Question about Fuses/Circuit Breakers/Relays Barry Grant Fuel Pump Relay & Wiring Harness - 30 Amp
Where is the fuses located in the trailer? - Fuses/Circuit Breakers/Relays Barry Grant Fuel Pump Relay & Wiring Harness - 30 Amp
Need the fuse number for rear trailer lamp for 2006 Lincoln is the rear trailer parking lamp fuse located 2006 navigator
trailer lights are fused in the main fuse box of the car
tail lights on a trailer are the same fuse for tail lights of the car , the same for brake lights and indicators
Dec 23, 2016 | Lincoln Cars & Trucks
Trailer fuses
Should not be any fuses other than the basic ones for the lights. Check any plug in connectors and make sure you have a good ground wire from trailer to truck.
Mar 25, 2014 | Honda Pilot Cars & Trucks
Tail lights on trailer not working f250
did you check the trailer /tow fuse under hood in truck? located lfet side rear near firewall top. should be fuse for towing / trailer.DW Mylin
Dec 01, 2012 | 2008 Ford F 250 Super Duty 4WD
Where is the trailer fuse located on a 2012 jeep grand cheroke
depends if the person , installing trailer setup
used the factory kit
or just cut in to your wiring.
my 2010 WK has a fuse.
why not say what fails.? first.
brakes
blinkers L and R
parking lights.
and if the cars lights are effected?????? or hazards.
which location, will the fuses are all under-hood.
the operators guide names them all , lost that.
the factory kit comes with trailer relays to add to system.
this protects the system best from trailers that short out.
best is to set it up like that. using real jeep kit.
but we can fix yours. as soon as you answer the questions.
im not posted all fuses for all 4 circuits,
fess up and get free answers.
Jan 15, 2012 | 2012 Jeep Grand Cherokee
Which fuse is for the trailer lights
The aux fuse panel in the engine compartment on the 04-08 has nothing to do with the trailer lights ( that is ABS, clock spring illumination, 4WD and the diode for the AC compressor ).
All the fuses are in the CJB ( aka Central Junction Box, cab fuse panel ):
The trailer parking lamps
Fuse #10 and relay #201
Trailer Stop / turn lamps
R: fuse #36
L: fuse #42
There are a few others with the reversing lamps and the battery charge circuit ( for the 7 pin adapter ).
Bit easier than trying to read each line, is to download a PDF copy from Ford, so you can search on keywords ( in this case trailer )
https://www.fleet.ford.com/maintenance/owners_manuals/default.asp
Dec 26, 2009 | 2005 Ford F-150
When i hook up my trailer lights it blows the fuse
I replaced some clearance ligts on my stock trailer and when I plug the trailer in it blows a fuse in the truck
Nov 14, 2009 | 2002 Ford F250 Super Duty SuperCab
F150 Ford 1998 is there a fuse for a trailer and where is it located? Thank you
There are a few fuses for the trailer tow adapter.
1st, is theodd location on the 97-98, engine mini fuse panel has a 20 A fuse forthe stop / turn lamps. Have seen it covered in tape from the factory onsome 97-98 MY trucks.
This is on page 142 in the owners 1997 manual, all the revisions for the 1998 owners manual I have seen do not include this fuse box for some reason.
Download a PDF version from Ford, for the 1997 MY at :
This is a picture of the Power Distribution Box, additional relay box and engine mini fuse panel with the covers off. The 20A in the upper right panel with the red base, is the trailer stop/turn fuse.
The others :
1. Power Distribution Panel / engine compartment fuse panel
Fuse #1 - Trailer tow back-up and tail lamps
Fuse #16 - Trailer tow battery charge and stop/turn lamps
Fuse #28 - Trailer tow electronic brake
2. Instrument Panel Fuses ( cab fuse panel by hood release )
#23 - trailer tow battery charge relay
Nov 11, 2009 | 1998 Ford F150 Regular Cab
I HAVE NO VOLTAGE AT THE TRAILER CONNECTION
1st, is the odd location on the 97-98, engine mini fuse panel has a 20 A fuse for the stop / turn lamps. Have seen it covered in tape from the factory on some 97 MY trucks.
This is on page 142 in the owners manual.
If you see one, you can download a PDF version from Ford at :
The others :
Nov 01, 2009 | 1997 Ford F150 Regular Cab
Fuses/Circuit Breakers/Relays Barry Grant Fuel Pump Relay & Wiring Harness - 30 Amp Logo
613 people viewed this question
Top Fuses/Circuit Breakers/Relays Measuring Tools & Sensors Experts
Thomas Perkins
Thomas Perkins
D. E. Hev
Ngoro
Ngoro
Are you a Fuses/Circuit Breakers/Relays Measuring Tool and Sensor Expert? Answer questions, earn points and help others
