How do I change bearing degrees into decimal points?
    Top Expert:
  • 10,875 Answers
The words FIX DEG appear on the screen and I can't get rid of it. It doesn't calculate properly
DEG says that the angle unit is set to degrees. You can change it to RADians, or GRADs. However much you want to get rid of all of them you will always have one of them. Learn to live with them.
FIX says that the decimal displays will always show a fixed number of decimals. You can decide how many you keep. Apparently your calculator is configured not to show any decimal digits: the number of fixed digits is set to zero. Change it to some other number
There are other display formats : Engineering ENG, and Scientific (SCI)
There is another format (possibly 2) called Norm 1 or Norm 2.
Set you calculator to one of the Normal formats.
Press SHIFT MODE to enter (Setup) and configure.
Advice: Learn to use your calculator. The best way to achieve mastery is to look inside the manual whenever you do not understand something.
Dec 06, 2013 | Casio FX-300 Plus Scientific Calculator...
Enter degree minutes seconds
Enter the degrees, a decimal point, then two digits for the minutes followed by two digits for the seconds (then followed by any fractional seconds). You can then convert to decimal degrees with the HMS-> function.
For example, to enter 1 degree 36 minutes 24 seconds, press 1 . 3 6 2 4 ALPHA ALPHA "H" "M" "S" right-shift "0" ENTER
Jun 30, 2013 | HP 50g Graphic Calculator
OCT mode to DEG mode
OCT and Degree have nothing to do one with the other. Your calculator is in the Base-N computational mode. You have to change it to DECimal. Look for a key that has DEC marked next to it. You might have to press the SHIFT, 2nd or 2nd F key first.
Once the calculator is in Decimal numeration (press 8 or 9 to see if the screen displays the number entered) change the angle unit from whatever it is now (radian or gradian) to degrees. It is possible that it will show the DEG indicator after you switch to Decimal from Octal.
I am sorry but your not disclosing the make and model of the calculator does not help.
Jun 14, 2012 | Office Equipment & Supplies
Decimal point
To switch the radix mark between the US and European formats, turn the calculator off. Press and hold the decimal point key, then press and release the ON key, then finally release the decimal point key.
Dec 29, 2011 | Office Equipment & Supplies
How do i enter 46degrees 15minutes into my ti-36x calculator?
Enter DMS (Degrees/Minutes/Seconds) values as D.MMSSs, using 0s as necessary:
  • D degrees (0-7 digits)
  • . decimal-point separator
  • MM minutes (must be 2 digits)
  • SS seconds (must be 2 digits)
  • s fractional part of a second
For example, enter
  • 46° 15' as 46.15.
  • 179° 9' 2.54" as 179.090254, note the 0s in front of the 9 and 2.
Before using a DMS value in a calculation, you must convert it to decimal with [2nd] [>DD].
Jan 13, 2011 | Texas Instruments TI-36 X Solar Calculator
My casio fx-992s is showing fix and deg on the screen. I think the "fix" is causing me a problem but I can't get rid of it. All my decimals are being rounded up to whole numbers! Thanks
The DEG is merely indicating that the angular mode is set to degrees. If you want to change it to radians or grads, press SHIFT MODE and make your selection.
Likewise, the FIX is merely indicating that the calculator is displaying numbers in fixed decimal notation. If you're not seeing any digits to the right of the decimal point, then you're in FIX 0 mode. To change it, press SHIFT MODE. You can choose FIX and the calculator will prompt for the number of digits, or you can select NORM.
Nov 29, 2010 | Casio Office Equipment & Supplies
How to set the decimal place to 3 places on a casio fx 300ms calculator
Decimal Point and Separator Symbols
You can use the display setup (Disp) screen to specify the symbols you want for the decimal point and 3-digit separator.
• To change the decimal point and separator symbol setting, press the MODE key a number of times until you reach the setup screen shown below.
Display the selection screen. (Disp) 1.
Press the number key ( 1 or 2) that corresponds to the setting you want to use.
1(Dot): Period decimal point, comma separator
2(Comma): Comma decimal point, period separator
Nov 27, 2010 | Casio FX-300MS Calculator
My decimal changed to a comma, how do i change it back?
P12c display from Comma to Point This document describes how to change the display of the decimal point on the HP 12C (HP12C) Calculator from a comma (commas) back to a decimal point.
Instructions
  1. Turn off the calculator.
  2. Hold down the decimal point.
  3. Continue to hold the decimal point key, while turning on the calculator.
The comma should change back to a decimal point.
Explanation The comma is the European equivalent of the decimal point.
This procedure is also applicable to HP12CP (Hewlett-Packard 12c Platinum) and HP12CPA (Hewlett-Packard 12c Platinum 25th Anniversary Edition).
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Feb 04, 2010 | HP 12c Calculator
There is a comma where the decimal point should be and vise versa.
From HP12c FAQ:
This document describes how to change the display of the decimal point on the HP 12C Calculator from a comma back to a decimal point. Instructions
The comma should change back to a decimal point. Explanation The comma is the European equivalent of the decimal point. *
For more information about your machine (data sheets, learning modules, manuals, FAQs, etc), check this link:
http://h10010.www1.hp.com/wwpc/us/en/sm/WF05a/215348-215348-64232-20036-215349-33525.html
Aug 08, 2009 | HP 12c Calculator
jasbo
jasbo
