Question about Sharp El-520x Advanced Scientific Calculator White Bp Package Of 5
How do I convert a degree angle into a decimal
    Top Expert:
  • Sharp Master
  • 10,875 Answers
How do i enter 50deg,25minutes,23seconds into a casio fx-9750 plus
In Run>Mat press the OPTN key, Then F6:> to move to the next page of options. You will see the ANGL tab as on the screen capture (above F5 key.
Press F5. You will see what follows.
Type in 50, press the F4 key, 25 then F4, 23 then F4. Press EXE. you get the result in decimal degrees as on the screen capture. To convert from DMS to D.D, or from D.D to DMS, vice-versa, press the F5 key
Jan 05, 2013 | Casio FX-9750GPlus Calculator
I am trying to locate the minute key on my casio fx-9750GII. I can find the degree and second key but not the minute key.
In Run(/Mat) press the OPTN key. Then press F6 to find other options.
Press F5:ANGL Here is what you see.
To enter an angle in decimal degrees, type in a decimal value then
press the F1:key to insert the degree symbol.
To enter an angle value in DMS, press the F4 key after each part.
See the next screen capture.
The menu option key above the F5 key, converts from DMS to DD
Sep 08, 2011 | Casio FX-9750GPlus Calculator
How do I convert DMS to DD with a ti84 plus?
To enter an angle in DMS format, enter the number of degrees, 2ND [ANGLE] 1 to indicate degrees, enter the number of minutes, 2ND [ANGLE] 2 to indicate minutes, enter the number of seconds, ALPHA ["], then ENTER.
ANGLE is on the APPS key, " is on the + key.
You can convert an angle from decimal to DMS with the ->DMS command, 2ND [ANGLE] 4
Jan 10, 2011 | Office Equipment & Supplies
T-85 d.ms to dec degrees
To convert a value in DMS form to decimal, use the degree command in the MATH ANGLE MENU.
2ND [MATH] F3 to bring up the menu. The degree command is F1. F4 converts back to DMS.
Sep 02, 2010 | Texas Instruments TI-85 Calculator
How to switch from the decimal degree to degrees, minutes, seconds
Keys 1. I displays the following menu that lets you change the angle mode setting to DEG, RAD, and GRD without affecting the value in the display. DEG Sets degree mode. RAD Sets radian mode. GRD Sets gradient mode. The default setting is DEG. 2. = displays a menu that lets you specify the unit of an angle. º Specifies degrees. å Specifies minutes. æ Specifies seconds. r Specifies radians. g Specifies gradients. DMS Lets you convert an angle from decimal degrees to DMS notation. Notes · The examples on the transparency masters assume all default settings. · Angles with a trig function ignore the angle mode setting and display results in the original unit. Otherwise, angles (without a trig function) are converted and displayed according to the angle mode setting. · You enter decimal-degree angles the same as you would any other number. · For decimal/DMS conversions, the calculator interprets all values as degrees, regardless of the angle-unit setting. · DMS angles are entered as º (degrees), ´ (minutes), and ´´ (seconds You watched 2 videos that were 2:05 (2 hours and 5 minutes) and 1:46 (1 hour and 46 minutes) in length. How long did you watch videos? = Press Display 2 = ¡ å æ r g & - DEG < 2¡ DEG 5 =" ¡ å æ r g & - DEG <T 1 = < 2¡ 5å + 1¡ DEG 46=" << 2¡ 5å + 1¡ 46å ' 3.85 DEG =! % ¾DMS ---- DEG << Ans ¾ DMS ' 3¡ 51å 0æ DEG Degrees, Minutes, and Seconds to Decimal © 1999 TEXAS INSTRUMENTS INCORPORATED TI-30X ùS: A Guide for Teachers 96 How much is 2/3 of an hour in hours, minutes, and seconds? = Press Display 2 N 3 2®3 DEG =! % ¾DMS ---- DEG << 2®3 ¾ DMS ' 0¡ 40å 0æ DEG
Aug 19, 2010 | Texas Instruments TI-30 XIIS Calculator
How do I get from degrees to radians? For some reason my TI-84 will not convert degrees to radians.
Press the [MODE] key to access the mode comfiguration screen .
Set angle unit to to radian (see above)
Enter angle value in Decimal degrees only, use the [2nd][ANGLE] key sequence to have access to the degree symbol. The degree symbol must imperatively appear at the end of the angle value.
Here are some examples
If you use angle values in DMS, it will not be converted to radians, but to decimal degrees.
If you omit the degree symbol there is no conversion.
A general formula is Pi radians =180 degrees
Feb 10, 2010 | Texas Instruments TI-84 Plus Calculator
How do I find degrees minutes and seconds on my ti 84 plus?
On this family of calculators, you do as follows
  1. Enter the first number (degrees), ex:15
  2. Press [2nd][APPS] (ANGLE) to access the Angle functions
  3. Select [1: degree symbol] [ENTER]
  4. Main screen shows 15 deg
  5. Enter the minutes, ex 25
  6. Press [2nd] [APPS](ANGLE) to access Angle functions
  7. Select [2:' apostrophe] [ENTER]
  8. Screen echoes 15 deg 25'
  9. Enter the seconds number, ex 32
  10. Press [ALPHA][+] (") to access the double quotation mark.
  11. Screen echoes 15 deg 25' 32"
  12. Press [ENTER]
  13. Calculator converts this in decimal degrees 15.42555556
To convert this back to DMS, press [ANGLE][|=>DMS][ENTER] and the calculator displays the original value 15 deg 25' 32"
Jan 11, 2010 | Texas Instruments TI-84 Plus Calculator
If a textbook problem is given in DMS notation, how do I enter the DMS notation into the TI84 to get decimal degrees?
Press [2nd][+] (") to access the double quotation mark
Press [ENTER]
Jan 06, 2010 | Texas Instruments TI-85 Calculator
HOW DO YOU USE THE DEGREES MINUTE SECONDS FUNCTION
To convert an angle from degrees (decimal degrees) to the sexagesimal notation (deg, min, seconds) use the key [DMS] the one between [(-) and [hyp].
Everytime you press the key, the displayed result is cast in the other form
EX; 12.58 [DMS] gives 12 deg 34 min 48 sec.
Suggestion: If you are doing many calculations with the sexagesimal format, use the decimal degree format, and only when you find the final result do you convert it to DMS.
Hope it helps.
Sep 30, 2009 | Casio FX-115ES Scientific Calculator
I can't get the answer in decimal form. Need to convert from DMS to decimal.
Use [2nd][MATH][2:Angle] [9:-->DD] [ENTER][ENTER] . To have meaningful results make sure angle unit is in degrees.
Hope it helps.
Sep 29, 2009 | Texas Instruments TI-89 Calculator
Sharp El-520x Advanced Scientific Calculator White Bp Package Of 5 Logo
97 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
