How do i fold vivitar sound storm headphones?
Vivitar VM14235 Bluetooth Headphones
Fixya does not sell replacement USB charging cables.
Aug 25, 2017 | Vivitar Cell Phones
I have broken the top of my headphones, the part that locks the to when you unfold them and fold them up. They are an older model which are in good shape never got tryed to see if they can be fixed
Hi, if the headphones still work and are broken have you tried obtaining a good quality glue to repair the h/phones broken part , but the upside is they will not be fold-able after glueing.
May 18, 2016 | Able Planet XNC230W Extreme Foldable Noise...
My ipod classic is only playing out of 1 headphone, it is the same with all headphones
Step 1:
Your trusty iPod has been a close and reliable friend for a long time but one morning only the sound of air comes through the headphones. The likely culprit is a loose or broken headphone jack that is in need of repair. Rather than spend an exorbitant amount of money to have someone fix it you can easily make the repair on your own and have your iPod friend back. Read on to learn how to fix a broken headphone jack for a fifth generation 30GB or 60GB iPod video.
Open the iPod case with a small flathead screwdriver by slipping it under the centerline of the case. You will find a series of clips you have to release in order for the case to open up about an inch. Locate the headphone jack connection and verify that there are no broken wires. Fix broken wires quickly by twisting the wires back together and wrapping with electrical tape. Test the iPod for sound by connecting your headphones to the jack. Replace the wires completely if you find static coming from the iPod jack. Fold a business card twice so that it wants to unfold and slip it into the case over the blue sponge. This creates the pressure needed to hold the jack in place and allow a solid connection. Push the case together without engaging the clips on the side and test to make sure the jack is now working. Try a thicker business card or fold the first one again to get enough pressure onto the jack connection if the first card didn't fix the problem. Press the case fully together until the clips click into place. Use extra care when inserting your headset to ensure the jack remains in place.
DigiExpress - iPod Video / iPod Classic Headphone Jack installation
http://www.youtube.com/watch?v=MXXgV6YNGkQ
Feb 22, 2013 | Apple iPod classic MP3 Player
WILL TWO SONY HEADSETS RECEIVE THE SAME SIGNAL
go on use IR transmitter...
http://www.amazon.com/Sound-Storm-Laboratories-SHP-IR-Transmitter/dp/B0015C1RKE
THANK U...
Nov 23, 2012 | Sony MDR-RF970RK Headphones
No sound after a storm- no fix found
it sounds like your sound card is dead .
you may have to get a new one
Sep 27, 2009 | Computers & Internet
Default to headset mode
this is actually a glitch with the BB storm.
Stick a set of headphones in the headphone jack for 3-5 seconds, then go back to the HOME SCREEN and unplug the headphones (dont go ripping the headphones out, as this is what i noticed in my issues causes the phone to become stuck in the first place, like pulling the headphones out in the middle of listing to a song or video).
Usually works for me. This has been an issue with many builds.
You would think resetting the phone would fix this, but it doesn't. Has something to do with the sound device software not recognizing there is no longer a set of headphones in place...
Jul 11, 2009 | RIM BlackBerry Storm 9530 Smartphone
How do you fold lowrider headphones?
It's easy,
Step1: rotate the earpeices so that either the cushions face up or down
Step2: fold one side inwards by bending the rotating elboe inwards, this elboe is located one inch above the top of the cushion
Step3: now do the same for the other side
Step4: as you fold/rotate the second earpeice, do so in a way that this earpeice lies underneath or ontop of the first folded earpeice
Note: as you do step 4, you will notice that the middle of the top band starts to bend to accomodate the motion of this folding process
Add. Note: the mic may be sticking out at an odd angle by now, rotate it towards the rest of the mass that is now your folded headphones...... now they are ready for your pocket
Dec 26, 2008 | Skull Candy Lowrider Headphones
41 people viewed this question
 Grubhead
Grubhead
