Question about Canon PIXMA MP287 ALL-IN-ONE INKJET PRINTER
What is error po3? - Canon PIXMA MP287 ALL-IN-ONE INKJET PRINTER
Finding the name or formula of polyatomic ions
(PO_3)^(3-) Phosphite
(ClO)^- Hypochlorite
Apr 04, 2014 | Computers & Internet
My Kia optima 2004 is cutting off while driving coming to a stop or just sitting at the light. Code 335 po3 came up on the code reader. also when i accelerate to 20mph my car jerks or jump
The crank position sensor is going bad. Need to replace it and below is some instructions how to do it yourself.
    • Raise the hood of the car and locate the crankshaft sensor. It is at the lower right of the exhaust manifold. The sensor is installed in the trans axle housing that is bolted to the engine.
    • Remove the single bolt holding the crankshaft sensor in place. Twist the sensor back and forth to unseat the O-ring seal. Pull the sensor out and unplug the wiring connector.
    • Lubricate the O-ring of the new sensor with mineral oil. This will aid in a smooth installation of the new sensor. Push the sensor into the location until it seats. Turn the mounting tab on the sensor until the mounting holes line up. Install the bolt. Snug the bolt, being sure not to over tighten and strip the threads in the aluminum trans axle housing. Plug the sensor connector into the engine harness connector. Start the engine.
Dec 01, 2013 | Vehicle Parts & Accessories
Error code P03. It won't print, it doesn't make any noise when I turn it on, and I don't see any traces of paper.
Error code PO3 is caused by Timing Disk dirty / damaged.
Please use this methods
1. Check the timing disk sensor located to the left of the printer
2. Check and clean the board.
And start to print... thanks
Aug 11, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
My Canon MP258 is Displaying PO3 Error what i will do?
my canon mp 258 printer is shown an po3 error
please give any solution
May 26, 2011 | Office Equipment & Supplies
My mp280 shows po3 error this is not listed in the manual what does it mean , please
P03 is a line feed error. It has to do with an electronic error inside your printer.
Either your timing disk sensor is bad on you main logic board is bad. It either needs to be repaired or replaced...
You can go to Canon's website for an estimate on the cost of repair. That way you can decide to fix or replace.
http://www.usa.canon.com/cusa/consumer?pageKeyCode=repairLanding
Jan 30, 2011 | Canon Office Equipment & Supplies
I tried to pop3 my yahoo accopunt with windows
Here is a website telling how to setup yahoo on outlook. I know you needed windows mail, but the two are almost identical. http://help.yahoo.com/l/us/yahoo/mail/original/mailplus/pop/pop-06.html
Nov 14, 2009 | Yahoo Mail
PARAMETERS FOR RCA
hold menue button in. push power once vol up once.vol up to76 ch to po1 po3  have fun.
Nov 13, 2008 | RCA 27V530T 27" TV
Canon PIXMA MP287 ALL-IN-ONE INKJET PRINTER Logo
43 people viewed this question
old marine
old marine
