Both fridge and freezer seem to work fine, but both internal LED lights flash like a strobe light when opening either door. Have powered off and reset filter, neither worked.
I had the same problem but instead of throwing a couple hundred dollars away I decided to let my lights stay on all the time inside the fridge. All I did was pop the filter switch out so it wouldn't trigger when the door was closed. No more flickering and the hole doesn't irritate me like the rave party inside my fridge did????
This worked for me too. The only difference in what I did was I left the switch in place, and using some male connectors and a small piece of 16 gauge wire, I jumped past the switch closing the circuit and letting the lights stay on 24/7.
How does switch come out? I can not find anything on internet, they obviously don't want you to know.
This is a common problem. Look on the back of the circuit board for R15. This resistor burns out. I removed it and soldered in a 1/4 watt 120 ohm resistor and it works fine now. You have to use a very small soldering tip to avoid burning the pad off the board. Bend your resistor leads down on the end so that the resistor lays flat against the board before soldering to avoid breaking the solder joint after the repair.
That is a sign that the led driver is failing in the unit and needs to be replaced what i would do is locate the led power wires and mount an external driver to operate them,to find the drive voltage connect a verable dc power supply and then wind the voltage up 0 to 30 volts
2 amps max
http://www.ebay.com/itm/DC-Power-Supply-0-30V-5A-Adjustable-Variable-digital-display-Switching-110V-220V-/251956886769?hash=item3aa9ccfcf1:g:DpYAAOSwqu9VLdi-
SOURCE: fridge and freezer not cold.
Read this article on Compressor Relays to understand the problem you are having. It will explain in detail what to do to repair your machine.
Thanks,
Bill
SOURCE: no power to control unit in fridge
Turns out we had a bad control board. One of the coponets was blown and it had to be replaced. $400.00 and its good as new.
SOURCE: Inside LED and light on fridge do not work.
First check your light bulb to see if it's good, if it is replace the door sw( it's the switch the door hits when closing ), It can be a pain to remove but that's the only parts that make up the light circut hope this helps
SOURCE: FREEZER OK / FRIDGE SIDE NO INTERNAL LIGHT & NOISE
your refrig has a bad electronic control heres the part #W10135090 the noise your hearing is an internal relay on the board buzzing trying to turn the lights on. i found the part at sears.com and it was ony about 80 bucks it is a plug and play part so you should be able to replace it yourself. the board is located in the white box next to the compressor in the back of your refrig. thanks peyton
SOURCE: Whirlpool GD5RHAXNT00 Side By Side Refrigerator
your problem on this is the main control in the compressor compartment. unplug your refrig then remove this control unplug all connectors and reconnect. this will probably get you working temporarily In almost every case I've seen we ended up replacing the control board. thx peyton
did you figure out how to fix the strobe light issue? I'm having the same one.
I am too. I have a Maytag side by side.
We are having the same issue but not sure how to fix it. Doesn't seem like it would be the light or the switch since both the fridge and freezer do it in at the exact same time.
