Question about LG WM-2032H Front Load Washer
Can anyone help fix this washers spray function?
Unit Sprays fine when service tested, but does NOT spray cleaning solution to wet clothing. Unit doesnt spray until the wash cycle is almost over. Unit used to spray the clothing almost immediately upon starting any of the wash cycles. Now my clothes are NOT WASHING PROPERLY. BOOOOO!!!!
  • BJ Mott
    BJ Mott Apr 02, 2015
    Any way to determine if this is a circuitboard or other chip type issue? ?? I can use the QC mode and successfully complete each of the following from the manual’s QC test mode section . I can see the water spray and shut off when I press the button to stop the WaterCirculation test and start the Drain test. This is all from the manual….. THANKS!! ************* “7-2. QC TEST MODE. The washer must be empty and the controls must be in the off state. ₪?Press the SPIN SPEED and SOIL LEVEL buttons simultaneously. ₪?Press the Power button, while the above condition. Then buzzer sound twice. ₪?In order to advance to the next step of test mode, press the START / PAUSE button once. 7-3. HOW TO CHECK THE WATER LEVEL FREQUENCY Press the SPIN SPEED and SOIL LEVEL button simultaneously. So, for example a display indicating 241 : a Water level frequency of 241 x.1 kHz = 24.1 kHz The digits indicate the water level frequency ( x.1 kHz ). Check Point Display Status None Turns on all lamps and locks the door. “ *************Press the START / PAUSE button the number of times indicated below for each test. ************* “--1 time Tumble clockwise. rpm (40~50). --2 times Low speed Spin. rpm. –3 times High speed Spin. rpm. --4 times Inlet valve for prewash turns on. Water level frequency (25~65). -- 5 times Inlet valve for main wash turns on. Water level frequency (25~65) . -- 6 times Inlet valve for hot water turns on. Water level frequency (25~65) . --7 times Inlet valve for softener turns on. Water level frequency (25~65). --8 times Inlet valve for bleach turns on. Water level frequency (25~65). --9 times Tumble counterclockwise. rpm (40~50). --10 times Heater turns on for 3 sec. Water temperature. --11 times Circulation pump turns on. Water level frequency (25~65) . --12 times Drain pump turns on. Water level frequency (25~65) . --13 times Power off and unlock the door. Turn off all lamps”
  • LG Master
  • 2,160 Answers
Is it getting enough water in tub? try extra water button and see if then it works. if that makes it work, then water pressure sensor may be an issue
Posted on Apr 01, 2015
Testimonial: "Thanks RDJagger! Yes, the tub fills with water, hot or cold, properly. I verify the water level reading with the control panel. When the level get too low, it adds water and stops adding at the proper level. I'm stumped since it does indeed actually recirculate/spray during the wash cycle, it just doesn't do it when it's supposed to. Thanks again!!"
  • 2 more comments
  • rdjagger Apr 02, 2015
    well there are four water inlet valves on your unit i believe, one of them is either disconnected or not working would be my best guess. good luck. easy fix and fairly inexpensive.
  • BJ Mott
    Hello & Thanks again!! Well, I'm able to test the water inlet valves and all 5 test successfully. Lost the hot water valve two years ago, replaced it and no leaks or problems with any of the valves or QC testing of the valves since that hot water valve failure. SMH totally perplexed, but I suspect a circuit board issue of some kind impacting the starting times for water circulation. It sprays only in the middle to end of wash cycles and doesnt spray at all during the rinse cycle! Just bizarro!! At least if this were a Microsoft problem I could just reboot it, uninstall a screen saver or malware or pay for a quick painless upgrade(YA RIGHT!)
    Well I have heard that holding in the power button while plugged in or unplugged can reset it. 15 secs or so. Never tried so don't know. A wild shot in the dark.
  • BJ Mott
    HooRah! Looking forward to trying to hard reset the electronics. I can't imagine any other cause since water circulation and all other washer functions test successfully 100%. Damned computer chips I tell ya!! Where's my old fashioned wash tub & board???
