heat burner - WB30T10132
9" radiant dual heat burner - WB30T10133
You can view these parts at searspartsdirect.com under the "Cooktop" heading. You may find the parts cheaper at these other websites, by searching for them using the part numbers provided:
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary at the other websites. Sometimes they may not carry the model number, but the part numbers are still listed.
If you have further questions, please post back and let me know. I hope this helps you.
Dec 22, 2009 | GE JBP65 Electric Kitchen Range
Kenmore gas stove Model 790
It could be that the sensor wire that controls the main gas valve is out of position. It should sit in the pilot light flame.
Look, and adjust if needed.
If it's ok, then you need a replacement main gas safety valve.
This should only be fitted by qualified personnel.
They do give up eventually after years of heating, and fail safe.
Dec 31, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Electrical problem w/ magic chef electric range CER3540AAA
hi thanks for the question i would check to see if theres 240 volts at the stove if only 110 volts at stove you will not get any heat but lights will work check that replace fuses in main panel for the stove thanks the appliance doc
Sep 27, 2008 | Kitchen Ranges
MY HOTPOINT SELF CLEANING STOVE
how do I get my self cleaning to come on in my hotpoint stove
May 22, 2008 | Ovens
Kitchen Ranges Logo
76 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
