Question about Little Tikes Toys
I am looking for instructions for assembly instructions for little tikes construction dump truck 3 - in - sand box pool
5 Suggested Answers
  • 55 Answers
SOURCE: I have lost the assembly instructions for the
You might be able to download the instructions from the Little Tikes website.
http://www.littletikes.com/consumerservice/toy_assembly.aspx
Posted on Aug 01, 2009
  • 973 Answers
SOURCE: little tikes sand and sea play table replacement
I would contact http://www.littletikes.com/consumerservice/replacementparts.aspx
Posted on Jun 05, 2010
SOURCE: Are assembly instructions for the
Yes they are, this is what I got of the little tykes website, it's the ADOBE instructions, 62451R100-2-06.pdf
I hope it will be of help, have a great day :)
Posted on Aug 19, 2010
rossthis
SOURCE: i need assembly instructions for little tikes cozy coupe
The video on Youtube is very easy to followit has step by step instructions on how to put it together
http://www.youtube.com/watch?v=q3j4svB7mnA
Posted on Jan 04, 2012
I need to find a drain plug for my old blue little tikes swimming pool.
Here's a site I found about how they made a drain plug,I looked all over and couldn't find one,home depot or lowe's has plumbing fittings that will work. Converting Little Tikes pool into duck pond
Jul 16, 2017 | Pool & Spa
Can't assemble the push handle in little tikes 3 in 1 purple
Hi Blanca,
We'd recommend you contact Little Tikes direct for assistance -
Mar 05, 2014 | Little Tikes 3 in 1 Trike Purple
I need assembly instructions for the Little Tikes Cozy truck
I have just downloaded the instructions for one of their cozy trucks at littletikes.co.uk
I would expect the instructions you are seeking would also be available.
Good luck.
Jun 27, 2011 | Little Tikes Cozy Cruiser Twin Seat Jogger...
Sand Leaking From Filter into Pool. When my filter is running I am experiencing sand in the bottom of my pool from the filter. What can be causing that?
There is only one thing that can cause sand to come back into the pool from a sand filter. The internal assembly, called the lateral assembly, is either cracked or broken. This is an easy fix and should cost you around $70 to replace the whole thing. You need to unscrew the bottom drain cap on the filter to remove the water in the tank. Then, remove the multiport valve on top of the filter. Take a shop vac and remove the sand in the filter. If the sand hasn't been replaced in the last 3-5 years, this would be a great time to do that since you already have the sand out anyway. Then, remove the lateral assembly and inspect the entire thing. After you replace the lateral assembly, you'll need to fill the sand filter tank 1/2 full of water before adding fresh sand. This is done to cushion the laterals from the weight of the sand. Cover the hole in the top of the lateral assembly pipe with a cup or duct tape to prevent any sand from getting inside the pipe (the sand will come out into the pool if it gets into the pipe). Fill the tank 3/4 full of pool filter sand. Make sure it is genuine silica pool filter sand from a pool company. A lot of big box and home improvement stores sell play sand as filter sand. This will cause you more problems!
Jun 16, 2011 | Hayward SAND FILTER, PRO SERIES
My cooking creations kitchen didn`t come with an assembly instruction manual
Here is the link to download assembly instructions, though I did not see "cooking creations" listed, you may try entering the exact model number:
http://www.littletikes.com/consumerservice/little-tikes-assembly-instructions.aspx
Note, that Little Tikes does not post all assembly directions- some products do not have them online. However, if you contact them via this form, they can send them to you:
http://www.littletikes.com/consumerservice/Contact-Us.aspx
Just select "Product Help" from the subject field. Good luck to you, hope this helps!
Jan 09, 2011 | Little Tikes Toys
Little tikes crazy coupe
Here are the instructions on how to assemble the Cozy Coupe. Hope this helps!
http://www.littletikes.com/pdf/4855CozyCoupe.pdf
Blessings,
The Grand Toy Wizard
http://www.thegrandtoywizard.com/store
Jul 16, 2009 | Little Tikes Cozy Coupe
Sand is in pool after backwash
A little sand is normal, called a puff back. Anything more then a good pinch of sand is a problem If its a lot of sand you can check the following.
1. O-ring in side the filter valve when standpipe inserts is intact. Make sure that standpipe is not cracked and seats well into valve.
2. check spyder gasket inside filter head. (looks like a wagon wheel) if it is loose or is pulling up it will need to replaced or re-siliconed. A good indication of this being the problem is if water is leaking from backwash port.
3. Check hoses to make sure that the to pool, to pump conections have not been reversed, if this was case you would get a lotta sand into pool. (can empty tank)
Jul 04, 2009 | Hayward Pro Series 18" Above Ground Pool...
A crack in the plastic of little tikes sandbox
Try an epoxy plastic repair kit from Home Depot or Lowes...should do the trick!
Mar 22, 2009 | Little Tikes Construction Sandbox
Toys Logo
71 people viewed this question
Top Little Tikes Toys Experts
 Russ Hill
Russ Hill
Brett Duxbury
Brett Duxbury
Bill Boyd
Are you a Little Tikes Toy Expert? Answer questions, earn points and help others