  • 1294 Answers
SOURCE: LG1812CW Walks During Spin Cycle
The rear 2 legs are fixed. The front 2 are adjustable. There are lock nuts to prevent the adjustment from coming loose. The front legs are to be adjusted to the minimum. While not running if the machine rocks, continue the adjustment. For few clothes there is a half load switch; best the read the manual well before anything. Well if the walking continues, check the rear for any shocks or springs that may hv fallen off during transport. Plug off the wall socket first.
Posted on May 29, 2007
johnychel
  • 796 Answers
SOURCE: spinning cycle
Keeping in mind that the soap & bleach gets dispensed into your wash on the second to last rinse cycle and that most all rinse cycles are in cold water. Is your cold water valve screen plugged causing your washer to rinse poorly? Are you using the HE detergent? If not maybe the washer is sudsing up to much and having a hard time rinsing all the suds and bleach out and leaving the clothes soapy.
Fill the washer up with no clothes in it on a cold/cold wash setting does it take a long time to fill the washer up? Also when it is full and agitating is there suds in the washer?
Last suggestion is if the drain is hose is a lot higher than the top of the washer it might have a hard time draining out all of the soap water before the next load
Posted on Mar 23, 2008
ginko
  • 19396 Answers
SOURCE: clothes are still water logged after cycle
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
From Repairclinic
Posted on Oct 24, 2008
  • 68 Answers
SOURCE: Cloths Soaked after Spin Cycle
If the motor has a transmission, it could be stuck in 1st gear. I think the agitator running is normal.
Posted on Jan 17, 2009
  • 72 Answers
SOURCE: LG Tromm WM2496HWM Washer - stops mid cycle
use only HE (high efficiency ) soap,try not to use too much ,run tub clean cycle with a little bleach to kill smell
Posted on Jun 19, 2009
I have a 2004 BMW 320i M sport The windscreen washer sprays do not work, no noise, no water coming out. Anyone know how to fix?
I would recommend checking the washer pump unit on the washer reservoir. They have a tendency to clog up with algae or fail. You can also check for voltage to the washer pump while someone is activating it.
Feb 26, 2012 | 2004 BMW 320i
Diesel pump sprays and ignition coil discharges but No cumbustion?? please help
test compression in cylinder use a bit of oil remove igniter to do test also check to see if glow plug heats up
Jan 13, 2011 | Northstar Gas Powered Wet Steam & Hot...
Bissell, ProHeat, ProTech won't spray water.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
895r
Jul 16, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Whirlpool Duet 9150.. should I be able to see water in the tub when it is washing? There is no visible water level. The clothes are wet but how do they get clean?
water is drawn THROUGH the clothes. There is a BIT of water in the drum - however the water sprays on the clothes during the wash cycle and draws the dirt/water/detergent THROUGH the clothes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer wont fill with water/clothes dont get clean
Actually the machine is working like it is designed. When the correct soap is used, these machines clean clothes better than the old style. Try using a major brand of soap like Tide, Bold, or Cheer. Make sure it has the HE design on the bottle. This means that it is made just for the new High Efficiency machines. Also make sure you don't use to much. Read the directions. If this is done correctly, I'm sure you will find that it does clean great. I was like you when I first saw one of these new machines. "These is no way you can clean dirty and I mean dirty clothes without enough water to cover them. Well since, I have became a believer. They have put a lot of thought into designing these things. They had to of, for them to clean as good as they do.
Please rate solution
Aug 27, 2009 | Whirlpool Duet WFW9550 Washer
Realigning the front window washer unit
I Believe those Clip into the Hood and if it is Loose and Will not clip Down it will Spray wild and May Be Broke at the Clip (REPLACE IT) but if it is Thght then it may Be Parcialy CLOGED try A Needle in the Hole that Sprays to Unclog it
Feb 05, 2009 | 2003 Chevrolet TrailBlazer
Whirlpool Calypso Washer: No water fill intermittent
Check the hose from the tub to the pressure switch, make sure its clear and the reservoir on the tub is clean.
Oct 21, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Not recirculating
"0d" refers to an "open door" problem. Need to chceck the lid switch to insure it is functioning properly.
Dec 30, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
LG WM-2032H Front Load Washer Logo
103 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
