Question about Cuisinart CBK-100 2-lb. Bread Maker with Brushed Stainless Housing
The shaft is not turning . The machine just clicks.
    Genius:
  • Cuisinart Master
  • 1,280 Answers
If you have chosen whole wheat setting (and even on some machines just regular white bread) your machine may not start mixing immediately. They warm the ingredients first. Black and Decker machines are like that. If your machine hasn't started mixing within 1/2 after you pushed the start button then you have problem. Give it at least that half hour before assuming there is something wrong. The clicking sound you hear is the heating element gently warming to get the ingredients to the perfect temperature.
Posted on Apr 02, 2015
How to oil the handwheel on a singer 4530 that has starting making a clicking sound in that area.
You buy some sewing machine oil from a sewing machine shop and then put a few drops on the shaft of the wheel as you turn it.
Jan 27, 2017 | Singer Sewing Machines
Washing machine not selecting cycles. It is stuck on fast wash, dial moves but wont click and select any other cycle.
Hi
the problem is the shaft on the control knob
is cracked so the knob turns but won't grip
the shaft on the control panel
requires an new knob
Jun 06, 2016 | Hotpoint Washing Machines
How to free a seized main shaft
Sounds like the clutch: here is a link to the instruction manual:
http://www.aisin.at/assets/manuals/RSSDENG.pdf
It has a fault fining section page 50
Jun 12, 2014 | Toyota STF17 Sewing Machine
PFAFF SEWING MACHINE, USED MACHINE, JUST BOUGHT. MACHINE SEEMS TO BE VERY CLEAN, HOWEVER MOTOR ON OUTSIDE TURNS FURIOUSLY, BUT INTERIOR SHAFT WILL NOT TURN. I have cleaned and oiled, can this be fixed...
Try holding the hand wheel firmly and turning the smaller knob in it's center clockwise until it clicks. To fill bobbins, you have to stop the needle from moving by turning that knob counterclockwise and it sounds like that's the problem.
Aug 12, 2011 | Vacuums
I cleaned my Flair air purifier, The motor turns on but not the fan even after lubricating the fan shaft and giving the fan blades a little push. Any suggestions on how to get this going?
The Flair is no longer manufactured nor serviced by EcoQuest, and the company is now Vollara. If what you're hearing is the fan motor (there is no other motor associated with this machine), it might mean that either it's totally seized up, or that the oil just has not penetrated deeply enough.
1) Turn the machine over and remove the large screw in the bottom. The chassis will then slide out (I assume you've already done this in order to reach the fan shaft.)
2) Firmly pull on the fan blades near the center in order to pull them free of the shaft.
3) Turn the chassis on its back, so the fan shaft points up. Drip a small amount of lightweight oil (sewing machine, hair clipper, 3-in-1) on the shaft and turn it manually to work the oil down the shaft. Continue doing this if you feel the shaft loosening up.
4) Set the chassis upright, tilt it forward, and drip a small amount of oil on the rear opening to the fan shaft. Continue manually turning the shaft and tilting the machine to work the oil in.
5) Replace the fan blades and turn on the machine, depressing the safety switch manually, to see if the fan will begin to turn.
If it won't turn, it might mean that the fan motor is entirely seized up. You may be able to find a local small appliance repair person who could replace that motor.
Your other option is to call Vollara customer service at 800-989-2299 and ask them to explain your options. Use #16618 if you need a dealer referral number.
Feb 11, 2011 | Ecoquest Flair Air Purifier
The lower shaft on my ryobi stoped turning, how do i fix this problem.
You didn't quite give me enough info on which machine you have ... but if it is one that allows the lower half of the shaft to be removed for using other implements, disconnect the shaft and try to turn the inner splined shaft by hand and see if the head turns, if not you may have a broken shaft cable or a frozen bearing in the shaft head...this will necessitate removal of the head and replacement of either the shaft cable or the machine head...if all is working then check the shaft going to the clutch...hope this helps... ;-D
Jul 13, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Clicking noise
center bearing that holds the shaft is bad and lets the shaft move
Mar 21, 2008 | Maytag Neptune MAH5500B Front Load Washer
Shaft not turning
Unfortunately Regal ware no longer supply spare parts for there breadmakers, because their motto about dedication obviously didn't apply to bread machines. I think youe best bet would be to take the pan and machine to a local machine shop and see if they could make you one up - if they could it shouldn't be too expensive. Hope this helps :)
Feb 13, 2007 | Regal Ware K6725 Kitchen Pro Bread Maker
Cuisinart CBK-100 2-lb. Bread Maker with Brushed Stainless Housing Logo
147 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dale Anderson
Dale Anderson
Level 1 Expert
Tom Chichester
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
